Mini fuse holder
Hi all,
In looking at the Christmas lights, the light strings have mini fuses
in them. very small.
does anyone know if there is a fuse holder for a circuit board for
these little guys ?
I seems that the second largest item on the board is the fuse. This
seems a natural for mini boards.
Dave
these little guys ?
Dave
pushed into a couple of machine tool sockets. There are also the 5 x 20 mm
fuses they use in consumer electronics -- you can even get some fuse clips
and lay the board out to accept them.
For a low-tech solution, a single strand out of a 18 ga lamp cord is good
for about 1 amp.
Original Message
> these little guys ?
daweasel@s... writes:
> They make fuses the size of 1/4 watt resistors that can be soldered in or
> for about 1 amp.
A strand from 18 gauge lamp cord? That is geneous!!!!! I am going to try it.
I have some applications that can use that kind of fuse.
brown fine-strand zip-cord you see on most lamps and not the speaker wire
with the larger strands.
Go to www.mouser.com and search for 504-MCR -- this will list the
subminiature axial resistors.
Original Message
mm
clips
good
> > for about 1 amp.
it.
They make great slow blow fuses. They heat up and give off lots of smoke
before they pop.
Of course it depends on the short and how much current and voltage you run
through it.
We used this technique in Radio Control Systems we used to build a long time
ago.
Nicad battery packs can provide lots of current if you short them and the 10
ohm resistor would
protect everything including the wires. The resistor was cheaper than the
fuse.
If you need higher current then use a 5 ohm or lower value resistor.
The advantage the fuse had is that you can get a good fuse to pop or blow
faster, helping to
protect highly sensitive components from damage. If you aren't using those
types of parts a resistor works great.
Original Message
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z7LVWT4YU6rOYmnSMCxeFbB_oa5F89Jh5nHdUPNQaxKaoPxxIeNEEnU3CJIYL-CVWaoaivMeZEA5su5kFw]daweasel@s...[/url
Sent: Wednesday, January 01, 2003 10:42 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Mini fuse holder
for about 1 amp.
Original Message
> these little guys ?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
twisted wire comes in different hardnesses, and in a strand the wires
are different diameters. a very flexible cord, like a coffee pot
will have many more strands than say a TV cord.
Thinner strands make a more flexible bundle and cost more.
This is a great idea. probably good idea to get a lenght, test it
and keep it aside for your stock.
even better is that from the solder, the base is thicker forcing the
failure to be in an area of greater visibility.
Simplicity. and cheap !
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> In a message dated 1/1/2003 8:42:33 PM Pacific Standard Time,
soldered in or
5 x 20 mm
fuse clips
is good
> > for about 1 amp.
to try it.
are no fuse holders available.
The PICO fuses are ones I have used before, about the size of a small
cap, nice by expensive.
Thermal resettable fuses may be an option.
The one failure I have had so far was that while installing, an ac
line went to ground letting the AC rip across the board and burn up
the ground traces.
I hope more people contribute to this with options. I like the
single strand, a simple pair of binding posts and presto, replaceable.
Seems that someone should do that in a standard jumper block.
Dave
Dave
--- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> Thank Heathkit -- they used it on several of their kits. This is
the cheapy
speaker wire
Original Message
soldered in
> or
the 5 x 20
> mm
fuse
> clips
cord is
> good
> > > for about 1 amp.
going to try
> it.
> DOH! Axial fuses.
I figured "fuses".....
fast it would blow? I would think that a longer strand (like 1 inch) would
have more heat buildup and quicker burn-out than a real small one(1/4 inch)?
Is that not correct?
Original Message
To: basicstamps@yahoogroups.com <basicstamps@yahoogroups.com>
Date: Wednesday, January 01, 2003 10:44 PM
mm
clips
>> for about 1 amp.
it.
>How long is the exposed strand? Doesnt the length make a difference in how
>Not correct. You're "burning through" the diameter, not the length.
long. I really don't think it would make much difference though, as the
critical dimension is the diameter of the strand.
Original Message
how
would
inch)?
good
> >> for about 1 amp.
> it.
difference in how
inch) would
(1/4 inch)?
Would this mean that the long wire, although it would not benefit
from any heat sinks, would burn out at the same current as a short
wire that benefitted by the solder joints as heat sinks ?
I would imagine there are some thermaldynamics to add to the
calculations. even if it were just a time factor until it would burn
thru.
The concept sound interesting. it would appear that one could use a
simple 2 pin jumper, jamb a section of wire in the shorting block
instead of the full shorting block and the wire would be the home
brew fuse.
Dave
> difference in how
> inch) would
> (1/4 inch)?
> thru.
> brew fuse.
In fact in the dim, dark, ancient past domestic AC current fuse holders
were built as small ceramic blocks with two brass blades and
accompanying screw terminals. You attached a piece of fuse wire between
the two blades and pushed the block into the mating receptical. If the
lights blew, you started pulling blocked looking for melted wire. And If
your home used this sort of fuse holder, you also kept a roll of fuse
wire handy for when the thing blew. Normally the fuse wire was an alloy,
but in a pinch you could use suitably sized copper wire. The trick was
not to install wire *too* think and create a fire hazard.
I don't know if these were common here in the U.S. but in Australia,
where I grew up, they were the standard issue until circuit breakers
came along in the past twenty or thirty years. This isn't a new idea, by
any means.
I've also serviced equipment that uses this idea for a cheap main fuse
between two posts. Obviously, it's more of a pain to replace than a
simple fuse, but it has the benefit of low cost.
- peterd
Peter Deutsch pdeutsch@g...
Gydig Software
""It doesn't hurt to be optimistic. You can always cry later."
-- Lucimar Santos De Lima
cartridge type fuses for mains, or screw-in glass fuses for individual
circuits. The only thing I have ever seen with a bare fuse element was the
main fuse of some of the 70's models of Honda motorcycles.
Original Message
> > brew fuse.
> any means.
