New Software ???
Is there an estimated time for when the next version of the Basic Stamps
software will be available, Beta version or otherwise?
James
James
Beta versions. Trust me, you'll like the new stuff.
-- Jon Williams
-- Parallax
Key additions:
PIN type -- Allows software to adjust syntax based on requirement.
Examples:
X PIN 15
HIGH X ' X is evaluated as a 15
IF (X = 1) THEN ... ' X is evaluated as In15
X = 0 ' X is evaluated as Out15
And what we've all been wanting....
IF (condition) THEN
' statements
ELSE
' other statements
ENDIF
You can also do something like this:
IF (condition) THEN GOSUB Target
We've also added:
SELECT expression
CASE condition
' statements
TCASE condition
' statements
ENDSELECT
TCASE (Through CASE) is a PBASIC add-in, it allows a condition to be
evaluated even if the previous CASE evaluated as true (this is not normal in
BASIC; yet falling through is the default behavior in C and Java).
And, finally, GOTO can be virtually eliminated with DO-LOOP. Here's the
syntax:
DO { WHILE | UNTIL expression }
' statements
LOOP { WHILE | UNTIL expression }
Examples:
DO
' statements
LOOP
DO WHILE (x < 10) ' test before statements
' statements
LOOP
DO
' statements
LOOP UNTIL (x > 10) ' test after statements
Finally....
ON expression GOTO addr1, addr2, addr3 ...
ON expression GOSUB addr1, addr2, addr3 ...
Experienced PBASIC programmers will recognize the first statement as the
functional equivalent of BRANCH. It is; it just uses "classic" BASICA
syntax. Since we added it, the ON x GOSUB made sense and is actually quite
useful.
We've got a few other goodies in our plan, we'll let you know when we've
implemented and tested those things. What I've mention here is implemented
and working well in lots of code (I've spent a good deal of time porting
projects to the new syntax as part of our test).
In a message dated 12/30/2002 2:28:45 PM Central Standard Time,
jamesrwaldron@e... writes:
> James
count). Are there any plans for this? Would Parallax be willing to let an
outside programmer perform the work if the programmers in Parallax are too
busy? Would Parallax sue if somebody reverse engineered the Stamp Software?
(Just kidding)
Happy Holidays,
Kelley
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, December 30, 2002 3:56 PM
Subject: Re: [noparse][[/noparse]basicstamps] New Software ???
> We're targeting mid- to late-January. Testing takes time though, even for
> -- Jon Williams
> -- Parallax
> Key additions:
> Examples:
> X PIN 15
> IF (condition) THEN
> ' statements
> ELSE
> ' other statements
> ENDIF
> We've also added:
> SELECT expression
> CASE condition
> ' statements
> TCASE condition
> ' statements
> ENDSELECT
in
> syntax:
> ' statements
> Examples:
> DO
> ' statements
> LOOP
> ' statements
> LOOP
> DO
> ' statements
> Finally....
quite
> useful.
implemented
> > James
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Yes, we have already released precompiled modules for Mac and LINUX systems
and they are being used by developers to create native tools for those OSes.
And yes, we will update those modules when we finalize and release PBASIC
2.5.
No, we will not let outsiders work with our tokenizer source.
-- Jon Williams
-- Parallax
In a message dated 12/30/2002 3:04:58 PM Central Standard Time,
schnozzy@v... writes:
> Question about Stamp Software for platforms other than Windows (DOS doesn't
> (Just kidding)
> Happy Holidays,
> Kelley
' No external oscillator is required
' This uses the internal 4MHz oscillator
' No resistor from MCLR to +5V. MCLR is turned OFF
' Connections to PIC
' Pin #5 to ground
' Pin #14 to +5V
' Port pins B0, 1,2,3,4,5,6,7 will toggle from ground
' to +5V with 500 milliseconds between each toggle.
@ DEVICE INTRC_OSC, MCLR_OFF, LVP_OFF
DEFINE OSC 4
W vaR BYTE
TIME VAR BYTE
BEGIN:
for W = 0 to 7
HIGH PORTB.0[noparse][[/noparse]W]
PAUSE 500
LOW PORTB.0[noparse][[/noparse]W]
PAUSE 500
NEXT
GOTO BEGIN
END
Original Message
Sent: Monday, December 30, 2002 4:39 PM
> Yes. No.
> 2.5.
> -- Jon Williams
> -- Parallax
> > (Just kidding)
> > Happy Holidays,
> > Kelley
> from the same email address that you subscribed. Text in the Subject and Body
I just read the latest Nuts and Volts article about the new editor
features comming up.
True IF/THEN/ELSE blocks, DO UNTIL/LOOPS, SELECT/CASE, ON GOSUBS, etc
Awsome!
I come from strong programming background, and this will make the Stamp fun
again!
Keep up the great job guys!
Original Message
To: basicstamps@yahoogroups.com <basicstamps@yahoogroups.com>
Date: Monday, December 30, 2002 2:56 PM
>-- Jon Williams
>-- Parallax
>Key additions:
>Examples:
> X PIN 15
> IF (condition) THEN
> ' statements
> ELSE
> ' other statements
> ENDIF
>We've also added:
> SELECT expression
> CASE condition
> ' statements
> TCASE condition
> ' statements
> ENDSELECT
in
>syntax:
> ' statements
>Examples:
> DO
> ' statements
> LOOP
> ' statements
> LOOP
> DO
> ' statements
>Finally....
>useful.
>> James
"Yes" about 0.001 milliseconds after Parallax offered me a job. All kidding
aside, it is a bit easier to program BASIC Stamps now, especially if you come
from PC BASICs or languages like Pascal, C or Java.
-- Jon Williams
-- Applications Engineer, Parallax
In a message dated 1/2/2003 1:34:34 PM Central Standard Time, wb@i...
writes:
> Jon,
> Awsome!
> again!
