MIDI Patch Controller
Hello Basic Stamp Group,
I just joined today. I am in need of some ideas for code and circuits
to build the following.
A MIDI patch controller that uses a keypad to select
1) the channel to send
2) the patch number to send
I have a need for such a device for my guitar effects / guitar
synthesizer equipment.
There are many controllers on the market that can be programmed and
there
is software for PC that do this. These are either too big or do not
have a keypad. I am going to build a small unit
that can either mount / clip on the side of a microphone stand or
double-sided sticky tape to my guitar.
I only need to send. No MIDI in or MIDI through is needed.
Thanks in advance. I look forward to the group ideas.
Bill Bores
www.cypressguitars.com
there
Bill Bores
circuits
>there
>Thanks,
>Bill Bores
The fist obvious thing to do is to find out exactly what signals you
need the stamp to send. Timing, voltage level, etc. I'd work that out
first on a stamp prototype board and then once you've done that, and
programmed it all, work out how to translate that into the final
phsyical package you need.
Paul Lugger
__________________________________________________________________
Get your free Australian email account at http://www.start.com.au
kevin / kc6pob
--- Bill Bores wrote:> Hello Basic Stamp Group,> > I just joined today. I am
in need of some ideas for> code and circuits> to build the following.> > A MIDI
patch controller that uses a keypad to select> > 1) the channel to send> 2) the
patch number to send> > I have a need for such a device for my guitar> effects /
guitar> synthesizer equipment.> > There are many controllers on the market that
can be> programmed and> there> is software for PC that do this. These are
either> too big or do not> have a keypad. I am going to build a small unit>
that can either mount / clip on the side of a> microphone stand or> double-sided
sticky tape to my guitar.> > I only need to send. No MIDI in or MIDI through
is> needed.> > Thanks in advance. I look forward to the group> ideas.> > >
Thanks,> > Bill Bores> www.cypressguitars.com> > > > > To UNSUBSCRIBE, just send
mail to:> basicstamps-unsubscribe@yahoogroups.com> from the same email address
that you subscribed. > Text in the Subject and Body of the message will be>
ignored.> > > Your use of Yahoo! Groups is subject to>
http://docs.yahoo.com/info/terms/ > >
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
Phil.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, May 27, 2002 6:56 PM
Subject: Re: [noparse][[/noparse]basicstamps] MIDI Patch Controller
> take a look at this site for [url=ideashttp://www.audiomulch.com/midipic/]ideashttp://www.audiomulch.com/midipic/[/url]
