i2c probs
Hi BS2p fans.
I am hoping for some assistance in getting my bs2p to talk to a
series of 8574A I2C chips I have connected. I have checked all
connections and they look OK. I just can not seem to communicate with
the devices.
I have connected SDA to AUXIO p15 and SCA to AUXIO p14. (Im am using
a BS2P/40.
I have connected pins 1,2 and 3 of the first 8574A to ground. I
assume this is address 0. The remaining two chips have individual
addresses.
I would like to read and display the status of inputs on each of the
three 8574A ICs.
Can anyone help with some simple code?
Are there any reference sites you can direct me to for examples of
I2C code for the BSP2/40?
I have reviewed the publication on Nuts and Volts (vol 3) re
expanding I/O. This is exactly what I want to achieve, however I can
not get the code to work.
I suspect the prob is in the I/O definitions , Device Address or
I2CPIN area. Is my problem to do with using AUXIO p15 and 14?
The N&V example use only pin p0. Not sure how that works with SDA and
SCL?
I would appreciate any advise.
Ken
the devices.
a BS2P/40.
addresses.
three 8574A ICs.
SCL?
Ken
Much appreciated.
So it sounds like ONLY P0 and P1 or AUXIO P0/P1 can be used for I2c.
No other pins can be setup to work?
Thanks.
Ken
--- In basicstamps@yahoogroups.com, "peter verkaik"
<peterverkaik@b...> wrote:
> Hi Ken,
> The bs2p has builtin commands I2CIN and I2COUT but these operate on
either
> P0=SDA and P1=SCL or P8=SDA and P9=SCL. Other pins are not supported
> by the I2C commands. Also don't forget to use the AUXIO command if
you use
> the
> auxiliary P0/P1 or P8/P9. The manual has several examples using
I2CIN and
> I2COUT.
> I hope this resolves your problem.
> Regards peter
Oorspronkelijk bericht
> Van: digdul2002 <jduldig@s...> [noparse][[/noparse]mailto:jduldig@s...]
> Verzonden: woensdag 25 december 2002 16:38
> Aan: basicstamps@yahoogroups.com
> Onderwerp: [noparse][[/noparse]basicstamps] i2c probs
> Hi BS2p fans.
with
> the devices.
> a BS2P/40.
> addresses.
> three 8574A ICs.
and
> SCL?
> Thanks
> Ken
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
Subject and
> Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
I have changed the SDA pin to AUXIO8 and SLC to AUXIO9.
What is the based ID $70. Where do I insert that into my code?
' {$STAMP BS2p}
'{$PORT COM1}
auxio
I2Cpin CON 8
result var byte
Loop
I2CIN I2Cpin,???,???, [noparse][[/noparse]result]
DEBUG "Bits=... ", (", bin result ")
Pause 2000
Goto loop
What do I insert for ???
Should this not display a 0 or 1 depending on the input state.
Any suggestions?
Ken
> Ken,
> You can use P0/P1, P8/P9, aux P0/P1 and aux P8/P9 with the builtin
i2c
> commands.
> Other pins can be used but then you must program the I2C routines
yourself,
> as you must when using the stamp 2, 2se or 2sx. The stamp 2p has
builtin
> commands
> for i2c and therefore preferable. Btw, did you use the correct base
id for
> the PCF8574A?
> The PCF8574 has base id $40, the PCF8574A has base id $70.
> Regards peter
> Verzonden: woensdag 25 december 2002 18:22
> Onderwerp: [noparse][[/noparse]basicstamps] Re: i2c probs
> Thanks Peter,
> Much appreciated.
> Thanks.
> Ken
> > Hi Ken,
on
> either
supported
> you use
> > the
> I2CIN and
> > I2COUT.
> > Regards peter
> > Hi BS2p fans.
> with
> > the devices.
using
> > a BS2P/40.
> > addresses.
the
> > three 8574A ICs.
can
> and
> > SCL?
