LCD/Temperature
'm new to the Basic Stamp. I have a BS2P24 and a NX1000 board that I
am trying to display the temperature to the 2x16 LCD offered by
Parallax.(4 bit mode)
I started with the DS1620bsp code. My modified code is at the bottom
of this Page. I know there is some excess code, But I will eliminate
it when I have it operating corectly
I am using LCDOUT LCDpin,NoCmd,[noparse][[/noparse](tempIn)] to display the temp on the
LCD. I get a display that changes with the temp but it is a single
letter. K is about 73 degrees F. If I warm the chip then it will
display L,N,P,R,T.... and so forth depending on the temp. Any help
would be appreciated. I would like to end up diplaying degrees in F.
Thank you,
Chris Haley
Main:
GOSUB GetTemperature ' read the DS1620
DEBUG Home
DEBUG "DS1620",CR
DEBUG SDEC tempC," C ",CR
DEBUG SDEC tempF," F ",CR
PAUSE 500 ' pause between
readings
LCDCMD LCDpin,ClrLCD ' clear display
PAUSE 500
LCDOUT LCDpin,NoCmd,[noparse][[/noparse]tempIn]
pause 1000
GOTO Main ' do it all over
END
DS1620init:
HIGH Reset ' alert the DS1620
'SHIFTOUT DQ,Clock,LSBFirst,[noparse][[/noparse]WrCfg,%10] ' use with CPU; free-
run
LOW Reset
PAUSE 10
HIGH Reset
SHIFTOUT DQ,Clock,LSBFirst,[noparse][[/noparse]StartC] ' start conversions
LOW Reset
RETURN
GetTemperature:
SHIFTOUT DQ,Clock,LSBFIRST,[noparse][[/noparse]RdTmp] ' give command to
read temp
SHIFTIN DQ,Clock,LSBPRE,[noparse][[/noparse]tempIn\9] ' read it in
LOW Reset ' release the DS1620
tSign = sign ' save sign bit
tempIn = tempIn/2 ' round to whole
degrees
IF tSign = 0 THEN NoNeg1
tempIn = tempIn | $FF00 ' extend sign bits
for negative
NoNeg1:
tempC = tempIn ' save Celsius value
tempIn = tempIn */ $01CC ' multiply by 1.8
IF tSign = 0 THEN NoNeg2 ' if negative, extend
sign bits
NoNeg2:
tempIn = tempIn + 32 ' finish C -> F
conversion
tempF = tempIn ' save Fahrenheit
value
RETURN
LCDinit:
PAUSE 500 ' let the LCD settle
LCDCMD LCDpin,%00110000 ' 8-bit mode
PAUSE 5
PAUSE 0
PAUSE 0
LCDCMD LCDpin,%00100000 ' 4-bit mode
PAUSE 0
LCDCMD LCDpin,%00101000 ' 2-line mode
PAUSE 0
LCDCMD LCDpin,%00001100 ' no crsr, no blink
PAUSE 0
LCDCMD LCDpin,%00000110 ' inc crsr, no disp
shift
RETURN
Thank you,
Chris Haley
Main:
DEBUG Home
DEBUG "DS1620",CR
readings
PAUSE 500
pause 1000
END
DS1620init:
run
LOW Reset
PAUSE 10
HIGH Reset
LOW Reset
RETURN
GetTemperature:
read temp
degrees
for negative
NoNeg1:
sign bits
NoNeg2:
conversion
value
RETURN
LCDinit:
PAUSE 5
PAUSE 0
PAUSE 0
PAUSE 0
PAUSE 0
PAUSE 0
shift
RETURN
interpreting the value as a character. Use the SDEC modifier (as you did
with DEBUG) to change the temperature value to a string of characters.
-- Jon Williams
-- Applications Engineer, Parallax
In a message dated 7/21/02 12:06:55 AM Central Daylight Time,
chaley63@y... writes:
http://www.mindspring.com/~jc1/serial/Resources/ASCII.html
Looks like a value of 75 decimal -- so the LCD is displaying what you told
it to, but not what you want it to. You need to convert this value to
characters in order to display it properly.
Original Message
Chris
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> So what is the ASCII value of an upper-case K?
you told
to
Original Message
that I
bottom
eliminate
the
F.
The SDEC modifier worked. Thanks All
--- In basicstamps@y..., jonwms@a... wrote:
> The LCD displays characters and you're sending it a number. It is
simply
you did
characters.
> -- Jon Williams
the
single
help
Thank you,
Chris Haley
Main:
DEBUG Home
DEBUG "DS1620",CR
readings
PAUSE 500
pause 1000
END
DS1620init:
run
LOW Reset
PAUSE 10
HIGH Reset
LOW Reset
RETURN
GetTemperature:
read temp
degrees
for negative
NoNeg1:
sign bits
NoNeg2:
conversion
value
RETURN
LCDinit:
PAUSE 5
PAUSE 0
PAUSE 0
PAUSE 0
PAUSE 0
PAUSE 0
shift
RETURN
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Do You Yahoo!?
Yahoo! Health - Feel better, live better
the value directly which is causing the LCD to think your sending an ASCII
character; that's why the character changes as the temperature changes. The
DEC, SDEC, HEX and BIN modifiers (used with DEBUG, SEROUT, LCDOUT, I2COUT,
OWOUT) are actually numeric-to-text convertors.
-- Jon Williams
In a message dated 7/22/02 10:15:25 AM Central Daylight Time,
donaldscott_18@y... writes:
