update DATA in BS2e
Hello, after searching for this and finding no info... I am asking if
anyone has implemented a method of changing stored DATA?
I have built a BS2e controlled speakerphone that a partially paralyzed
person is using to talk to the outside world. However, when he needs
his phone list updated, I have to reprogram it for him.
Is there any way to allow him to update those DATA numbers (& names)?
He uses a 'puff' switch to select from menues, one allows him to
generate and store one phone number (no text). If there is some way to
allow it to append to or replace selected names and numbers, that
would make him more independent.
Don Jones
Don Jones
download time, so that can be changed on-the-fly by the program.
You'd have to develop a mechanism for changing the data based on your
friend's input device, but it can certainly be done.
-- Jon Williams
-- Parallax
In a message dated 12/21/2002 7:05:16 PM Central Standard Time,
djones@5... writes:
> Thanks,
> Don Jones
I'll have to try some simple stuff first, then integrate into my
selection/replacement program.
I am using different program sections for Home, Work, Cell, and Pager
numbers... so there will be additional issues there.
Don
p.s. I posted earlier about a different wacky problem and got no
reply. Maybe you could search for 'wacky' and set me straight there
also. I was trying to add X-10 control using the Firecracker onto this
phone... got it working, but then it blew away the displayed phone
number when I returned with Run 0.
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> You can do it with WRITE. DATA statements are written to the Stamp
EEPROM at
your
> -- Jon Williams
> -- Parallax
> djones@5... writes:
asking if
paralyzed
needs
names)?
way to
> > Thanks,
> > Don Jones
