Driving Nixie Tubes
Hi All,
Anyone have thoughts on the best way to drive Nixie tubes from a Stamp?
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
What are Nixie Tubes?
Perplex, Kai
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, January 22, 2003 6:53 PM
Subject: [noparse][[/noparse]basicstamps] Driving Nixie Tubes
> Hi All,
> Thanks,
> Jonathan
> www.madlabs.info
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Essentially, 7-segment displays in a vacuum tube. They were the
original "digital" text display technology.
You can find them in old HP counters and computer equipment. If
you are much younger than about 30, you probably havent' run into
them.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: (403)-730-8603 Fax: (403)-730-8903
http://www.HVWTech.com
** New Breadboard Voltage Regulator (BVR) -A plugable +5 Volt
power supply !
the other 7 drive a digit. I believe they require 70 volts DC to light
them up. So you would need something to buffer the Stamp from the high
voltage and something to generate the 70 volts.
I have 6 Nixie tubes, If I can find them in my junk pile. I always
thought they would make a great retro looking clock. If someone has
better info, please post to this list.
TIA,
Randy Wahlfeldt
KC9BFV
Email: randyw@w...
Web: http://www.staff.uiuc.edu/~rwahlfel
Original Message
Sent: Wednesday, January 22, 2003 1:12 PM
Subject: Re: [noparse][[/noparse]basicstamps] Driving Nixie Tubes
> > Hi...
> them.
> power supply !
and Body of the message will be ignored.
Your most probably best driving a NPN transistor with a high Vce (>300V)
from a stamp pin, to ground the appropriate cathode. The Nixies I used
30 odd years ago (built a digital clock using TTL logic) I think had a
common anode and needed about 250 Vdc via a resistor (50K ish). You then
grounded the cathode to "illuminate" the required number. Collector
current is pretty insignificant, but be careful 250VDC hurts. I think
they were "cold cathode" devices (it's a long time ago, so my memory is
a bit vague).
Rob
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rA-WIpMCS5TaY2LlHBIPlVxf6cOsD2nlupZ9XRmCiNoVxENU-415jAkVZtkQRmN7Qv0xaqBNEU045zOJ4bKz_w]jpeakall@m...[/url
Sent: 22 January 2003 17:54
To: basicstamps@yahoogroups.com
Hi All,
Jonathan
www.madlabs.info
A Nixie tube is a form of Neon lamp and has the same driving requirements. The
tube has 11 contacts, a common and one for each of the 10 wires that is formed
into the digits 0 through 9. For some ideas on driving Nixis tubes check out:
http://www.electricstuff.co.uk/nixclock.html
http://www.amug.org/~jthomas/clockpage.html
or do a Google search on "nixie clock".
Years ago I built a decade counting stage using the then very new Fairchild 723
RTL logic flip-flop in a ring "Johnson" counter that drove a Nixie tube using a
transistor rated for about 100 Volts on each of the 10 digit pins.
Have Fun,
Brooke Clarke, N6GCE
http://www.prc68.com
> Date: Wed, 22 Jan 2003 09:53:53 -0800
> From: "Jonathan Peakall" <jpeakall@m...>
> Subject: Driving Nixie Tubes
> Hi All,
> Thanks,
> Jonathan
> www.madlabs.info
from a Stamp should be similar.
Rich
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=34glKwaDF-YlM_eGRBC__eHc4V3ttEtxPog54DStlP7f9xC9Yt-AaZRVWYUazm2loka8_maZ2z7gh1sV7Q]jpeakall@m...[/url
Sent: Wednesday, January 22, 2003 11:54 AM
Hi All,
Jonathan
www.madlabs.info
but were NEON filled, operating on the same principle as the neon indicator
lamps we still see occasionally. There were, I believe 10 separate
cathodes, each in the shape of a digit, plus a decimal point.
Nixies were in a "compactron" format glass envelope with 12 pins, one was
common and the other 11 pins were energized individually to make the
corresponding element glow. The elements were arranged to allow the least
obscuration from the other non-selected elements. There was no logic of any
type within this tube. In 1968, I used the first electronic calculator I
had ever seen, made by Bourroughs, which had a Nixie display.
p@
> Off the top of my head... They are in 8 pin tubes. One pin is common and
What I was hoping for is a device like a ULN2003 that can handle the
voltage. The tubes only need 3mA or so for current draw. Any such device out
there? Of course, I can just use transistors as you say.
Jonathan
www.madlabs.info
Original Message
Sent: Wednesday, January 22, 2003 11:26 AM
Subject: RE: [noparse][[/noparse]basicstamps] Driving Nixie Tubes
> Hi
> a bit vague).
> Rob
Original Message
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LYAMQMmZ8lgnLHUlLQvAjEuadYCZHzavDwFifsUrgEBGhAA2kibNunYmgXy-eYv94yIUHFrYGJVyfE8CFLY]jpeakall@m...[/url
> Hi All,
> Thanks,
> Jonathan
> www.madlabs.info
characters 0 through 9 and each one can be lit up separately. They date back
to way before 7-segment displays.
