--- In basicstamps@yahoogroups.com, "John Schwab
<johnschwab5678@y...>" <johnschwab5678@y...> wrote:
> Can anybody tell me how to setup a current (0-125ma) measuring
> system with a Stamp2? Thanks.
Use a current transformer.
Jameco, less than $1.00 output changes as the flux field around the
wire changes. very simple. or if you want even cheaper, wrap a few
dozen loops around your wire, and measure the induced signal !
Dave
--- In basicstamps@yahoogroups.com, "Martin Hebel <martin@s...>"
<martin@s...> wrote:
> Yes, convert it to a voltage! [noparse]:)[/noparse]
> Take the 125mA and pass it through a resistor. V=IR
> If you use a 33 Ohm, this will give approximatly 0-4.125V, which
you
> can use an A/D to measure.
> -Martin Hebel
> Electronic Systems Technologies
> Southern Illinois University
> http://www.siu.edu/~imsasa/est
Current transformers measure an AC signal, since that is what causes
the induced current into the sensor. A DC one is usually a linear
hall effect device.
Though the original post did not specify, I am assuming this is a DC
level from some type of sensor?
-Martin
--- In basicstamps@yahoogroups.com, "Dave Mucha <davemucha@j...>"
few
> Dave
> you
> > -Martin Hebel
If it is a DC signal, then the resistor/ADC is the way to go.
causes
> hall effect device.
DC
> -Martin
the
> few
> > Dave
which
> > you
> > > -Martin Hebel
measuring
What about a 25 Ohm resistor in series with what you want to measure
and then just use an ADC to pick off the voltage across the resistor?
An 8-Bit ADC would give you approx 488uA resolution. A 12-Bit ADC
would give you approx 30uA resolution, but it might be difficult
distinguishing this against the noise floor.
Ahem!.. or better yet a 40 Ohm resistor... Sorry!
John,
If you're wanting to measure AC then the CT (current transformer)
would be ideal, as the other guys on this list already mentioned.
If you're measuring DC then you can use the series resistor like a
few of the other guys talked about. However, seems like you need to
take a look at the load your driving before arbitrarily picking some
resistor value out of the air like 33 ohms, or 40 ohms or whatever.
If you add a series resistor to the circuit, the total resistance
will go up making the current go down. You'll also be dropping some
of your voltage across the resistor and you will have less voltage
across the load.
Say your load is 50 ohms and you have a 12V power supply connected to
it. Your total current will be .24A. Now you start adding a 33 ohm
resistor in series, your total current drops to .144A. You'll then
only have 7.2V across your original load. Depending on the nature of
the load this may not be acceptable.
Here is exactly what I am trying to do: I have a device that
controls a light output. It outputs 12 Volts DC and varies the
current between 0-125ma. What I want to do is test the current
without any lights (so no load) hooked up to test if it is outputting
very little, some medium amount of current, or something close to
maximum (125ma) current. I need to make a harness to test this
circuit, and I already have a Stamp2BSX in the system, so I am hoping
to use it to check this too.
/John
--- In basicstamps@yahoogroups.com, "Ron Jeremy <ronjeremy912@h...>"
> John,
to
some
whatever.
some
> across the load.
to
ohm
of
> Hope this helps
You should probably load your circuit so you know it really can
output the 12 volts and 125 ma. 96 ohms (=12V/0.125A) is the right
load for that. If you split the load into 2 resistors, 56 ohms
between the sense point and the 12v input and then 40 ohms between
sense point and ground, the sense point will go from 0 to 5 volts as
the load current goes from 0 to 125 ma. (Likewise the input voltage
will go from 0 to 12 volts at the same time because of the 96 ohm
total load). The 0-5 volt sense point voltage can be measured many
ways depending on the accuracy you need. An A/D gives best accuracy
but there may be a circuit somewhere to measure that voltage range
using RCTIME and another resistor or two and a capacitor.
Harry
Stamp Robotics to the next level
www.bluebelldesign.com
outputting
hoping
> /John
> > John,
mentioned.
a
> to
> some
> whatever.
> some
voltage
> > across the load.
connected
> to
> ohm
then
nature
> of
> > Hope this helps
If you use a 33 Ohm, this will give approximatly 0-4.125V, which you
-Martin Hebel
Dave
you
> -Martin Hebel
hall effect device.
-Martin
few
> Dave
> you
> > -Martin Hebel
causes
> hall effect device.
DC
> -Martin
the
> few
> > Dave
which
> > you
> > > -Martin Hebel
measuring
John,
across the load.
Hope this helps
/John
> John,
to
some
whatever.
some
> across the load.
to
ohm
of
> Hope this helps
Harry
outputting
hoping
> /John
> > John,
mentioned.
a
> to
> some
> whatever.
> some
voltage
> > across the load.
connected
> to
> ohm
then
nature
> of
> > Hope this helps
