Powering the Devantech SRF04 Ultrasonic Ranger
The documentation says that the power supply should be at least 50ma
to power both the Stamp II and the Devantech. If I power the Stamp
with a 9V transistor battery, will there be enough power to run the
Davantech off of the regulated 5v output of the Stamp? If not, how
do I power the Devantech? Does it need it's own power supply?
power the devantech from a 9v battery and the stamps internal regulator. You
are pushing the limits of the stamp however, and you will have no power left
over for anything else. I created a test device, with the stamp a devantech
and a tiny speaker. I ran this from a 9V battery and carried it around the
room listening to the output from the devantech.
I do not recommend this for long term use, you are going to burn out the
stamp's regulator eventually.
You will need to use a small external power supply. Either onboard
batteries such as 4 C cell batteries and a 5V regulator or an external 120V
to 5V wall powerd regulator system. Radio shack has small referance
notebooks on building power supplys as well as regulating a 4 cell battery
pack to 5V.
Good luck to you.
-Kerry
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Very respectfully, your obedient servant.
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1132
that uses sonar for object avoidance. I don't have much space. I
have a 9v transistor battery powering the stamp, and 4 AA batteries
powering the servos for locomotion. I am using a Stamp II OEM which
does have a larger votage regulator than the SMD type. It sounds
like I need to have a third battery to power the Devantech? Since
space is limited, I really don't want to do it (especially bulky C
batteries!). Can I use some type of voltage regulator (like a 7805)
and connect it to the 9V battery that powers the stamp? I am
picturing one set of wires going from the battery to the stamp, and
another set of wires going to the Davantech through a "7805". Would
this work?
Steve
--- In basicstamps@y..., Kerry Barlow <admin@m...> wrote:
> I wrote an article about the devantech for N&V a few months ago.
You CAN
regulator. You
power left
devantech
around the
out the
external 120V
battery
> pack to 5V.
> Good luck to you.
> -Kerry
50ma
Stamp
the
how
> > basicstamps-unsubscribe@y...
Subject and
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
> 607-775-1132
LM2940 5 volt regulator. I then have enough power to run my stamp and
devantech and some other small sensors. The servos I drive directly from the
4 AA batteries at 6V. I tie the grounds of the servos and the ground of the
regulator, and battery and stamp all together. Always tie all of your ground
wires together.
You cannot use a standard 7805 regulator because there is to much voltage
drop within the 7805 series.
go to national and order a free evaluation copy of the LM2940 regulator
http://www.national.com/pf/LM/LM2940.html
Good luck to you.
-Kerry
At 05:33 PM 6/10/02 -0000, you wrote:
>Thanks for the quick response. I am trying to build a small robot
>this work?
>Thanks,
>Steve
>You CAN
>regulator. You
>power left
>devantech
>around the
>out the
>external 120V
>battery
>> pack to 5V.
>> Good luck to you.
>> -Kerry
>50ma
>Stamp
>the
>how
>Subject and
>> Kerry
>> Admin@M...
>> Kerry Barlow
>> p.o. box 21
>> kirkwood ny
>> 13795
>> 607-775-1132
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1132
in terms that I could understand!!!)
Again, thanks so much!!!
Steve
I have successfully run 8 SRF04's simultaneously on the same stamp
(the final code actually pulsed 4 at a time to eliminate crosstalk
issues). The stamp board was running off 12V shared with the IFI
robot controller, using Lithium AA cels.
Never bothered to check whether or not this would stress the Stamp,
it worked quite reliably, even with a 9V alkaline battery. The
SRF04's would tend to die a bit more often than I'd like but that was
probably due to the harsh environment (a battlebot).
'Course, I could be wrong, I'm a software geek, I wouldn't know a
milliamp if it bit me in the behind.
Best
R