> > Thanks
> > Ken
> Subject and
Subject and
The bs2p has builtin commands I2CIN and I2COUT but these operate on either
by the I2C commands. Also don't forget to use the AUXIO command if you use
the
auxiliary P0/P1 or P8/P9. The manual has several examples using I2CIN and
I2COUT.
Regards peter
Van: digdul2002 <jduldig@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XfmeZxlW4lo63VicvypiMDB8NO9g-en-9dNLSQjcC7fSrNxS4YQUmEvSWmMsCQX9sTK5B0x1tJJ9zw]jduldig@s...[/url
Hi BS2p fans.
the devices.
a BS2P/40.
addresses.
three 8574A ICs.
SCL?
Ken
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
You can use P0/P1, P8/P9, aux P0/P1 and aux P8/P9 with the builtin i2c
commands.
Other pins can be used but then you must program the I2C routines yourself,
as you must when using the stamp 2, 2se or 2sx. The stamp 2p has builtin
commands
for i2c and therefore preferable. Btw, did you use the correct base id for
the PCF8574A?
Regards peter
Van: digdul2002 <jduldig@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mt9RcnO2GyYXBJVnUOJTvtLWlcJnFgldk0BodHhKwLs6mxf5HojurdlPqUBgl0CcIMOpr-bNt3JSVk4Ztfc]jduldig@s...[/url
Thanks Peter,
Much appreciated.
Thanks.
Ken
> Hi Ken,
either
you use
> the
I2CIN and
> I2COUT.
> Regards peter
> Hi BS2p fans.
with
> the devices.
> a BS2P/40.
> addresses.
> three 8574A ICs.
and
> SCL?
> Thanks
> Ken
Subject and
The id for a i2c device is made of a fixed part (the base id), an address
part that correspond to
the address pins on the device (pins 1-3 for the PCF8574A) and a read/write
bit. The R/W bit
Is 0 for a writecommand and 1 for a readcommand.
Id = baseid + (a2a1a0<<1) + RW
For the PCF8574A with all address pins grounded:
Id = $70 + (0<<1) + 0 = $70 'write command
Id = $70 + (0<<1) + 1 = $71 'read command
The I2C commands for the PCF8574A are
I2CIN pin,id,[noparse][[/noparse]inputdata]
I2COUT pin,id,[noparse][[/noparse]outputdata],
where pin is 0 for i2c bus at P0/P1 or 8 for i2c bus at P8/P9
To read a value from your PCF8574A at i2cbus P0/P1 into a bytevariable
pcfread:
I2CIN :0,$71,[noparse][[/noparse]pcfread]
To write a value to your PCF8574A at i2cbus aux P8/P9::
AUXIO
I2COUT :8,$70,[noparse][[/noparse]$AA] 'outputs the value $AA (10101010 binary)
The first ??? in your code is for the calculared id
The second ??? is for an internal address. Eeproms do have internal
addresses,
the PCF8574A does not so you can leave it out.
I hope this makes it clear to you.
Regards peter
Van: digdul2002 <jduldig@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=y5AT6RImmahkdIa-46h1QbpKHSO1aUjAI3zcZlEY3A_2WvtdUmVwumA8Gfkk7w2--TeGiAb_7Nrlr6A7]jduldig@s...[/url
Verzonden: woensdag 25 december 2002 21:38
Thanks Peter,
' {$STAMP BS2p}
'{$PORT COM1}
auxio
I2Cpin CON 8
result var byte
Loop
Pause 2000
Goto loop
Any suggestions?
Ken
> Ken,
i2c
> commands.
yourself,
builtin
> commands
id for
> the PCF8574A?
> Regards peter
> Thanks Peter,
> Much appreciated.
> Thanks.
> Ken
> > Hi Ken,
on
> either
supported
> you use
> > the
> I2CIN and
> > I2COUT.
> > Regards peter
> > Hi BS2p fans.
> with
> > the devices.
using
> > a BS2P/40.
> > addresses.
the
> > three 8574A ICs.
can
> and
> > SCL?
> > Thanks
> > Ken
> Subject and
Subject and
The : in the I2C commands is obviously a typo error.
Just remove it.
