reading ouputs
Hi All,
I have spent numerous hours trying to work out why the following code
does not dispaly the correct state of each output (off/on or
closed/open, or 1 or 0)
The code is designed to toggle outputs based on a keypad input. This
part works fine. I just can not seem to dispaly the current status of
a given output.
If I individually assign each output (i.e. out2, out6 etc), that
works. However, tagging a VAR onto out2 (i.e. out0(result) or outs
(result), does not seem to work.
Any suggestions would be greatly appreciated.
'{$STAMP BS2p}
'{$PORT COM1}
dirs=%1111111111111111 '0=input >> 1=output
bps con 240 '9600 Baudrate
dly con 20 'Global pause delay..
auxio 'use aux i/o
Rx con 13 'Serin (receive) pin 13
invar var byte 'key input varible
result var byte 'decoded key
pause 500
HIGH 11 'Set the pin high (Power LED on).
gosub reset 'reset lcd
loop:
auxio
serin Rx,bps,[noparse][[/noparse]invar]
if invar=13 then tgl 'if key 13 is pressed then toggle
output
if invar=8 then reset
invar=invar-48
if invar<=10 then keyscan
invar = invar-7
Keyscan:
LOOKUP invar, [noparse][[/noparse]48,55,56,57,52,53,54,49,50,51,65,66,67,68,35,42],result
mainio
if outs(result) = 0 then displayo
goto displayc
tgl:
debug "tgl",cr
mainio
toggle(result) 'Toggle output
if outs(result) = 0 then displayo 'read status of output, then
dislay
goto displayc
goto loop
displayc: 'display relay closed
serout 0,bps,[noparse][[/noparse]254,192]
pause dly
serout 0,bps,[noparse][[/noparse]"RLY ", (result), " CLOSED"] 'display status of
selected relay
pause 100
goto loop
displayo:
pause dly
serout 0,bps,[noparse][[/noparse]"RLY ", (result), " OPEN "]
pause 100
goto loop
reset:
debug "reset",cr
mainio
serout 0,bps,[noparse][[/noparse]1]
pause dly
serout 0,bps,[noparse][[/noparse]12]
pause dly
serout 0,bps, [noparse][[/noparse]"READY"]
goto loop
ken
a given output.
'{$STAMP BS2p}
'{$PORT COM1}
auxio 'use aux i/o
pause 500
loop:
auxio
output
invar=invar-48
invar = invar-7
Keyscan:
mainio
goto displayc
tgl:
debug "tgl",cr
mainio
dislay
goto displayc
goto loop
pause dly
selected relay
pause 100
goto loop
displayo:
pause dly
pause 100
goto loop
reset:
debug "reset",cr
mainio
pause dly
pause dly
goto loop
ken
you probably should use 'outs.LOWBIT(result)'
to access the individual bits of outs like a bit array.
Hope this helps
Adrian
this:
status = Outs.LowBit(idx)
Where idx is 0 - 15 corresponding to your output bit. Since you're using a
BS2p40, you must remember which set of pins you're dealing with. If you want
to know about I/O pin 15 then this works:
MAINIO
status = Outs.LowBit(15)
If you're outputs are on the AUX group, you need to do this:
AUXIO
If you're mixing pins on both groups, you can write a little routine that
works like this:
Get_Status:
IOTERM (ioPin 16) ' ioPin = 0 - 31
status = Outs.LowBit(ioPin)
RETURN
I hope this helps.
-- Jon Williams
-- Parallax
In a message dated 1/9/2003 3:36:56 AM Central Standard Time,
jduldig@s... writes:
> a given output.
not successive words. Use this syntax:
out0(result)
is equivalent to
outs.lowbit(result)
is equivalent to
outs.bit0(result)
Here is another issue:
>output
>invar=invar-48
>invar = invar-7
>Keyscan:
The "invar" will be 0,1,....., but the number output in "result" at
this point will be too large for the following [noparse][[/noparse]even when changed to
out0(result)].
>mainio
>goto displayc
out0(48) would refer to the 48th bit following out0, which is way up
in the memory space above the i/o pin states.
out0(48), out0(55),... and so on is not what you want. If you need
to permute the lookup values, maybe:
LOOKUP invar, [noparse][[/noparse]0,7,8,9,4,,...],result
-- Tracy
