Microsecond pause durations
I saw in a post from a few weeks ago that pauses of a few
microseconds' duration might be possible with the BS2 SX if Assembly
were used:
"If you really need that much precision, you could switch to assembly
and use the SX directly ... that will give you complete control."
I need to pulse a signal in a pretty tight pattern....300 microseconds
low, 600 high, 1200 low, 600 high, and so on. Although I'm good at
coding, I'm new to microcontrollers. Could someone give me some advice
on how to use Assembly, or actually ANY strategy to get this timing?
FYI, what I'm actually trying to accomplish, is sending commands to a
Sony CD-player using the S-Link protocol...
Thanks in advance,
--Alex
were used:
Thanks in advance,
--Alex
with an Atmel AVR in Assembly Language. Very similar to what you want to do.
You can either use the internal timer(s) or a program loop to generate a
pulse every so often -- you have to start with your processor clock speed
and work backwards. Its definitely more difficult than Stamp Basic and it
will drive you nuts.
Original Message
> were used:
http://www.al-williams.com/pak8.htm
They also have a PWM coprocessor as well.
http://www.al-williams.com/pak5.htm This chip can be clocked at up to 75mhz
as well.
these chips can be controlled from the Basic Stamp quite easily.
With these chips you could get down to about a 5us pulse, with 1-2us
increments.
If you want real precision, you can use assembly and a Ubicom Scenix SX chip
directly.
The basic Stamp BS2-SX happens to use the Ubicom Scenix chip itself.
Original Message
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RYcEiknXtG0zdBwO3lkfkEXrIGjszSSEByJbBLC-YW2VVGUhg6OdOve-QMS7151pQMHjv0OfmHgW]daweasel@s...[/url
Sent: Thursday, January 02, 2003 11:02 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Microsecond pause durations
Haven't done it with an SX chip, but I did figure out how to run a servo
Original Message
> were used:
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
If you would rather not use assembly, the PicBasic Pro compiler can easily
do what you want with its "pauseus" command. The "us" in "pauseus"
indicates that this command is for microseconds (uS), so...
pauseus 300
...gives you 300 microseconds. PicBasic Pro generates code for the PIC line
of microcontrollers, which is what the BS2 uses.
The "SX" reference above appears to mean an "SX" microcontroller, rather
than the BS2-SX Stamp.
Randy Jones
www.glitchbuster.com
