Cable problem...
I've been trying to get Stampw to work under Virtual PC on a Mac Laptop.
The software works, however, it says that the BS2 was found but is not
responding.
Here is how it is all set up:
Mac: G3 Powerbook with RS422 serial port.
Cable: Home made 8pin mini DIN to DB9 (RS422 to RS232).
The cable is wired up as follows:
Mac end PC End
HSKout DTR
HSKin RTS
RX- RX
TX- TX
GND GND
The interesting thing, is that this set up works fine under Virtual PC
when I am using Hyperterminal to send and receive data to/from the
BOE. It also works on the Mac side, when using the Mac equivalent of
Hyperterminal.
Virtual PC is set up to use the Mac's Serial port as Com1.
I have also tried V1.098 and 1.3.1 of the Stamp Editor.
Any ideas? Is the cable wired correctly?
I have got a USB PC Card on the Mac, but don't want to spend $75 on a
USB to PDA adapter if it is just an incorrectly wired cable.
Cheers,
Ben.
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Web Hosting and Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
responding.
Mac end PC End
HSKout DTR
HSKin RTS
RX- RX
TX- TX
GND GND
Hyperterminal.
Cheers,
Ben.
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
It sounds as if you have no power to the Basic Stamp, or pins 6 an 7 at the
DB9 end are not tied together.
Check both of these areas and see if the problem is still there when these are
OK. If one or both of these
problems exist then fix them and see if the problem goes away.
Have Fun !!
Dale Fleischmann
> responding.
> Mac end PC End
> HSKout DTR
> HSKin RTS
> RX- RX
> TX- TX
> GND GND
> Hyperterminal.
> Cheers,
> Ben.
> Hm: +64 4 972 7567
> Mb: +64 21 536 627
> 87 Spencer Street
> Crofton Downs
> Wellington
> New Zealand
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
From reading your email, and looking at the trace on the BOE board (the
trace connects 6 and 7 together), and looking at my trusty Dick Smith Data
section, it would seem that I haven't got the Handshaking wires set up
correctly!
I've got Power to the Board.
The fact that I can talk to the Stamp with Hyperterminal on the "PC"
(Connectix Virtual PC) or Mac side, but not with Stampw, would suggest that
Stampw relies on Handshaking to work, whereas Hyperterminal and similar
programs do not.
Will rewire the cable and report back.
Thanks Dale!
Ben, Windy Wellington, New Zealand.
> From: Dale Fleischmann <fleidale@c...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Fri, 31 May 2002 05:52:06 -0600
> Subject: Re: [noparse][[/noparse]basicstamps] Cable problem...
> Hi Ben;
> Have Fun !!
> Dale Fleischmann
>> responding.
>> Mac end PC End
>> HSKout DTR
>> HSKin RTS
>> RX- RX
>> TX- TX
>> GND GND
>> Hyperterminal.
>> Cheers,
>> Ben.
>> Hm: +64 4 972 7567
>> Mb: +64 21 536 627
>> 87 Spencer Street
>> Crofton Downs
>> Wellington
>> New Zealand
>> Body of the message will be ignored.
There are multiple sufficient causes. I don't think the older
Mac/VPC/RS422 port will work with the Stamp IDE software. I looked
into this intensively a couple of years ago, before Apple switched
completely away from RS422 support to USB only. (Note that the USB
solution, amazingly, does work quite well, at least using the keyspan
PDA adapter.)
cause 1) The stamp requires a reset pulse to come out from the PC on
the DTR line.
-- this pulse is not generated correctly on the Mac/VPC
cause 2) At the same time a long Break signal has to appear on TX- to
put the Stamp into programming mode
-- the Mac/VPC only generates a short runt pulse
At the time, I made a circuit that would take the runt pulse and
externally generate the reset and the break signals. But it still
didn't work..
cause 3) After the stamp is in programming mode, the stamp IDE
software sends out interrogation bytes and it expects responses to
come back from the stamp within a tight time frame, amounting to less
than 30 milliseconds. However, VPC operated the serial port on some
kind of queuing buffer that was serviced at something like 50
millisecond intervals. So the response from the Stamp rarely came
back on time and the IDE would time out with the dreaded "Stamp not
found.." error. I asked Jeff at Parallax if he could make a
version of the IDE with relaxed timing, but he is a very busy guy,
and with the new IDE it has a lot more checking to do now to test for
all the different kinds of stamps.
I have not checked on it for a couple of years, so I would be happy
to find that you can get it to work. But I am not too encouraging
about it. You may have to spring for the USB adapter, or even for
an old used PC!
BTW, when wiring the Mac RS422 cable, HSKin as an input would be more
like DSR or CTS. Also, be sure to connect RX+ to GND so that the
RS422 will have a reference for the input level.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
>responding.
>Mac end PC End
>HSKout DTR
>HSKin RTS
>RX- RX
>TX- TX
>GND GND
>Hyperterminal.
>Cheers,
>Ben.
I'll check the wiring, but may just have to buy the PDA adapter.
I've been using an old Toshiba Satellite Pro 410CDT for Stamp development so
far, but would prefer to get rid of that and the really old Power Mac 6300
and LC475 (used for my PCB CAD program - Protel Easytrax), and just use my
G3 Laptop with it's USB port and RS422.
Save some space in my workshop, basically.
If it does work OK with the PDA adapter, anyone in New Zealand be interested
in buying an old Toshiba Laptop cheap? It's PC Card slot doesn't work (So
can't use my USB card in it), and the battery circuitry seems to have failed
(Works off AC power only). Apart from that, it works fine for Stamp
Development.
Cheers,
Ben, Wellington, New Zealand.
> From: Tracy Allen <tracy@e...>
> Date: Fri, 31 May 2002 09:26:23 -0700
> Hi Ben,
> PDA adapter.)
> the DTR line.
> didn't work..
> an old used PC!
> -- regards,
> Tracy Allen
> mailto:tracy@e...
>> responding.
>> Mac end PC End
>> HSKout DTR
>> HSKin RTS
>> RX- RX
>> TX- TX
>> GND GND
>> Hyperterminal.
>> Cheers,
>> Ben.
