Optrex 16117b lcd
Does anyone know where I might find a data sheet on an "OPTREX 16117B
LCD"? Did a google search with no results.
Thanks for your help..
Leroy
Leroy
The controler is the same one in the stamp manual (HD44780).
You can use LCDCMD (page 159-166) LCDIN (page 167-170) and LCDOUT
(page 171-176)
here is some info for you about that display
http://www.optrex.com/SiteImages/PartList/SPEC/16117aae.pdf
Good luck
A. Conti
16117B
> Leroy
page 8 has the pinout for that display
--- In basicstamps@y..., "iamturbo2000" <aconti@s...> wrote:
> Leroy,
LCDOUT
> (page 171-176)
> Good luck
> A. Conti
> 16117B
> > Leroy
>Leroy
Leroy -
This is probably the unit you're looking for, or one similar to it:
http://www.optrex.com/ProductList.asp?PartNumber=DMC%2D16117A
Bruce Bates
You might find this web site interesting. They sell IC's for
microcontrollers. The chip you may be interested takes any LCD display with
the standard Optrex interface and make it a serial LCD display. The chip is
under $10 bucks and works great. I bought some 4 X 20 displays (surplus
new/old stock) for $4.50 each and added the chip and I have nice SERIAL LCD
displays for under $15.00. MUCH easier than using all those Stamp pins for
the data lines....
Mike B.
Oh yea, here's the link:
http://www.elabinc.com/
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, September 02, 2002 9:05 AM
Subject: [noparse][[/noparse]basicstamps] OPTREX 16117B LCD
> Leroy
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
