MAX7219 Ghost!
I am running two digits with the MAX7219 and constangly get gohsting
on the second digit even if I send it a "blank" instruction (15).
Even with the blank, the second digit shows the same character as on
the first digit but much fainter (about 10%) brightness. The only
way I can eliminate the gohsting is to set the scanning to 0 (one
digit)and in that case the gohsting disappear but of course loose
control over the second digit.
Anyone has encountered this? Is there a solution? I am sure there
is...
PS. I followed the circuit and program that exist in Scott Edward's
book to the letter.
Many thanks...
Al
is...
book to the letter.
Many thanks...
Al
It sounds as if your scanning frequency is too high or your LEDs have too
much capacitance. Does the MAX chip have anything to control inter-digit
blank time? If it does, try increasing that.
The problem you are having is caused by stored charge in the output drivers
of the MAX chip and the LEDs themselves. The cure is to reduce the scan
frequency and to increase the dead time between each digit as it is scanned
(inter-digit blank time).
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
the MAX?
Al
--- In basicstamps@y..., Dwayne Reid <dwayner@p...> wrote:
gohsting
on
have too
inter-digit
output drivers
the scan
is scanned
> dwayne
