Stamp control of 2.4GHz LAN/Sender unit for ATV
Has anyone used a Stamp BS2-IC for frequency control of a 2.4GHz
Wireless LAN/Video sender for multi-channel use on ATV (Ham -
Amateur Television)? I've seen external controller circuits using a
PIC16F84 with a 1X16LCD Display together with some code to step
through the entire tuning range in 250KHz, 500KHz or 1MHz steps. I
would think that the Stamp is purpose made for the job (easier to
upload the program)! Any help, particularly with programming will
most welcome.
(Typical Unit using a PIC can be found here:
http://lea.hamradio.si/~s51kq/UNI.HTM click on UNI13P (UK Flag)
Bye for now – Steve/G4MJW
http://www.skylites.freeserve.co.uk
most welcome.
These cans use a SP5055 I2C controlled PLL. Pretty simple to program, remove
the SCL and SDA lines form the OEM control board. I have found that these
lines will need to be pulled up to +5vdc using a 10k resistor. Connect these
lines to your micro, if it does do I2C. The PLL needs 5 bytes and are
programmed in 125khz steps. Here's a sample program I wrote in BASCOM-AVR
for a 90s2313 chip. It should be pretty easy to modify it to work with the
stamp.
The formula for frequency is "Desired_Frequency" * 8 = "PLL WORD"
9976 / 8 = 1.247Ghz
Note: This is for the 23cm version of the can. THE SAME PRINCIPALS APPLY to
the 23cm cans.
Also be careful these modules will transmit out of the Amateur Band.
' ATV RF Module:
' Note: The Module's SCL and SDL lines requires a 10k pull up resistor
for
' each line to +5vdc. The module uses a Mitel SP5055 2.6GHz
' Bi-directional I2C BUS Controlled Synthesizer, for frequency
' generation. See the data sheet for more info.
' Pin 1 Audio/Left
' Pin 2 Audio/Right
' Pin 3 +12 - 15 VDC
' Pin 4 Video
' Pin 5 I2C SDA, Clock Pin 9 - PortD.5
' Pin 6 I2C SCL, Data Pin 8 - PortD.4
' CASE Ground
' SMA RF out
'***** Compiler Setup:
$regfile = "2313DEF.dat" ' define chip type
$baud = 19200 ' configure com port for
19200,8,N,1
$crystal = 7372800 ' set crystal to 7.3728 MHz
Config Sda = Portd.5 ' SDA is connected to Port D pin 4
Config Scl = Portd.4 ' SCL is connected to Port D pin 5
'***** Define Variables:
Dim Status As Byte ' module status
Dim Freq_msb As Byte ' I2C MSB byte holder for Freq
Dim Freq_lsb As Byte ' I2C LSB byte holder for Freq
Dim Freq As Word ' 23cm frequency * 8
Dim Pll As Byte ' PLL status byte
Dim Fail_cnt As Byte ' # of times the PLL is out of
lock
Const Address_write = 194 ' slave write address
Const Address_read = 195 ' slave read address
Const Charge_pump = 142 ' default value for SP5055
Const Control_bit = 0 ' default value for SP5055
'***** Main Program Starts:
Ddrd = &B01001110 ' Set port d's direction
Gosub Can_off ' make sure module is off
Begin: ' start of main program loop
Waitms 20 ' wait for everything to power up
Freq = 9976 ' set transmit frequency to 1.247
Ghz
Gosub Wt_can ' program frequency to module
End ' Something blew-up if we're here!
'***** Subroutines Below:
Can_off: ' set frequency to 0 and fall
through
Status = 0 ' set status
Freq = 0 ' frequency equals 0
Wt_can: ' write frequency to module
Status = 1 ' set status byte
Freq_msb = High(freq) ' get high byte
Freq_lsb = Low(freq) ' get low byte
I2cstart ' generate start to I2C bus
I2cwbyte Address_write ' write address byte of module
I2cwbyte Freq_msb ' write msb of freq word to module
I2cwbyte Freq_lsb ' write lsb pf freq word to module
I2cwbyte Charge_pump ' write control code byte
I2cwbyte Control_bit ' write control code byte
Waitms 20 ' wait 20ms for I2C to finish
return
End
'***** EOF
Hope this helps,
Mike - kd5dhu
Original Message
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FoUzaKo5y37-wrLsYnv36EYhuCe71GfdzE9JEbVPyWeQxZWL37QUHApvsicym1SfZSI2NOWR9Upr_pU5zQJkv7FeKNE7j7NUZw]catweazle@s...[/url
Sent: Tuesday, January 07, 2003 6:00 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Stamp control of 2.4GHz LAN/Sender unit for ATV
most welcome.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I have both the original BS-1 and a BS2-IC. Neither have I2C but I
think there is something in the handbook abt adding it. I've only
ever "Stepped" motors for moving Lights at outside light shows
The BS-1 is a real veteran! I've just removed it from an automated
Skyskanner (Searchlight)which I fitted about 4 years ago. It's been
at Shows all over the world. It stepped a pair of large stepper
motors (Pan+Tilt). The 25V 80A switching PSU failed and most of the
wiring burnt up . . . . but the STAMP survived.
In reality, the two TX/RX units will "Live" on 2432MHz RX and
2346.5MHz on TX.
I will put something together and then work on translating yr prog.
Thanks again - Bye for now - Steve/G4MJW
--- In basicstamps@yahoogroups.com, "Mike Cook" <kd5dhu@a...> wrote:
> Steve,
program, remove
that these
Connect these
are
BASCOM-AVR
with the
> stamp.
> 9976 / 8 = 1.247Ghz
APPLY to
> the 23cm cans.
Amateur Band.
> ' ATV RF Module:
resistor
> for
2.6GHz
frequency
> ' Pin 1 Audio/Left
> ' Pin 2 Audio/Right
> ' Pin 4 Video
> ' CASE Ground
> ' SMA RF out
CUT CUT CUT CUT
