PINS?
Hello,
I am using my stamp works kit to run various IC's, control a
stepper motor, and run an LCD. At the moment i am using all of the
available stamp pins (P0 - P15). If i wanted to would i be able to
connect two different components to the same stamp pin. Or would i
have to get a special chip that would provide high-z outputs or some
type of hardware that would allow me to safely have multiple
connections to one pin.
thank you,
Anthony
thank you,
Anthony
to separate them and that kind of depends on what you are actually
doing. For example, if you just need a bunch of inputs, you can use a
shift register or the "resistor keyboard" trick that is in the Stamp
manual.
For a general purpose solution, have a look at
http://www.al-williams.com/pak3.htm. Also, many of our other
coprocessors have "spare" I/O pins on them.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
Original Message
> From: engrmaps [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nLtNycBHQ9UMABbqWG1r7zM95uA7ygmID57vywjasmo6WjloAnf_e3v1bbD4MkwAvL4j_hF8435J]engrmaps@y...[/url
> Sent: Monday, November 25, 2002 12:06 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]JUNK] [noparse][[/noparse]basicstamps] PINS?
> Hello,
> thank you,
> Anthony
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
(74HC595) for SPI or I/O expanders for I2C (PCF8574). Either chip for
reducing the pins needed by the LCD. Just search for "stamp lcd" on the net
and you'll find some examples.
You can use something like the 74HC4053 (hi-z gizmo) to double up on a set
of pins if you like as well.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, November 25, 2002 10:06 AM
Subject: [noparse][[/noparse]basicstamps] PINS?
> Hello,
> thank you,
> Anthony
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
