BS2 and Servo Question
I am trying to controll servos from a VB application, I can't seem to
get it figured out. Here is some snips, anyone have any ideas?
the Stamp Code
'{$STAMP BS2}
pinnumber var byte
servopos var byte
main:
Serin 16,16780,[noparse][[/noparse]WAIT(255),pinnumber,servopos]
pulsout pinnumber, (750 + servopos)
pause 15
goto main
The VB code
Private Sub cmdSend_Click()
Dim PinNumber As Long
Dim servopos As Long
servopos = Val(txtvalue.Text)
' Get Pin Number
PinNumber = cboPinNumber.ListIndex
' Send Out Data
MSComm1.Output = Chr$(255) & Chr$(PinNumber) & Chr$(servopos)
End Sub
servopos comes from a slider controll set at min 25 and max 254, not
sure if these are right but I have tried many values and nothing
works. Anyone have any ideas????
the Stamp Code
'{$STAMP BS2}
pinnumber var byte
servopos var byte
main:
pause 15
goto main
The VB code
' Get Pin Number
' Send Out Data
End Sub
need to send values between 500 and 1000 with PULSOUT. That means the value
that is passed to your servo routine needs to be between -250 and +250 ... a
byte variable can't hold anything but positive values (0 - 255).
To keep things simple, I would have your VB slider send a value between 0 and
500; 250 being the center point. Your servo update routine would change to:
PULSOUT pinNumber, (500 + servoPos)
Then, your servoPos value needs to be a Word (two bytes), so you'll have to
modify your SERIN line.
Or ... you could keep the servoPos variable a Byte and pass a servo position
value between 0 and 250 (125 is the center now). Then change your servo
update code to this:
PULSOUT pinNumber, (500 + (servoPos * 2))
I hope this helps.
-- Jon Williams
-- Applications Engineer, Parallax
In a message dated 7/22/02 1:38:07 AM Central Daylight Time,
joebiederman@h... writes:
> the Stamp Code
> '{$STAMP BS2}
> pinnumber var byte
> servopos var byte
> main:
> pause 15
> goto main
> The VB code
> ' Get Pin Number
> ' Send Out Data
> End Sub
--- In basicstamps@y..., jonwms@a... wrote:
> Part of the problem is that to move the servo through its full
swing, you
the value
+250 ... a
between 0 and
change to:
have to
position
servo
> I hope this helps.
> -- Jon Williams
seem to
> > the Stamp Code
> > '{$STAMP BS2}
> > pinnumber var byte
> > servopos var byte
> > main:
> > pause 15
> > goto main
> > The VB code
> > ' Get Pin Number
> > ' Send Out Data
> > End Sub
not
update the servo position very fast. Anyone have any ideas?
Stamp code
'{$STAMP BS2}
pinnumber var byte
servopos var byte
cont var byte
b var byte
main:
for b = 1 to 50
pulsout pinnumber, (500 + (servopos * 2))
pause 10
next
goto main
VB Code
Private Sub cmdcenter_Click()
sldpos.Value = 125
End Sub
Private Sub Form_Load()
Dim Pins As Long
' Add the pin numbers 0 to 15 to cboPinNumber
For Pins = 0 To 15
cboPinNumber.AddItem CStr(Pins)
Next Pins
' Default to Pin 0 being selected
cboPinNumber.ListIndex = 0
' Default to optState(0) being selected
' Use COM1
MSComm1.CommPort = 1
' 2400 baud, no parity, 8 data bits, 1 stop bit
MSComm1.Settings = "2400,N,8,1"
' Open the port
MSComm1.PortOpen = True
End Sub
servopos = sldpos.Value
' Get Pin Number
' Send Out Data
End Sub
Private Sub Form_Unload(Cancel As Integer)
MSComm1.PortOpen = False
End Sub
Private Sub sldpos_change()
cmdSend_Click
End Sub
--- In basicstamps@y..., "quasigeek2002" <joebiederman@h...> wrote:
> Thats helps tremendously, thanks a million!
> swing, you
means
> the value
> +250 ... a
> between 0 and
> change to:
you'll
> have to
servo
> position
your
> servo
> > I hope this helps.
> > -- Jon Williams
> seem to
> > > the Stamp Code
> > > '{$STAMP BS2}
> > > pinnumber var byte
> > > servopos var byte
> > > main:
> > > pause 15
> > > goto main
> > > The VB code
> > > ' Get Pin Number
> > > ' Send Out Data
Chr$(servopos)
> > > End Sub
254,
> not
nothing
SERIN so that the servos get updated if nothing new is sent from the PC. You
could also use a timer on the PC side to continuously send the servo values
(in case the Stamp is doing something else and misses and update from the
PC). Lastly, you could use a "full" serial port with flow control.
I'll be working on that last part (pc connection with flow control) myself in
the next couple of weeks for an upcoming Nuts & Volts article.
-- Jon Williams
In a message dated 7/22/02 12:24:50 PM Central Daylight Time,
> Seems to be working ok, I posted the code below. It won't let me
