serin/serout
Hello everyone. I'm having some trouble with getting a BS2 and BS2SX
to communicate using serin and serout. I programed each with the
example code from the BS2 manual(v1.9 page 318) and then I hooked
them together, but it didn't work. I eventually want to be able to
communicate wirelessly with the HP-900 series transmitter and
reciever from Linx Technologies. Does anyone know what I'm doing
wrong? Thanks.
wrong? Thanks.
a problem.
check out the v.2 manual for the correct bs2sx
calc.
ian
Original Message
To: basicstamps@yahoogroups.com <basicstamps@yahoogroups.com>
Date: Tuesday, January 01, 2002 9:19 AM
Subject: [noparse][[/noparse]basicstamps] serin/serout
>wrong? Thanks.
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Like Ian said, check the baud rate table in the manual. Also, double
check your connections to make sure they are correct. A note of
caution. If you plan on writing your own codes to network both
stamps, put a 1 K resistor in between the pins that are used
as "communication ports". If you have flow control line, the same
must be done. Otherwise, you might end up burning one or both of your
Stamps. Like Jon says to everyone, it is cheap insurance.
RP
--- In basicstamps@y..., "sethjaredjeromiejohnson" <sjohns10@h...>
BS2SX
> wrong? Thanks.
data from the BS2sx, and the sx sends one byte of data. I am using
flow control and my commands look like this:
BS2P40
serout 12\13, 16624,[noparse][[/noparse]dec y]
serin 12\13, 16624, [noparse][[/noparse]dec order]
BS2SX
Await_Instruction:
serin 6\7, 16624,[noparse][[/noparse]dec Instruction]
Branch Instruction,[noparse][[/noparse]Await_Instruction,Check_swr]
serout 6\7, 16624, [noparse][[/noparse]dec order]
I want to send 3 more numbers across now. How can I send four
numbers at once, or do I have to stack serin/serout commands. The
following does not seem to work.
Serout 12\13, 16624,[noparse][[/noparse]dec order,dec swr(1),dec swr(2),dec swr(3)]
Serin 12\13, 16624,[noparse][[/noparse]dec order,dec swr(1),dec swr(2),dec swr(3)]
You can serout:
serout 0, N9600, [noparse][[/noparse]"a", "b", "c"]
but in order to receive it you have to write serin 0, N9600, [noparse][[/noparse]str namestr\3]
namestr would have to be declared as namestr var byte(3)
Sid
BS2P40
Send request for data-
& wait for data-
BS2SX
Await_Instruction:
& send data-
Any help would be appreciated!
Jim
be one, two or three bytes. (e.g., "1", "12" or "123"). The SEROUT
needs punctuation, so that the SERIN can tell when one number ends
and the next begins.
Serout 12\13, 16624,[noparse][[/noparse]dec order,tab,dec swr(1),tab,dec swr(2),tab,dec swr(3)]
Alternatively, they could all be sent and received using the DEC3
modifier, always 3 bytes, and the whole string is always 12 bytes:
Serout 12\13, 16624,[noparse][[/noparse]dec3 order,dec3 swr(1),dec3 swr(2),dec3 swr(3)]
Serin 12\13, 16624,[noparse][[/noparse]dec3 order,dec3 swr(1),dec3 swr(2),dec3 swr(3)]
But that is limited to numbers (0-999).
if the numbers are always bytes (0-255), you could send them as just
4 bytes, which is much faster:
Serout 12\13, 16624,[noparse][[/noparse]order,swr(1),swr(2),swr(3)]
Serin 12\13, 16624,[noparse][[/noparse]order,swr(1),swr(2),swr(3)]
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
>I currently have a BS2P40 talking to a BS2SX. The BS2P40 requests
>BS2P40
>& wait for data-
>BS2SX
>Await_Instruction:
>& send data-
>Jim
>Subject and Body of the message will be ignored.
Thank you for the advice. In the meantime, I have proven you are right. swr
is only a one digit number, that I only want to display, not calculate. So I
have gotten around it with strings.
serout 6\7, 16624, [noparse][[/noparse]dec order,str swr\4]
I will try your suggestion and see if I can deal with numbers, but after
studying yours, I am sure yours will work also.
Thanks again.
Jim
I think the problem may be you're SEROUTing an unbroken stream of
ASCII numbers which the SERIN is unable to separate into distinct
representations of variable values.
For instance, if order = 1, swr(1) = 234, swr(2) = 56, swr(3) = 78,
the SEROUT will send "12345678". The SERIN will unsuccessfully
attempt to assign 12345678 to order, leaving nothing from the input
stream for the other variables.
Try using constant length DEC representations or delimiters to break
the data stream up into its logical pieces:
Serout 12\13, 16624,[noparse][[/noparse]dec2 order,dec3 swr(1),dec3 swr(2),dec3 swr(3)]
Serin 12\13, 16624,[noparse][[/noparse]dec2 order,dec3 swr(1),dec3 swr(2),dec3 swr(3)]
Serout 12\13, 16624,[noparse][[/noparse]dec order, ",", dec swr(1), ",", dec swr(2), ",", dec
swr(3), ","]
Steve
jcfjr007 wrote:
> ...How can I send four numbers at once, or do I have to stack
> serin/serout commands. The following does not seem to work.
SEROUT DOUT, Baud, [noparse][[/noparse]d0, d1, d2, d3, d4, d5, d6, d7] versus
SEROUT DOUT, Baud, [noparse][[/noparse]d0]
SEROUT DOUT, Baud, [noparse][[/noparse]d1]
etc. to
SEROUT DOUT, Baud, [noparse][[/noparse]d7}?
I have another BS2 expecting 8 bytes of data (using SERIN DIN, Baud,
[noparse][[/noparse]d0, d1, d2, d3, d4, d5, d6, d7] and was wondering if 8 separate
SEROUT can send data without timing issues.
Can someone please help?
calls to the SEROUT function, will consume quite a bit more EEPROM
space. You can verify this with the Memory Map tool in the editor.
-- Jon Williams
-- Parallax
Original Message
From: yellowniter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=26nJg6Qqwgs3VLO-kpV_KdVOh3Fo_WzrCP-lWpHvoXbJvsNL8D4RKMl5Kp9kPkpEFQ2GzuFfCHoJO1DddSTEgw]yellowniter@y...[/url
Sent: Thursday, July 17, 2003 10:19 AM
Subject: [noparse][[/noparse]basicstamps] Serin/Serout
Is there a difference between
etc. to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
command interpretation time between bytes
in the second instance.
(You can do the same thing, with less
use of EEPROM, with a FOR loop)
So if your goal was to put additional
space between the bytes, so the receiving
BS2 has more time, yes, that should work.
For this to work, however, you must
insure somehow that the receiving BS2 is
waiting on 'd0' when the transmitting BS2
starts sending 'd0'.
--- In basicstamps@yahoogroups.com, "yellowniter" <yellowniter@y...>
> etc. to
Baud,
