SerIn - SerOut and Open Colector
Hello,
I have a device that communicate using RS232, I saw in the schematic that
the RX line is the colector of a transistor. And the colector of the transistor
has a resistor to Vdd. How do I set the baud mode to receive the data? The
device communicate at 9600bps 8bits no Parity, Thank you
Ezequiel
Ezequiel
Another point, in on part of the program I have to communicate with
this device at "5bps , 7 data bits, Even Parity and 1 stop Bit". How can I
select the baud mode for this? Thank you
Original Message
To: "Basic Stamp Yahoo" <basicstamps@yahoogroups.com>
Sent: Sunday, October 27, 2002 2:29 PM
Subject: [noparse][[/noparse]basicstamps] SerIn - SerOut and Open Colector
> Hello,
that the RX line is the colector of a transistor. And the colector of the
transistor has a resistor to Vdd. How do I set the baud mode to receive the
data? The device communicate at 9600bps 8bits no Parity, Thank you
> Ezequiel
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
The slowest a stamp can send or receive data is around 120bps. Sending
data with 7 data bits and even parity is easy, as you just add 8192 to
the baudmode, but if you really need to send data at 5bps, you will
have to create your own serial routine.
On Sunday, October 27, 2002, at 11:59 AM, Ezequiel Leonardo Aceto wrote:
> hello,
> with
> can I
Original Message
> From: "Ezequiel Leonardo Aceto" <Nik@i...>
>> Hello,
>> schematic
> the
> receive the
>> Ezequiel
>> and
> and Body of the message will be ignored.
