Little stepu controller
What code do i use to read the current position of the stepper motor.
I tried a write on 10 and a read on 11 didn't work.any information anyone
can give will be appreciated
thanks max
thanks max
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, July 29, 2002 12:29 AM
Subject: SV: [noparse][[/noparse]basicstamps] LITTLE STEPU CONTROLLER
> Greetings!
> You might start by telling us a bit more about your equipment.
> But...
> Unless you have some sort of rotary encoder or something you won't be able
> to read the position.
> Trygve
Opprinnelig melding
> Fra: max powell [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=K_lpUlfCHbeB1QOeYo9QKrUNLJ1sJCU2SSbPOjkLSN2fdVJhBnYB7LQCcw7knGajITY9NNPver1T]mpowell@t...[/url
> Sendt: 29. juli 2002 12:28
> Til: basicstamps@yahoogroups.com
> Emne: [noparse][[/noparse]basicstamps] LITTLE STEPU CONTROLLER
> WHAT CODE DO I USE TO READ THE CURRENT POSITION OF THE STEPPER MOTOR.
> I TRIED A WRITE ON 10 AND A READ ON 11 DIDN'T WORK.ANY INFORMATION ANYONE
> CAN GIVE WILL BE APPRECIATED
> THANKS MAX
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> ACORDING TO INFO WITH THE CONTROLLER IT SHOULD SEND BACK # OF COUNTS FROM
HOME POSITION WHEN SENT THE CODE "U" I DONT HAVE THAT INFORMATION AT HAND AT
PRESENT BUT THOUGHT SOMEONE MIGHT HAVE WORKED WITH IT AND MAY KNOW THAT
INFO.
THANKS MAX
