Robotic Arm
Help, Please!!!
I am new at the game of programming. I have a robotic arm with five degrees
of freedom (base, elbow, shoulder, wrist and gripper). I am using BS2sx
Board of Education kit.
If someone has an algorithm of some kind I would appreciate. This way I can
learn by manipulating it.
Tom
Tom
If this is the arm I have in mind, easiest way is to
use discrete transistor drivers to swap polarity of
the batteries to the motors and handle the current
required to drive the motors.
Control to the drivers is ON/OFF only. There is no
(simple) positional feedback logic for this arm.
Sensing current overload (stall) is not possible when
the arm has reached the end of travel as this
particular kit has a built-in clutch to prevent damage
to the plastic gears.
Kevin K Asato
KC6POB
--- smarttip@a... wrote:
> Help, Please!!!
> Thanks,
> Tom
> removed]
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus – Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
