Multiple relays
Hi All,
I am trying to select multiple relays via a 4x4 matrix keypad. I can
achieve this by writing lots of subroutines for each realy. (READ
KEYPRSS, OUTPUT TO RELAY, VIEW RELAY STATUS, AND TOGGLE RELAY.
However, to write code for 24 relays fills all the available memory
space, and then some.
Is it possible to convert a key press into a variable "value" and
refer back to this "value" throughout the code. i.e. Read
the "value" corresponding to the key press, output that "value",
dispaly and toggle that "value"? This should reduce the code size
significantly.
If I assign a number to the the output. i.e OUTPUT 2, OUT2=1, TOGGLE
2, this works fine.
However, the following code does not work as I have
subsituted "value" for a number. How can this be achieved?
'{$STAMP BS2p}
'{$PORT COM1}
dirs=%1111111111111111 '0=input >> 1=output
bps con 240 '9600 Baudrate
dly con 10 'Global pause delay..
auxio 'use aux i/o
Rx con 13 'Serin (receive) pin 13
Value VAR BYTE
statusIN var byte 'staus on output pin
index var byte
pause 500
gosub reset 'reset lcd
loop:
auxio
serin Rx,bps,[noparse][[/noparse]w2]
if w2=8 then reset 'goto reset LCD
if w2=13 then tgl 'goto toggle
value = w2
index = 1
PUT Index, value
relay: 'store value of w2
GET index, value
debug dec value - 48,cr 'show key pressed
mainio
output(value)
out(value)=1
statusIN=in(value) 'read & display staus of relay
if IN(value)=0 then displayO
if IN2=1 then displayC
goto loop2
tgl: 'toggle
mainio
toggle (value)
if in(value)=0 then displayO
if in(value)=1 then displayC
goto loop
displayC:
gosub secline
serout 0,bps,[noparse][[/noparse]"RELAY ",(value), "CLOSED"]
goto loop
displayO:
gosub secline
serout 0,bps,[noparse][[/noparse]"RELAY ",(value), "OPEN "]
goto loop
secline:
pause dly
serout 0,bps,[noparse][[/noparse]254,192]
pause dly
return
reset:
mainio
serout 0,bps,[noparse][[/noparse]254,1]
pause dly
serout 0,bps,[noparse][[/noparse]"READY"]
pause 20
return
Any thoughts would be appreciated.
Ken
significantly.
2, this works fine.
'{$STAMP BS2p}
'{$PORT COM1}
auxio 'use aux i/o
Value VAR BYTE
index var byte
pause 500
loop:
auxio
value = w2
index = 1
PUT Index, value
GET index, value
mainio
output(value)
out(value)=1
goto loop2
tgl: 'toggle
mainio
toggle (value)
goto loop
displayC:
gosub secline
goto loop
displayO:
gosub secline
goto loop
secline:
pause dly
pause dly
return
reset:
mainio
pause dly
pause 20
return
Ken
As Peter noted, it's asking for trouble to use the pre-defined
variables in conjuction with others you declare yourself.
You can refer to the nth IN or OUT as an array element by
using the syntax IN0(n) or OUT0(n). For instance:
statusIN=in0(value) 'read & display staus of relay
out0(value)=1
Other things:
- debug dec value - 48,cr 'show key pressed
This suggests to me that the value you are receiving is an ASCII
numeric representation. If that's the case, I'd suggest you convert
to a numeric value right after the SERIN to simplify things.
Statements such as:
output(value)
won't work right unless the variable "value" holds the intended
numeric quantity as opposed to an ASCII representation.
- Be careful you don't exceed your Stamp's max current capacity by
turning on too many relays with successive actions.
- You can tighten your code up a bit by realizing that an input pin
will either read as 0 or 1. If it's not 0 then it must be 1. No
point testing for both states on successive IFs. You might also
choose to display common display elements like "RELAY " or
[noparse][[/noparse]DEC value] before the IF statement so you don't have to duplicate
them in either case.
Steve
Rename w2 to something else.
w0-w12 and b0-b25 are reserved names for fixed ram addresses.