Your debug statement should be
debug "bits...", bin result,cr 'cr gives a carriage return
Regards peter
Van: digdul2002 <jduldig@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xSC7ZaCkSiv3o6I65XbikAObBBEECs07AthsstUou2F3w1-BNzzyca4LF9AVoIGKOHnMCuduLrI1AQ]jduldig@s...[/url
Thanks Peter,
' {$STAMP BS2p}
'{$PORT COM1}
auxio
I2Cpin CON 8
result var byte
Loop
Pause 2000
Goto loop
Any suggestions?
Ken
> Ken,
i2c
> commands.
yourself,
builtin
> commands
id for
> the PCF8574A?
> Regards peter
> Thanks Peter,
> Much appreciated.
> Thanks.
> Ken
> > Hi Ken,
on
> either
supported
> you use
> > the
> I2CIN and
> > I2COUT.
> > Regards peter
> > Hi BS2p fans.
> with
> > the devices.
using
> > a BS2P/40.
> > addresses.
the
> > three 8574A ICs.
can
> and
> > SCL?
> > Thanks
> > Ken
> Subject and
Subject and
Thanks for your assistance re my I2C prob. All is fine now. The two issues
were with the dedicated pins on the BS2P 40 and the base ID of the 8574A.
Both of these items I was unaware of. (particularly the based ID)
Sorry to bother you. This will be the last time. Have you any ideas how I
can reference the incoming DEC iobyte from the I2C chip, to particular
output. Such as:
(this argument does not work by the way) "if dec iobyte = 254 then output
1" (assuming output 1 is a subroutine that turns on relay 1 connected to the
BS2). For some reason the "if then" statement doesn't like "dec" or "bin".
Do I need to use a Lookup table of the various dec values which relate to
each input from the I2C chip?
I will understand if you choose not to reply. Thanks for your help so far.
I appreciate it.
Ken.
Original Message
From: peter verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wO9yNq-BGd9v0i64xemiS5OU_vcOwUhPTWvv9Zx6WYBPmflUiVE-EUAjINvIOtD4zUP9pWR0cx52iJTa-88AYdOqhA]peterverkaik@b...[/url
Sent: Friday, 27 December 2002 3:43 AM
To: basicstamps@yahoogroups.com
Subject: RE: [noparse][[/noparse]basicstamps] Re: i2c probs
Ken,
Just remove it.
Regards peter
Van: digdul2002 <jduldig@s...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yf_ALeMtsCFE77WQ8VWPEHGGFYIqCft0-Ods12bQYsEFSs3PWyTMvpbgfpmwrwdwlRhY-ahJr27ni7crFg]jduldig@s...[/url
Thanks Peter,
' {$STAMP BS2p}
'{$PORT COM1}
auxio
I2Cpin CON 8
result var byte
Loop
Pause 2000
Goto loop
Any suggestions?
Ken
> Ken,
i2c
> commands.
yourself,
builtin
> commands
id for
> the PCF8574A?
> Regards peter
> Thanks Peter,
> Much appreciated.
> Thanks.
> Ken
> > Hi Ken,
on
> either
supported
> you use
> > the
> I2CIN and
> > I2COUT.
> > Regards peter
> > Hi BS2p fans.
> with
> > the devices.
using
> > a BS2P/40.
> > addresses.
the
> > three 8574A ICs.
can
> and
> > SCL?
> > Thanks
> > Ken
> Subject and
Subject and
specify the DEC formatter. This is only needed when you are converting
numbers for serial output (SEROUT, DEBUG, etc.) where their ASCII
representations are desired.
Just do this:
IF (ioByte = 254) THEN Relay_1_On
Remember that in this version of PBASIC (2.0), IF-THEN jumps to the target
address when the condition is true. In about a month we'll release version
2.5 of the language that will let you use IF-THEN-ELSE and SELECT-CASE (which
may be useful for your application).
-- Jon Williams
-- Parallax
In a message dated 12/26/2002 11:23:19 PM Central Standard Time,
jduldig@s... writes:
> the
