Pan / Tilt camera using 2 servos(or steppers)+ BS2-IC (help)+ ?
Thanks Dave:
Yes, steppers could be better.
I understand the feedback , but
any idea about how can I record and
play movements later. ?
Many thanks : Joe
--- Dave Mucha <davemucha@j...> wrote:
> I see two options pretty quickly.
> use some feedback such as a potentiometer or encoder
> to record
> movement.
> use a stepper as the motor.
> I think the stepper might be easier as you would
> need an H-bridge for
> the fwd and rev movements and the stepper would need
> a dual H-bridge
> for each motor. and Allegro has stepper chips for
> small steppers.
> Remember, a stepper SHOULD be driven at between 5
> and 20 times
> nameplave voltage, but no more than nameplate
> current. and if you
> take a uni-polar and drive it in bi-polar, full
> winding mode, you
> only need half the current to get the same power
> output.
> If you salvage some mini-steppers from an old
> printer, you may be
> able to use a darlington. a UNL2803 (8 circuits)
> could handle one
> (low power) motor and it has clamping doides to
> eleminate the high
> voltage spike that is created on every step as the
> magnetic files
> colapses.
> Dave
> --- In basicstamps@y..., Joe Terk <joeterk@y...>
> wrote:
> > Help:
> > We need to move a camera and record
> > the pan & tilt moves, because we
> > need to repeat the same movements.
> > Servos, must be modified ?
> > Pan / Tilt must be without vibrations.
> > Any Idea.
> > Thanks : JOE
> > PS: Is it better the SSC
> > PS2: Is it possible to use VB to move servos
> > , speed, time , and recording this using BS2-ic?
> > or SSController is better.
> > __________________________________________________
> > Do you Yahoo!?
> > Faith Hill - Exclusive Performances, Videos & More
> > http://faith.yahoo.com
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Do you Yahoo!?
Yahoo! Web Hosting - Let the expert host your site
http://webhosting.yahoo.com
Many thanks : Joe
> to record
> movement.
> a dual H-bridge
> small steppers.
> and 20 times
> current. and if you
> winding mode, you
> output.
> printer, you may be
> could handle one
> eleminate the high
> magnetic files
> colapses.
> Dave
> wrote:
> > Help:
> > Any Idea.
> > Thanks : JOE
> > Do you Yahoo!?
> ignored.
Do you Yahoo!?
>Thanks Dave:
>Many thanks : Joe
Joe -
You might want to search for animatronics devices. Here are some, including a
recorder and playback mechanism for r/c servos:
http://www.wizard-devices.com/animatronics.shtml
I'm sure there are many other available.
Bruce Bates
