Stamp software and windows 2000
The Stamp software doesn't get along with Windows 2000.
How can this be fixed? It will detect the Stamp2SX, and upload the
program to it, but you must disconnect the cable before the
program will run on the stamp. Then if you re-connect the stamp, it
stops the stamp program. It will still accept uploads to it though.
Doug Simpson
Doug Simpson
veewee77@a...
Doug Simpson
Doug Simpson
veewee77@a...
weekend for a course we determined the problem was actually an
inadequacy in the laptop's serial port. (Same O/S, W2K.) At the time
they didn't have a fix they could work from their side; they suggested
using a USB to Serial converter, but I forgot to write down which one.
Note that my BS2 will run while attached to the serial cable / laptop if
I have debug statements in the program, and won't if I don't. Crazy,
huh?
Given that I'm nearly a complete novice, I hope an expert chimes in
here.
HTH -
Chris
> Doug Simpson
> Doug Simpson
> veewee77@a...
power saving?) causing resets.
I found a Keyspan model 19 serial to USB works, the Belkin unit wouldn't.
> I see the same behavior with a BS2 but when I was out at Parallax last
> if I have debug statements in the program, and won't if I don't.
> Crazy, huh?
Chris
> On my W2K/Tecra it was pulsing the RS232 drivers on/off while
> idle(some type of
> unit wouldn't.
and adding a Debug statement fixed it.
