input debounce
I have written some code for a BS2 that looks at pins 0-2 for a low
input. Once a pin goes low e.g. IF INP0=0 THEN *** (via a Happ button
push)then the code makes the device look at pins 3-5 for another low
input (via a Happ button push). Ultimately, I plan to use a BS2P and
utilize 12 inputs pins and 12 output pins.
I programmed my BS2 and have it working just fine on my proto board.
I was wondering if I should go ahead and debounce the inputs. I would
rather do this with code rather than external logic device(s).
Can anybody recommend the easiest/simple way to do this in code?
Guy
Guy
code that I routinely use in my projects. It can be adapted for any number
of inputs.
The routine is setup for active low switches, hence the tilde (invert)
operator used with InA (change this part as needed). The routine assumes
that all buttons are pressed. It scans the inputs then ANDs them with the
assumed state. If any input goes (or is) inactive, even momentarily, then it
will return as not pressed.
You can fine-tune the debounce period by changing the loop count and the loop
delay.
Get_Switches:
switches = %1111
FOR x = 1 TO 10
switches = switches & ~InA
PAUSE 5
NEXT
RETURN
-- Jon Williams
-- Parallax
In a message dated 7/31/02 1:28:41 PM Central Daylight Time, guyb@m...
writes:
> Thanks,
> Guy
