SerIn at 10400bps
Hi,
Does somebody know how I can send and receive data at 10400bps with the
BS2? I don't know how to set the baudrate at this speed. The data is 8bits no
parity, 1 stop (with line driver and inverted). Thank you very much
Eze
Eze
tables for computing baud rate. It shows you how to compute it by hand.
You can compute it for 104000 but as best i am not sure how high the bs2
will go.
I was under the impression that it would only do 9600 but on page 274 of the
manual it says 243 - 50,000. Someone please jump in and verify this.
for 10400bps on bs2 you would do:
int(1000000 / 10400) - 20
+ 0 8bit/no-parity
+ 16384 inverted polarity
16460
so you would say
serin the_pin, 16460, [noparse][[/noparse]SerData] 'baud too high for bs2?
basic stamp manual - see page 277:
i did myself a huge favor by reading the entire serin section.
http://www.parallax.com/Downloads/Documentation/BASIC%20Stamp%20Manual%20v2.
0.pdf
mkl
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, November 24, 2002 7:35 AM
Subject: [noparse][[/noparse]basicstamps] SerIn at 10400bps
> Hi,
the BS2? I don't know how to set the baudrate at this speed. The data is
8bits no parity, 1 stop (with line driver and inverted). Thank you very much
> Eze
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Ezequiel
Original Message
Sent: Sunday, November 24, 2002 12:03 PM
Subject: Re: [noparse][[/noparse]basicstamps] SerIn at 10400bps
> Page 277 of the basic stamp manual gives a some pretty straight forward
> will go.
the
> + 0 8bit/no-parity
> 16460
> so you would say
> 0.pdf
> mkl
Original Message
> From: "Ezequiel Leonardo Aceto" <Nik@i...>
> > Hi,
with
much
> > Eze
and
>Thanks,
>Ezequiel
Hi Ezequiel,
The opposite.
Inverted mode usually means that 0 volts (or negative volts as in
RS232) is the "logic 1" or "marking" state. And +5 volts (or
generally positive >3 volts for RS232) is the "logic 0" or "spacing"
state.
That is true for the Stamp. For p0 to p15 and the "inverted" baud
modes, the pin rests at 0 volts when nothing is going on, between
transmissions. That is the logic 1 state, and that sometimes
confuses people, but RS232 always rests in the logic 1, marking
state. The start bit is logic 0 (+5 volts) and so on, data is
transmitted lsb first, with logic zero bits being +5 volts and logic
1 bits being zero volts. The byte is followed by at least 1 stop bit
back at logic 1 level, zero volts, and there the level stays until
the next transmission.
In non-inverted baud modes logic 1 is represented by +5 volts. Get
it!-->-non-inverted, logic 1, +5 volts. The trick is to remember
that the RS232 line always rests in the logic 1 state, +5 volts in
the non-inverted case.
If you are connecting a BASIC Stamp directly to another RS232 device,
use the inverted mode, but if you are going through an inverting line
driver, then use the non-inverted baud mode (because the driver will
invert it).
Finally, p16 on the Stamps is a special case, because it has a
built-in inverting line driver. It transmits with inverting logic
(resting at the low level, logic 1), no matter what baud mode you use
in your program. For example, it does not matter if you use $54 or
$4054. Either one will be inverted at P16. That number does affect
the sense of the flow control pin though, if you are using that
option of the SERIN and SEROUT command.
-- regards,
Tracy
