Breadboard Prototyping...
Hello All,
What experiences have you had with putting your Basic Stamp
prototype circuits together on breadboards? I'm aware of capacitance in
breadboards, but are there other issues that I should know of compared to a
final PCB version of the same circuit?
Thank You,
Tim
Timothy Medema
CrystaLite, Incorporated
3307 Cedar St. (425) 745-6000 800-666-6065
Everett, WA 98201 Fax: (425) 257-0232
www.crystaliteinc.com
<mailto:timm@c...>timm@c...
The information transmitted is intended only for the person or entity to
whom it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you received
this in error, please contact the sender and delete the material from any
computer.
Thank You,
Tim
Timothy Medema
computer.
As long as you stay away from high frequency applications, I think it should
be OK with breadboards.
I've made some test circuits (dual thermometer with LCD, real time clock,
relay switching...) with a breadboard without any problem... except some
wires poping out of the board... then I used thicker wires, and it's OK.
And I always put a 10 or 47 µF capacitor on the supply lines of the
breadboard itself.
Phil.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, August 12, 2002 6:49 PM
Subject: [noparse][[/noparse]basicstamps] Breadboard Prototyping...
> Hello All,
a
> Thank You,
> Tim
> Timothy Medema
> computer.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Tim
At 07:04 PM 8/12/2002 +0200, you wrote:
>Hi Tim,
>breadboard itself.
>Phil.
Original Message
>From: "Timothy Medema" <timm@c...>
> > Hello All,
>a
> > Thank You,
> > Tim
> > Timothy Medema
> > computer.
out for 0.400 DIPs like you get at Radio Shack. We have a local shop that
makes a much better version of the board, but its the same layout. I use 26
ga telephone wire or 26 ga buss wire for all my connections other than
external sensors, etc...
Prototyping is done on a solderless breadboard. Never had a problem with
things doing what they shouldn't with either method.
Original Message
a
Thanks for taking the time to provide input regarding your experience.
Much appreciated,
Tim
At 06:37 PM 8/12/2002 -0500, you wrote:
>All my Stamp and AVR stuff is done on those small perf-boards (2 x 3) laid
Original Message
>a
