Data Logging
Hi all,
I have a potential application for a stamp. I wish to connect to the
serial port of another device (Allen-Bradley PLC) and log the data that is
being sent. It is a string of about 40 characters that is transmitted
every 30 seconds. I can set the baud rate down to a low of about 1200. I
need to log 3,000 sets of data. When 3,000 sets are reached, I need to
start at the beginning and overwrite the oldest data set. Kinda like a
FIFO. Periodically somebody will come by and hook up a laptop and press a
button to dump all the 3,000 data sets to Hyperterminal. I know the bulk
of this is doable with a stamp, but I am concerned about the amount of data
I need to store... 120,000 bytes. Can this be done? Can somebody
recommend some external, non-volatile memory that I should look at? If
somebody out there has developed a board to work with the stamp with this
much memory already on it, I would even consider purchasing it. I can
write the necessary code myself.
Power consumption is not an issue.
Finally, does anybody have an algorithm for conversion to/from a Julian date?
Aaron
Aaron
not sure where you are from, but R T Nollet in Australia has a 1M bit
module (128k bytes) that may suit your needs. I am using one for my
data logging activities and it works great with any BS2.
http://www.nollet.com.au/Memory_module_1Meg.htm
Cheers
Col
--- In basicstamps@y..., "agarb@b..." <agarb@b...> wrote:
> Hi all,
the
that is
transmitted
1200. I
need to
like a
press a
the bulk
of data
at? If
with this
can
Julian date?
> Regards,
> Aaron
http://mathforum.org/library/drmath/view/51907.html
might help.
This one might help even more:
http://serendipity.magnet.ch/hermetic/cal_stud/jdn.htm
-- Don
--- "agarb@b..." <agarb@b...> wrote:
> Hi all,
> done? Can somebody
> Regards,
> Aaron
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you
> subscribed. Text in the Subject and Body of
> the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
A 16kB I2C EEPROM perhaps?
Each cell in the EEPROM can be written to 1 million times before they wear
out.
At a rate of 40bytes every 30 seconds, it would take 4000 seconds to fill
the EEPROM, or 4 x 10E9 seconds before the EEPROM wears out. Which, if my
maths is right (and considering how bored I am at work right now - hence why
I'm readung and replying to home emails..., so my maths could be wrong), is
about, well a few years...
> From: Don French <french_don@y...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Wed, 25 Sep 2002 19:09:26 -0700 (PDT)
> Subject: Re: [noparse][[/noparse]basicstamps] Data Logging
> As to the date conversion:
> might help.
> -- Don
>> Hi all,
>> done? Can somebody
>> Regards,
>> Aaron
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
multimedia, flashram type cards? If so, what are the
connections?
--- Ben <ben@l...> wrote:
> Re the Memory:
> out.
> > might help.
> > -- Don
> >> Hi all,
> >> done? Can somebody
> >> Regards,
> >> Aaron
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com
A single 8-pin flash memory chip AT45D020 can hold 256 kbytes. Code here:
http://www.emesystems.com/BS2flash.htm
http://www.emesystems.com/BS2math4.htm#JulianDate
>Regards,
>Aaron
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
Open Source Software for Data Acquisition and Data Mining.
Simply send XML encoded data out the serial port once per second.
Frontier Data System software can capture the data, store it into a
database, then search the data to deliver dynamic reports to your
browser.
It can be used to capture data from a microcontrollers and there is
even a tutorial for doing data acquisition from a Allen-Bradley PLC
via the HMI.
Uses Linux, Apache, MySQL and PHP to provide a 100% open source
solution.
The XML RS232 output looks something like this. The idea is to hard
code the XML tags and have the data values as variables.
*<w,0,2>552</w,0,2><w,0,1>37846</w,0,1><w,0,0>32771</w,0,0><n,0,0>3200
</n,0,0><n,0,1>502</n,0,1>$
The string is sent to the client PC once per second. When the string
changes records are created.
Encoding Scheme
*<Data Type,Station,Element>Value</Data Type,Station,Element>$
Data Types
b - Bit bit using 0 or 1
w - Word encodes 16 bits using integer values between 0 and
65535
n - Number Number (float)
Station
0 to 255
Element
Bit 0 to 240
Word 0 to 15
Number 0 to 255
Value
Bit 0 to 1
Word 0 to 65535
Number -3.4E+38 to 3.4E+38
For the rest of the discription chech out the online tutorials at
frontietech.ca.
> Hi all,
the
that is
transmitted
1200. I
need to
like a
press a
the bulk
of data
at? If
with this
can
Julian date?
> Regards,
> Aaron
