Stamp Interface with external eeprom
I am going crazy tring to figure out how to get my BS2SX to
interface with a microchip 24LC64 EEPROM. I found the following
code for the 24LC32 (which is the same only 32K less) however when I
download the program and run it, it seems to get caught in an
infinite loop because of the statment ' if ack=1 then agn ' can
someone please help me out with this. Possibly an incorrect wiring
job on my part?? I dont know?!? Please Help! Thanks :-)
I
wiring
oops forgot to add the code! Duh!
'{$STAMP BS2sx}
' 24LC32.BS2
' Illustrates how to write and read to and from 24LC32 32K EEPROM
' BS2 24LC32
' Pin5 (term 10)
SCL (term 6)
To Other
' Pin4 (term 9)
SDA (term 5)
24LC32
Devices
' Note that 10K pullup resistors to +5VDC are required on both signal
'leads.
' Note that the slave address is determined by A2 (term 3), A1
(term2)
' and A0 (term 1) on 24LC32. The above SCL and SDA leads may be
multipled
' to eight devices, each strapped for a unique A2 A1 A0 setting.
' Debug and Pause statements were included only to see what is going
on.
address var word ' 000 0000 00000 - 111 1111 1111
device var byte ' device 0-7
dta var byte ' data to program
o_byte var byte ' byte to send to memory
i_byte var byte ' byte fetched from memory
n var byte ' index
b var bit ' bit
ack_bit var bit
SDA_PIN con 4
SCL_PIN con 5
SDA_OUT var out4
SCL_OUT var out5
SDA_IN var in4
SDA_DIR var dir4
OUT con 1
IN con 0
dirs=$f0ff
main
address=$341 ' program data 55 into address $341
device=0
dta=$55
gosub write_random_data 'write dta to address $341
gosub read_random_data 'read from same location
debug hex i_byte
stop
write_random_data 'writes specified data to specified address
agn
gosub start
o_byte=$a0 | (device << 1) ' 1 0 1 0 a2 a1 a0 0
gosub out_byte
gosub nack
o_byte= address >> 8 ' high byte of address
gosub out_byte
gosub nack
o_byte= address & $ff ' low byte of address
gosub out_byte
gosub nack
o_byte= dta ' data
gosub out_byte
gosub nack
gosub sstop
gosub ack ' ack polling
if ack_bit=1 then agn
return
read_random_data ' reads data from specified address
' returns in variable in_byte
gosub start
gosub out_byte
gosub nack
gosub out_byte
gosub nack
gosub out_byte
gosub nack
gosub start
o_byte=$a0 | (device << 1) | $01' 1010 a2 a1 a0 1
gosub out_byte
gosub nack
gosub get_byte
gosub nack
gosub sstop
return
out_byte
low SDA_PIN
for n=0 to 7
b= (o_byte >> 7) & 1
if (b=1) then out_one
SDA_DIR=OUT
debug "0"
_clk
high SCL_PIN
pause 100
low SCL_PIN
pause 100
o_byte=o_byte << 1
next
SDA_DIR=IN
return
out_one
SDA_DIR=IN
debug "I"
goto _clk
get_byte
SDA_DIR=IN 'input
i_byte=0
for n=0 to 7
pause 200
high SCL_PIN
pause 200
i_byte=(i_byte << 1) | SDA_IN
debug dec SDA_IN
low SCL_PIN
next
SDA_DIR=OUT 'output
return
nack
SDA_DIR=IN ' input just in case
ack_bit=1
high SCL_PIN
ack_bit=SDA_IN
debug "A"
debug dec ack_bit
debug $0d
low SCL_PIN
SDA_DIR=OUT ' output
return
ack
debug "POLL"
gosub start
gosub out_byte
gosub nack
return
start
high SDA_PIN
high SCL_PIN
debug "START"
debug $0d
low SDA_PIN 'bring SDA low while clock is high
low SCL_PIN
return
sstop
low SDA_PIN
high SCL_PIN
pause 10
high SDA_PIN 'bring SDA high while clock is high
debug "STOP"
debug $0d
return
I
wiring
Hey I dont know if anybody is interested but I found the information
to get the eeprom to work. Here is the website which explains the
process really well. Anywho... Happy Stamping!
http://www.gorobotics.net/i2ceeprom.shtml
>I
>wiring
You may want to check with Prof. Peter Anderson since he's the one who holds
the copyright on the program. I suspect he'd appreciate having the copyright
notice replaced in the program: http://www.phanderson.com/stamp/i2c/24lc32.html
Bruce Bates
"I2C Fun For Everyone." You can download the column in PDF form from:
http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads_V3
.asp
There's probably something in the article and code examples that will help
you out.
-- Jon Williams
-- Parallax
In a message dated 12/2/02 4:47:53 PM Central Standard Time,
schuler_jason@h... writes:
