At 01:34 AM 1/17/03 +0000, richeybrooksiii <richey@c...> wrote:
>does anyone know if you can send a dimmerpack (for stage lighting) a
>DMX single from a stamp?
I don't think so. The data rate is 250,000 bits per second which is 4 us
per bit time. I don't think the Stamp is up to that speed (yet).
You can certainly do it from a standard PIC, though. I have code that does
just that.
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
DMX is an extention of RS-485 serial protocol that is run
asynchonously over a 5 pin XLR cable. It also runs at 250kBPS which
I believe is faster than is possible with Basic Stamp SEROUT
command. If you could speed it up, then there is no reason why not.
There might be a way to use some kind of external serial driver.
They also sell dumb DMX controlers that are programed via RS232. You
could definatly use the stamp to control the box which in turn
controls the dimmers. These things cost ~$200 which, for stage
lighting is damn cheap -- compare to a dimmer. So if you can spend a
little money and just want a stamp to control lights then you're all
set. If you were trying to use the stamp to avoid shelling out $200
for such a box, then you're SOL.
-selket
--- In basicstamps@yahoogroups.com, "richeybrooksiii <richey@c...>"
a
> Thanks
> Richey
I've been looking at doing this for a while now (trying to build
wireless dimmers, motor control, etc) and here is what I've found. For a
stamp to receive DMX you need a PIC, 8051, or any other programmable
device that can handle interrupts and run at 250K. You then pass on a
couple of channels to a stamp. To send DMX you would definitely be
looking somewhere other than a stamp. Unfortunate I know, but the stamp
is great for something's just not this particular application. That's
the way it goes. Ian
Original Message
From: richeybrooksiii <richey@c...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mH5fpP6ZzocAX4UAbZ0_FgnXxIDWdxZcEw9dNXVx4ui574EwGzBwyy8-Q2aj6_yw8R2oSybkYrRMgagt]richey@c...[/url
Sent: January 16, 2003 8:34 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Basic Stamp and DMX
Richey
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
> Short answer: no
> -selket
> a
> > Thanks
> > Richey
> from the same email address that you subscribed. Text in the Subject and Body
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
No you can't. Just because they use the same plug doesn't mean that
the protocols are the same. Midi is 31k baud and DMX is 250k baud.
the stamp can go up to 125k baud.
--- In basicstamps@yahoogroups.com, "Sean T. Lamont .lost."
<lamont@a...> wrote:
> Can't you do MIDI->DMX? You can *certainly* drive midi from a
stamp, I do
> it all the time.
> On Fri, 17 Jan 2003, selket_10027 <selket_10027@y...> wrote:
> > Short answer: no
which
not.
You
spend a
all
$200
> > -selket
<richey@c...>"
lighting)
> > a
> > > Thanks
> > > Richey
Subject and Body of the message will be ignored.
(ServNet)
Bremerton
No, that's not what I'm saying. There are devices for driving DMX systems
with midi control, which would be an alternative to doing conversion from
serial to DMX.
> stamp, I do
> > it all the time.
> > > Short answer: no
> which
> not.
> You
> spend a
> all
> $200
> > > -selket
> <richey@c...>"
> lighting)
> > > a
> > > > Thanks
> > > > Richey
> (ServNet)
> Bremerton
just that.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
-selket
a
> Thanks
> Richey
Original Message
Richey
it all the time.
> Short answer: no
> -selket
> a
> > Thanks
> > Richey
stamp, I do
> it all the time.
> > Short answer: no
which
not.
You
spend a
all
$200
> > -selket
<richey@c...>"
lighting)
> > a
> > > Thanks
> > > Richey
(ServNet)
Bremerton
serial to DMX.
> stamp, I do
> > it all the time.
> > > Short answer: no
> which
> not.
> You
> spend a
> all
> $200
> > > -selket
> <richey@c...>"
> lighting)
> > > a
> > > > Thanks
> > > > Richey
> (ServNet)
> Bremerton
