Grounding Issue
Hi folks!
I'm using a BS2 on a Super Carrier to control a BS1 Rev.D, which in
turn controls a couple of relays that turn LED's on and off. All of
the controlled circuitry (relays, LEDs, associated wiring) is on a
separate breadboard because the Rev.D's prototype area is too small.
The BS1-to-breadboard connections are:
1.BS1 5VDC to breadboard common power strip, 2. four(4) stamp pins
to relay set and reset pins for switching signals, and 3.BS1 ground
pin to breadboard common ground strip.
Another pin on the BS1 is connected to a pin on the BS2 for serial
control signals, and the BS1 ground is also connected to the BS2 VSS.
Now the strange part; the system only works properly when the BS1-
to-breadboard ground line is DISCONNECTED. When I hook it up, I get
inconsistently bad results.
You may wonder why I ask, when I know how to make it work!?!
Because I want to get an OEM BS1 and make a custom PCB to put all but
the BS2 on a single module. This means that the previous BS1-to-
breadboard ground, which seems to cause the trouble, will now be
permanent. If I can't find out why it's messing up under this
condition, I'm toast. By the way, the breadboard ground strip is NOT
connected to any other external ground.
Could it have anything to do with the fact that, when the BS1-to-
breadboard ground is hooked up, it is also directly connected to the
BS2 VSS? I can't disconnect the BS1-ground-to-BS2-VSS line, as then
I lose all serial comm for control signals.
I hope this is clear enough to understand the problem.
Any ideas?
Don
Any ideas?
Don
of the electronics Gurus out there can give some ideas! Please see my
question below. I welcome any suggestions!
Don
Sent: Sunday, June 02, 2002 9:23 AM
Subject: [noparse][[/noparse]basicstamps] Grounding Issue
> Hi folks!
> Any ideas?
> Thanks
> Don
to drive the relays. You may be marginally driving the relays due to the
current output limitations of the Stamps I/O pins.
relay coil is rated 5 VDC, 40 mA, 125 Ohm. I have read up on transistors
but I still don't understand them well enough to pick one.
Don
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, June 03, 2002 7:03 PM
Subject: Re: [noparse][[/noparse]basicstamps] Grounding Issue
> You should not drive relays directly with the stamp. Use a transistor
switch
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
OHM resistor in series with base connection (will limit I drawn from
chip to approx 1mA), and don't forget a back EMF diode across the relay
coil (1N4000 or any of the 1N4*** series will do).
ROB
Original Message
From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Nuoo5mXCO4DZ0xnVgwPAQdDCG882CB_ij08tJQEl1B_X17IqkDCMDvlgI8ZcymFUkVAXCCDWaBYl9WD5GS5GNxpG7-Y]renegade.engineer@v...[/url
Sent: 04 June 2002 15:26
To: basicstamps@yahoogroups.com
Ok, I could use some help figuring out what transistor to use. The
transistors
Don
Original Message
switch
the
and
and Body of the message will be ignored.
Ground the source pin.
Tie the gate to the stamp pin, no resistor is required as the mosfet's gate
load is less than a microamp at dc and only a small capacitive load, if you
prefer you could use a resistor anything from 470 ohms through 1 meg will
do. (I personally use a 10K if anything, because I accidentally ordered ten
thousand 10,000 ohm resistors).
Tie the drain lead to the relay coil, and put a diode across the coil
(reverse biased) to limit inductive kickback.
Original Message
> Don
Original Message
> From: <azeasi@a...>
> switch
and
Don
Original Message
Sent: Tuesday, June 04, 2002 8:51 AM
Subject: RE: [noparse][[/noparse]basicstamps] Grounding Issue
> BC337, BC107, 2N3904, BC107,8,9 all NPN devices with HFE >50. Put a 4.7K
> ROB
Original Message
> From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2hdj3Bsm6B-YFH-rPs4HfBP6vnn8T5PmK17PfAZDCmOq5yN0jhgAnc47fJbJDDeE4H0zbnFutLL3PnkOZLdg4BkahOmLDw]renegade.engineer@v...[/url
> transistors
> Don
Original Message
> From: <azeasi@a...>
> switch
> the
> and
Don
Original Message
<techsupport@f...>
Sent: Tuesday, June 04, 2002 9:17 AM
> My personal preference is the 2n7000 mosfet. ($4.00 / hundred)
gate
you
ten
Original Message
> From: "Don" <renegade.engineer@
transistors
> > Don
Original Message
> > From: <azeasi@a...>
> > switch
the
> and
and
Can you tell us the supplier for those FETs at that price?
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Do you know of an online source for the 2n7000 mosfet? Thanks.
Scott
but...
"A $5 handling charge is added to your order if the subtotal is less than
$25."
Since the unit cost is only $0.31, that makes it one expensive MOSFET.
Don
Original Message
Sent: Wednesday, June 05, 2002 11:39 AM
Subject: [noparse][[/noparse]basicstamps] Re: Grounding Issue
> Don -
> Scott
transistor (2N3904) and a 1K or less 1/4 watt resistor to drive your relay.
If you insist on buying the 2N7000 part it won't work any better for your
application. You aren't concerned about nanosecond switching speeds! By the
way Web-Tronics.com also carries the 2N7000 at the 29 cent price as well as
the 2N3904 etc. I don't think they have a minimum but probably would not
appreciate an order for 29 cents!