If I remember right, there was some sort of project in Nuts & Volts or
Poptronics several years ago about a nixie tube or fluorescent display
clock.
Original Message
neon bulbs in a vertical column for each digit of the display, and the later
ones had the nixie tubes. We used one well into the 80's in our shop because
it was more accurate than the stuff we could buy at a reasonable price.
I also had one at home along with a Hitchcock VTVM the size of a small
suitcase with about an 8" meter movement.
Original Message
> them.
http://www.cosmodog.com/nixie.html
That I have purchased. It's very nice.
To hook up and interface to the tubes, you can do a google search on
"Nixie tube clocks" and find numerous circuit examples.
IIRC, instead of driving a LED display, you drive a high voltage
transistor which switches the nixie tube digits on and off.
The problem is not turning the Nixies numerals on, it's when they're
off. The collectors of the drive transistor, whether it's a discrete
device or in an array (such as the DIL ULN type IC's) will have a
potential difference of 250 VDC collector to emitter. So you need a
device that can withstand that.
All the ULN range of devices I've seen only can handle 50 VDC, the
"MPSA" Range of Transistors are normally good for high voltage (MPSA42
300 VDC).
HTH
Rob
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=D2hPEImI5UNX5nElJjgJhjY1XxkovxaZ44Huu3znOnYexaIV15Tlgpyrp-6knCjayMOHRT2WyYoMiff_TX0]jpeakall@m...[/url
Sent: 22 January 2003 20:28
Hi Rob, All,
out
Jonathan
www.madlabs.info
Original Message
> Hi
(>300V)
then
is
> a bit vague).
> Rob
Original Message
> Hi All,
Stamp?
> Thanks,
> Jonathan
> www.madlabs.info
and
You can use Allegro HV serial drivers, or sink the cathodes with MPSA42
transistors which can be driven in turn with HC595 serial drivers. I suggest
that you join the Nixie group here on Yahoo.
Cheers
Derryck
I will check out the Allegro HV serial drivers. I joined the Nixie list
yesterday.
Thanks for the input!
Jonathan
www.madlabs.info
Original Message
Sent: Thursday, January 23, 2003 6:31 AM
suggest
> Cheers
> Derryck
>yesterday
Have you made a start on the code yet? I guess a simple counter incrementing
minutes and hours where appropriate will do, with pulse input from a suitable
source?
Cheers
Derryck
No start on code yet, I am still collecting hardware. I am going to use an
Atomic clock to do the timekeeping. If you are interested in code after I
get to that part, you are welcome to it. Just let me know.
Jonathan
www.madlabs.info
Original Message
Sent: Friday, January 24, 2003 6:31 AM
> >yesterday
incrementing
suitable
> source?
> Cheers
> Derryck
I looked at the Allegro site, and they have many choices of devices. I did
not see one with high enough voltage to drive Nixie's. Do you have a part
number?
Jonathan
www.madlabs.info
Original Message
> >yesterday
incrementing
suitable
> source?
> Cheers
> Derryck
>Derryck,
>number?
>Jonathan
>www.madlabs.info
Jonathan -
You may want to take a look here for at the 2 digit Nixie Tube driver board.
It appears all of the information is there, including the PCB layout, all for
free. http://www.gunnsys.com/nixiedrv.html
Bruce Bates
Original Message
>From: <derryck@n...>
> > >yesterday
>incrementing
>suitable
> > source?
> > Cheers
> > Derryck
did
> >number?
board.
for
>number?
A6810 or A6812 are the devices that were recommended.
Cheers
Derryck
Original Message
did
> >number?
a bcd to decimal decoder such as a 7445 with an additional few components
will do a fine job.
norm
>Reply-To: basicstamps@yahoogroups.com
>Date: Mon, 27 Jan 2003 10:49:46 -0000
>Hi Jonathan,
>did
> >number?
>Cheers
>Derryck
_________________________________________________________________
The new MSN 8: advanced junk mail protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
Any schematics or references about this?
Jonathan
Original Message
Sent: Monday, January 27, 2003 11:05 AM
> hello.
> will do a fine job.
> norm
> >Hi Jonathan,
> >did
part
> > >number?
> >Cheers
> >Derryck
the last place i remember seeing it is in a ttl or cmos data manual.
norm
>Date: Mon, 27 Jan 2003 13:57:31 -0800
>Hi Norm,
>Thanks,
>Jonathan
Original Message
>From: "norman doty" <normdoty@h...>
> > hello.
>components
> > will do a fine job.
> > norm
> > >Hi Jonathan,
>I
> > >did
>part
> > > >number?
> > >Cheers
> > >Derryck
>and
>and
The new MSN 8: smart spam protection and 2 months FREE*
