lookup question
I'm doing the following to convert the day (1-7) to text however, it
seems that there must be a better way. Anyone?
dow var byte(3)
day var byte '1=Sun, 2=Mon,...,7=Sat
lookup day-1,[noparse][[/noparse]"SMTWTFS"],dow(0)
lookup day-1,[noparse][[/noparse]"uouehra"],dow(1)
lookup day-1,[noparse][[/noparse]"nneduit"],dow(2)
' dow now contains "Sun, Mon, etc"
dow var byte(3)
hold it, that is, you just want to convert a number to a string and send it
somewhere (i.e., a serial stream), you can do this:
day VAR Nib
idx VAR Byte
eePtr VAR Byte
char VAR Byte
DayStr DATA "SUNMONTUEWEDTHUFRISAT"
Main:
FOR day = 1 TO 7
GOSUB Print_Day
DEBUG CR
NEXT
END
Print_Day:
eePtr = (day - 1 ) * 3
FOR idx = eePtr TO (eePtr + 2)
READ idx, char
DEBUG char
NEXT
RETURN
DEBUG can be replaced with SEROUT (plus appropriate parameters).
-- Jon Williams
-- Parallax
In a message dated 1/13/2003 8:36:50 AM Central Standard Time,
gtdesrosi@c... writes:
> dow var byte(3)
