imbedded for...next loops
Alex-
Nested FOR-NEXT loops are valid on all Stamps. The BS1 is unique in
that it will allow specifying the variable associated with NEXT,
such as:
FOR i = 1 to 10
FOR j = 1 to 5
NEXT j
NEXT i
The above will generate a syntax error with any flavor of BS2*.
Instead, just do this:
FOR i = 1 to 10
FOR j = 1 to 5
NEXT
NEXT
The editor will figure out which variable the NEXT applies to, which
will be the variable specified by the latest, preceding FOR.
Standard disclaimer/Alternate response: I agree with Jon, Tracy, or
Al and defer to their explanations.
Steve
such as:
FOR i = 1 to 10
FOR j = 1 to 5
NEXT j
NEXT i
FOR i = 1 to 10
FOR j = 1 to 5
NEXT
NEXT
Steve
syntax error. The documentation says that it only works on a BS1
(!!!)...is this really the case?
--Alex
idx1 VAR Nib
idx2 VAR Nib
Main:
FOR idx1 = 1 TO 5
FOR idx2 = 1 TO 5
DEBUG DEC1 idx1, ":", DEC1 idx2, " "
NEXT
DEBUG CR
NEXT
END
-- Jon Williams
-- Parallax
In a message dated 1/9/2003 9:03:03 PM Central Standard Time,
atl_guy1138@y... writes:
> When I tried an imbedded for...next loop on my BS-2SX, it gave me a
> --Alex
> --Alex
Okay, i get it now...I was trying to specify which loop the 'next'
applied to (i.e. 'next i'). Apparently the Stamp can figure that out
by itself.
thanks
--Alex
doing things like this that could lead to bad bugs:
( for illustration only)
FOR idx1 = x TO y
' some code
FOR idx2 = x TO y
' some code
NEXT idx1
NEXT idx2
You can accomplish what this code is trying to do by making the idx2 control
loop the outer-most.
-- Jon Williams
-- Parallax
In a message dated 1/10/2003 9:18:04 AM Central Standard Time,
> by itself.
> thanks
> --Alex
get paid to do it or not.
James
On Fri, 10 Jan 2003 11:11:08 EST jonwms@a... wrote:
> It just adds unnecessary complexity to the
> compiler and prevents you from
> bugs:
> FOR idx1 = x TO y
> ' some code
> FOR idx2 = x TO y
> ' some code
> NEXT idx1
> NEXT idx2
> -- Jon Williams
> -- Parallax
> Standard Time,
> > by itself.
> > thanks
> > --Alex
> removed]
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you
> subscribed. Text in the Subject and Body of
> the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
