Serial data with flow control help
Happy Newyear!!
I have been trying to get serial comms with flow control to work
between two BS2E's.
I got the program from the manual to work, so then proceded to add
it to my own program, which didn't work.
so i went back to the manual example and tried to get it to work
again, and guess what, I couldn't get it to go!!
OK so in case I have blown something up, I have tested each stamps
I/O functions for the pins concerned. Each stamp can output a high
on each pin, and each stamp can detect a high on each pin. I then
tested the serial out to a LCD on each pin and it works just fine.
I simply can't work out what is going on. Can anyone suggest
anything else I should be looking at?
Dwain.
between two BS2E's.
Dwain.
is a lot like asking "My car won't run, whats wrong with it" at a cocktail
party. Nothing to go on [noparse]:D[/noparse]
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, December 31, 2002 7:48 PM
Subject: [noparse][[/noparse]basicstamps] Serial data with flow control help
> Happy Newyear!!
> between two BS2E's.
> Regards,
> Dwain.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
You can download it as a PDF from this link:
<A
HREF="http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Download\
s_V3.asp">
http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads_V3.
asp</A>
-- Jon Williams
-- Parallax
In a message dated 12/31/2002 9:49:52 PM Central Standard Time,
dwainsworld@e... writes:
> Happy Newyear!!
> between two BS2E's.
> Regards,
> Dwain.
After about 69 hours of frustration, I have finally found what was amiss.
I was using a forward slash instead of a backslash in the pin definition
part of the code, which rather than generating an error, simply stopped the
flow control. Now there's a catch for young players!!
Thanks again.
Dwain.
Original Message
Sent: Wednesday, January 01, 2003 4:36 PM
Subject: Re: [noparse][[/noparse]basicstamps] Serial data with flow control help
> You might find column #81 from "The Nuts & Volts of BASIC Stamps" useful.
> <A
loads_V3.asp">
V3.
> asp</A>
> -- Jon Williams
> -- Parallax
> > Happy Newyear!!
> > between two BS2E's.
> > Regards,
> > Dwain.
> I will look up the nuts and volts reference, thanks for that guys.
> the
Don't you just hate it when that happens. Although, a lesson well learned.
You will likely never make that mistake again!