Now w2 is being overwritten by declared variables.
Regards peter
Oorspronkelijk bericht
Van: digdul2002 <jduldig@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AnHfTlzq0DlRSykShgF9WpDo0wa_LLegjqtgwKV4edm2JnNjmdDo8BojS6hTlZ1cUO5U7cVHloPwPw]jduldig@s...[/url
Verzonden: vrijdag 27 december 2002 21:44
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Multiple relays
Hi All,
significantly.
2, this works fine.
'{$STAMP BS2p}
'{$PORT COM1}
auxio 'use aux i/o
Value VAR BYTE
index var byte
pause 500
loop:
auxio
value = w2
index = 1
PUT Index, value
GET index, value
mainio
output(value)
out(value)=1
goto loop2
tgl: 'toggle
mainio
toggle (value)
goto loop
displayC:
gosub secline
goto loop
displayO:
gosub secline
goto loop
secline:
pause dly
pause dly
return
reset:
mainio
pause dly
pause 20
return
Ken
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
The line
if w2=9 then reset
inside loop is a goto reset instead of a gosub reset
When you use serin ,,[noparse][[/noparse]w2]
You test for 8 (backspace) and 13 (entet), is that what you want?
w2 is a word variable.
I suggest to use serin ,,[noparse][[/noparse]dec inputvalue]
where inputvalue is a bytevariable.
Regards peter
Van: digdul2002 <jduldig@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=You-XFmNg46d1yGgNKhJYCR7V56g5jCJKEgM0o7avYuWzcjq6GSROOl4t64ypdaParcAO7WPkaSbbg]jduldig@s...[/url
Hi All,
significantly.
2, this works fine.
'{$STAMP BS2p}
'{$PORT COM1}
auxio 'use aux i/o
Value VAR BYTE
index var byte
pause 500
loop:
auxio
value = w2
index = 1
PUT Index, value
GET index, value
mainio
output(value)
out(value)=1
goto loop2
tgl: 'toggle
mainio
toggle (value)
goto loop
displayC:
gosub secline
goto loop
displayO:
gosub secline
goto loop
secline:
pause dly
pause dly
return
reset:
mainio
pause dly
pause 20
return
Ken
Hi Peter,
I have tried to follow your comments, however I am struggling to make
sense of what is happening.
Does the following code look reasonable?
I have exchanged (w2) for (value). Something odd has occurred with
the "carraige return" and "backspace" keys as they now return very
large numbers. This wasn't the case when I used w2. Returned values 8
and 13.
I can't seem to get the toggle function to work either.
I would appreciate your comments - or anyone elses.
Regards
ken.
CODE SO FAR
'{$STAMP BS2p}
'{$PORT COM1}
dly con 10
auxio 'Global pause delay..
va var in12 'valid key press
Value VAR BYTE(10)
status var byte 'staus on output pin
pause 50
HIGH 11 'Set the pin high (Power LED on).
goto reset 'reset lcd
loop2:
auxio
if va=1 then loop2 'loop until valid data
if va=0 then loop
loop:
auxio
serin Rx,bps,[noparse][[/noparse]value] 'key in info
pause 100
debug value,cr '
if value = 13 then tgl 'goto toggle
if value = 8 then reset 'goto reset
mainio
dirs(value)=0
output(value)
tgl: 'toggle output
mainio
toggle (value)
if out0(value)=0 then displayo 'display output
if out0(value)=1 then displayc
goto readkey
displayC:
gosub secline
serout 0,bps,[noparse][[/noparse]"RLY ", (value), " CLOSED"]
pause dly
goto readkey
displayO:
gosub secline
serout 0,bps,[noparse][[/noparse]"RLY ", (value), " OPEN "]
pause dly
goto readkey
readkey:
auxio
if value=13 then tgl
if value=8 then reset
debug value
goto loop
secline:
pause dly
mainio
pause dly
return
reset:
mainio
pause dly
pause dly
goto loop
> Ken-
> or
> out0(value)=1
> Other things:
convert
> Statements such as:
> output(value)
> Regards,
> Steve
