number to bcd
Got to be an easier way. I want to turn a variable number into a BCD number
for seven segment displays. I'm not using the decoder chip. What
suggestions can you guys offer to get a number 0-9999 into a 4 byte string.
Currently I start by dividing by 1000 to get first digit, then divide the
remainder by 100 to get the second digit etc.
I this what the DIG modifier is for?
Original Message
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gW3kKVCwN53o_xrbl5YeK09H5GPAgvYzTettC7SXO4fz8KTdEsBEAFxQ8bmK10UsSsdbL7pG4IUpopc]tracy@e...[/url
Sent: Friday, December 20, 2002 1:11 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Noise on data lines...
Hi Chris,
Shield the cable. Near the Stamp, run it through an RFI bead (the
fat thing you often see on cables).
-- Tracy
>Hello all,
>I have a stamp connected to a radio frequency tag system. The serial data
>line between the RF unit and the stamp pcb has a lot of noise on it coming
>from the rf unit. Does anybody have any ideas on an effective way to remove
>the noise from the serial data line ?, or any links to sites with info on
>this ?
>Thanks
>Chris (Western Australia)
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Original Message
Hi Chris,
-- Tracy
>Hello all,
>this ?
>Thanks
machining parts.
Sorry, I'm making an rpm gauge for my lathe and mill.
It's not rally a stamp question cause I'm gonna make the final design using
a pic, but Pic Basic Pro is almost Stamp.
What I want to do it take the RPM counts input and convert that to a BCD
string to display on 7-segs. SO I need it in bcd byte format. All serial
output routines convert it for you using the "Dec" modifier but I need to
use the bytes elsewhere in the program.
Original Message
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N1Zbf0R30hVMhJnEjqosP_sMrTwg5_hizyhFcMNhDfxueDeF6zF3DvJGqPgx27iL2xTzS8OBzySo]Newzed@a...[/url
Sent: Friday, December 20, 2002 2:18 PM
Subject: Re: [noparse][[/noparse]basicstamps] number to bcd
In a message dated 12/20/2002 14:06:38 Eastern Standard Time,
porter.sadler@s... writes:
number
string.
Just go to Calculator - Scientific. Enter the decimal number then click on
"bin".
Sid Weaver
W4EKQ
Port Richey, FL
"bin".
Sid Weaver
W4EKQ
Port Richey, FL
dig3 = myValue DIG 3 ' thousands
dig2 = myValue DIG 2 ' hundreds
dig1 = myValue DIG 1 ' tens
dig0 = myValue DIG 0 ' ones
-- Jon Williams
-- Parallax
In a message dated 12/20/2002 1:06:37 PM Central Standard Time,
is mechanically limited to 10 positions. (0 thru 9). I have the 2 BCD
digits feeding a parallel to serial chip converting them into a 8 bit
variable called BCD for example. Simply break out the high nib and low nib
of BCD. For example the two switches are set to 6 4:
BCD variable gets set to the following, (binary), 01100100. The upper
nib is 0110 (6 dec) and the lower is 0100 (dec 4). From here you can do
what ever you want with the values..
Mike B.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, December 20, 2002 10:48 AM
Subject: [noparse][[/noparse]basicstamps] number to bcd
number
string.
Original Message
> From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6bK73dVOB-Lo5kNaXryug8mVnqP6BaXXNqy-kqob6QivFmbcXS-Rr7ad2O1k7KCjGEVNo1WPiKAxYyCbT5M]tracy@e...[/url
> Hi Chris,
> -- Tracy
> >Hello all,
coming
remove
> >this ?
> >Thanks
Looks like my documentation may be old. Where can I find more information on
the DIG command?
each digit into individual variables. I then used:
var1 * 10 + var2 * 10 + var3 * 10 + var4 = newVar 'to get it all
in one variable.
I guess that only uses two lines of code? I was reading in a 4 digit
number and outputting it to a lcd and led display converting it to xx.xx
format.
Great suggestion but then I would spend all my time at the calculator not
machining parts.
binary operators. You can download the latest manual -- free -- from our web
site. If you want a printed version, they're currently on sale. Don't delay
though, sales don't last forever.
-- Jon Williams
-- Parallax
In a message dated 12/20/2002 1:48:05 PM Central Standard Time,
smartdim@a... writes:
> This dig command, is that using a BS2, or what devices?
> on
> the DIG command?
wiring or a PCB, just get a LCD screen. Can get a 2 line x 24 char
for $10. The serial LCDs would be even easier, but at $40 it gets
pricey.
I'm woirking on a DRO (with LCD) for my mill from a hacked digital
caliper.(lathe really doesn't need one for my uses) Though its done
with a 'normal' PIC since I need SPI and to custom configure the SPI.
--- In basicstamps@yahoogroups.com, Sadler Porter
calculator not
> machining parts.
design using
a BCD
serial
need to
Original Message
> From: Newzed@a... [noparse][[/noparse]mailto:Newzed@a...]
BCD
> number
byte
> string.
divide the
click on
> "bin".
> Sid Weaver
> W4EKQ
> Port Richey, FL
Subject and
http://www.eio.com/lcdprodt.htm
Larry
At 02:12 PM 12/21/2002 +0000, you wrote:
>Just for RPM? LED? Don't bother, its gling to be a lot of parts and
>pricey.
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
