Macintosh to Basic Stamp 1?
Has anyone used a Macintosh to program
a Basic Stamp 1? (with Connectix Virtual PC)
The Keyspan USB to Serial Adapter
p/n: USA-19Qi works good to program the
BS2. Has anyone added a parallel
to serial converter with this device,
or found a working USB/Parallel
adapter and had success
with the BS1?
-Mike
with the BS1?
-Mike
I haven't trIed this with a BS1, but the "uMater" is a USB to Parallel
converter that works perfectly under Virtual PC.
I've used it to drive a Parallel Printer, using it's native Windows Drivers
(rather than using a Mac printer, and emulating a printer in VPC), and it's
worked perfectly.
You simply install a Windows Driver for the uMater, and it turns up as
"USBLPT1".
Cheers,
Ben, Wellington, New Zealand.
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Web Hosting and Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: "mikegotis" <mikegotis@y...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Sat, 27 Jul 2002 17:19:48 -0000
> Subject: [noparse][[/noparse]basicstamps] Macintosh to Basic Stamp 1?
> with the BS1?
> -Mike
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
