Mac + Keyspan 28X Anyone got it to work?
Hi,
I know this has been covered before, and I think I've read almost
every bit of info on the web and at Parallax about getting this to
work but I'm still stuck.
I've got a PowerBook G4 running 9.2 and VirtualPC 5 + Windows 98.
I'm connecting to the OEM Stamp 2 boards DB-9 through a Keyspan 28X
(the dual port USB to Mac serial unit).
I have verified that the board works by hooking it up to a WinBook
(its my server, so, no I can't use it permanently).
I've tried two or three premade DB-9 to Din 8 cable adapters to no
avail. I've made up my own cables.
When I run the Stamp application in Windows and I try to identify the
stamp I get NO on Echo and NO on Loopback for both COM1 and COM2.
I've verified the Keyspan Adapters works through VirtualPC + Win98 by
hooking up a modem and Rx/Tx'ing commands.
In short, everything works on the Stamp end everything works on the
Mac end but the two devices just are not talking to one another.
Anyone have any ideas?
INFOequipt,Inc.
dougc@i...
www.infoequipt.com
INFOequipt,Inc.
dougc@i...
www.infoequipt.com
dougc@I... writes:
Do you have pins 6 and 7 on the DB9 shorted ?
Sid
serial ports are).
It is easy to make an RS422 to RS232 cable, but the issue is with the pulses
created by the RS422 port - they are too short or something like that.
However, this solution does work:
Use a Keyspan USB to PDA adapter. That is USB to RS232.
Don't use a Belkin or any other brand, the Keyspan has been tried and tested
to work.
Below is Tracy's response to an earlier post on this subject:
Hi Ben,
There are multiple sufficient causes. I don't think the older
Mac/VPC/RS422 port will work with the Stamp IDE software. I looked
into this intensively a couple of years ago, before Apple switched
completely away from RS422 support to USB only. (Note that the USB
solution, amazingly, does work quite well, at least using the keyspan
PDA adapter.)
cause 1) The stamp requires a reset pulse to come out from the PC on
the DTR line.
-- this pulse is not generated correctly on the Mac/VPC
cause 2) At the same time a long Break signal has to appear on TX- to
put the Stamp into programming mode
-- the Mac/VPC only generates a short runt pulse
At the time, I made a circuit that would take the runt pulse and
externally generate the reset and the break signals. But it still
didn't work..
cause 3) After the stamp is in programming mode, the stamp IDE
software sends out interrogation bytes and it expects responses to
come back from the stamp within a tight time frame, amounting to less
than 30 milliseconds. However, VPC operated the serial port on some
kind of queuing buffer that was serviced at something like 50
millisecond intervals. So the response from the Stamp rarely came
back on time and the IDE would time out with the dreaded "Stamp not
found.." error. I asked Jeff at Parallax if he could make a
version of the IDE with relaxed timing, but he is a very busy guy,
and with the new IDE it has a lot more checking to do now to test for
all the different kinds of stamps.
I have not checked on it for a couple of years, so I would be happy
to find that you can get it to work. But I am not too encouraging
about it. You may have to spring for the USB adapter, or even for
an old used PC!
BTW, when wiring the Mac RS422 cable, HSKin as an input would be more
like DSR or CTS. Also, be sure to connect RX+ to GND so that the
RS422 will have a reference for the input level.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Web Hosting and Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: Douglas Corarito <dougc@I...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Tue, 23 Jul 2002 20:11:29 -0400
> Subject: [noparse][[/noparse]basicstamps] Mac + Keyspan 28X Anyone got it to work?
> Hi,
> INFOequipt,Inc.
> dougc@i...
> www.infoequipt.com
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
The correct Keyspan adapter is P/N: USA-19Qi.
It was designed as a way to connect a PDA to
the USB port on a Macintosh or Windows computer.
The Keyspan USB PDA Adapter comes with a
software driver which is installed as a Control Panel.
Configure the Keyspan USB 19 Serial Assistant and
Virtual PC to operate through the virtual COM port. Have
the "Basic Stamp 2 - to Keyspan" connected to the correct
USB port. You'll know when it connects by running
the Editor. Keep the stamp powered up and connected
when running the configuration. Also, my keyspan USB to
serial adapter is plugged directly into the BS2. I use
a Parallax Board of Education and removed the DBM
screws so the Keyspan can fit. For more information
please visit these sites:
http://www.keyspan.com/support/macosx/usa/
http://www.keyspan.com/products/usb/pdaadapter/
http://www.robotstore.com/download/Stamps_on_iMac_2.13.pdf
http://www.parallaxinc.com/downloads/Documentation/stamp_o
n_mac/
-Mike
--- In basicstamps@y..., Douglas Corarito <dougc@I...> wrote:
> Hi,
almost
Windows 98.
Keyspan 28X
WinBook
no
identify the
and COM2.
Win98 by
on the
> INFOequipt,Inc.
> dougc@i...
> www.infoequipt.com
