A to D conversion...
Hey folks,
Discovered today how easy A to D conversion can be. This is going to help a
lot in designing the Data Logger I'm thinking about.
See the url below for a demo circuit and code. Click on A to D Converter.
http://www.lennard.net.nz/electronics/electronics.html
cheers,
Ben, Wellington, New Zealand.
Ben Lennard, NCEE, Dip EE
Web Hosting and Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
>From: Leroy Hall <leroy@f...>
>To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] Any Power Engineers Lurking?
>Date: Tue, 21 May 2002 5:52 AM
> I think I understand your situation a little better than what was
> before. I assumed you were using commercial equipment, a mistake on my
> part. Your statement, "I am trying to assess the net effect on the
> primary side of the coupling transformer, i.e.: as long as the rectifier
> is fairly well balanced, there should be no DC reflected back, right?"
> is new to me. I have heard of power reflected in an RF radio type
> situation, we call it SWR. But I have not heard of DC being reflected
> back across the winding of a x-former. MAybe we could discuss the
> situation off list. if you like. Sounds interesting at the very
> least.. I consider myself more a controls engineer, in that I have
> expertise in PLC.s but power control is also very interesting although
> my experience there is limited more to the theoretical rather than the
> practical side. Good luck..
> Leroy
> "Chris Loiacono (E-mail)" wrote:
>> I have an AC Phase-angle power controller design that I am trying to fit to
>> a customer's application.
>> I mention it here because there are experts here in every field, it seems,
>> although the part of it I'm working on is basically an AC Power EE problem:
>> The controller fires gates on SCR/Diode pairs on each leg of a three phase
>> load. The zero-crossing timing is derived optically from the AC line, and
>> the command input to the PIC sets the gate delay, or phase angle to fire at.
>> It was intended for resistive loads, where the relationship between voltage
>> and current is quite simple.
>> I need to use it to gate the SCR's into a transformer primary, which is a
>> simple 3-wire delta. The secondary is through a three-phase bridge rectifier
>> to a wye connected resistive load. You might envision it feeding the
>> resistive equivalent of a 3-phase AC motor stator, but ignore the concept of
>> motion.
>> I am trying to assess the net effect on the primary side of the coupling
>> transformer, ie: as long as the rectifier is fairly well balanced, there
>> Will the current at the transformer primary lag, and will that effect my
>> zero-cross detect timing, since it is done by LED's? If so, the controller
>> will fire past the zero-crossings and make some spectacular fireworks, since
>> it deals with hundreds of Volts at hundreds of Amps.
>> Please let me know if anyone has experience with this sort of thing that
>> would like to discuss it either on or off-list.
>> Chris
>> To UNSUBSCRIBE, just send mail to:
>> basicstamps-unsubscribe@yahoogroups.com
>> from the same email address that you subscribed. Text in the Subject and
> Body of the message will be ignored.
>> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
cheers,
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
> Leroy
>> motion.
>> Chris
from the TLC548CP pointing at the 47k resistor?
Don
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, May 23, 2002 4:41 AM
Subject: [noparse][[/noparse]basicstamps] A to D conversion...
> Hey folks,
a
> cheers,
> Hm: +64 4 972 7567
> Mb: +64 21 536 627
> 87 Spencer Street
> Crofton Downs
> Wellington
> New Zealand
be."
> > Leroy
fit to
seems,
problem:
phase
and
fire at.
voltage
a
rectifier
concept of
> >> motion.
coupling
there
my
controller
since
that
> >> Chris
and
and
normally the middle pin.
>From: "Don" <renegade.engineer@v...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] A to D conversion...
>Date: Thu, 23 May 2002 07:40:42 -0700
> Ben, in the diagram on that link, what is the significance of the
>arrow
>Don
Original Message
>From: "Ben Lennard" <postmaster@s...>
> > Hey folks,
>help
>a
>Converter.
> > cheers,
> > Hm: +64 4 972 7567
> > Mb: +64 21 536 627
> > 87 Spencer Street
> > Crofton Downs
> > Wellington
> > New Zealand
>is
>be."
>rectifier
> > > Leroy
>fit to
>seems,
>problem:
>phase
>and
>fire at.
>voltage
>is
>a
>rectifier
>concept of
> > >> motion.
>coupling
>there
>my
>controller
>fireworks,
>since
>that
> > >> Chris
>and
>and
>and
_________________________________________________________________
Meld je aan bij de grootste e-mailservice wereldwijd met MSN Hotmail:
http://www.hotmail.com/nl
here. Look at
http://www.lennard.net.nz/electronics/ad.html
The arrow in question appears to be connected to the A-D converter chip, but
there is no pin identification associated with the IC. If it were meant to
indicate a variable resistor, I would expect the arrow to pass through the
resistor and not show an apparent physical connection to another device. To
me, the drawing seems to indicate a standard resistor, as it doesn't
indicate a high-low range for the resistor.
Don
Original Message
Sent: Thursday, May 23, 2002 9:11 AM
> An arrow in an resistor means it is a variable resistor. Physical, it is
> >arrow
> >Don
Original Message
> > > Hey folks,
> >help
> >a
> >Converter.
> > > cheers,
> > > Hm: +64 4 972 7567
> > > Mb: +64 21 536 627
> > > 87 Spencer Street
> > > Crofton Downs
> > > Wellington
> > > New Zealand
> >is
> >be."
you
that
my
> >rectifier
right?"
reflected
although
the
> > > > Leroy
to
> >fit to
> >seems,
> >problem:
three
> >phase
line,
> >and
> >fire at.
> >voltage
which
> >is
> >a
> >rectifier
the
> >concept of
> > > >> motion.
> >coupling
> >there
effect
> >my
> >controller
> >fireworks,
> >since
> >that
> > > >> Chris
Subject
> >and
Subject
> >and
> >and
chip handy to give you a pin number
Don wrote:
> Yes, I know about variable resistors, but I'm not sure that is the case
> here. Look at
> Don
Original Message
> From: "SX-2 commander" <sx2_commander@h...>
> > >arrow
> > >Don
Original Message
> > > > Hey folks,
> > >help
> > >a
> > >Converter.
> > > > cheers,
> > > > Hm: +64 4 972 7567
> > > > Mb: +64 21 536 627
> > > > 87 Spencer Street
> > > > Crofton Downs
> > > > Wellington
> > > > New Zealand
> > >is
> > >be."
> you
> that
> my
> > >rectifier
> right?"
> reflected
> although
> the
> > > > > Leroy
> to
> > >fit to
> > >seems,
> > >problem:
> three
> > >phase
> line,
> > >and
> > >fire at.
> > >voltage
> which
> > >is
> > >a
> > >rectifier
> the
> > >concept of
> > > > >> motion.
> > >coupling
> > >there
> effect
> > >my
> > >controller
> > >fireworks,
> > >since
> > >that
> > > > >> Chris
> Subject
> > >and
> Subject
> > >and
> > >and
> from the same email address that you subscribed. Text in the Subject and Body
The base of the arrow seems to be pin 2, Analog In.
The variable resistor's range is roughly 0-47k ohms. Datasheets pages 7-8
will help you figure out what resistor range to use (the variable resistor
uses the wiper to divide the pot into the pair of "fixed" resistors that is
shown on the datasheet diagram).
Daniel
Original Message
> From: Don [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4lvPT1mSet2JKnz7cwTREkcsyNKR6Tip1DhuT7XME7OtTnKpYrMhJWOjV2u7uevWmgzkqZsYf-N6BYCBO8ZI1twkg4HTMw]renegade.engineer@v...[/url
> Sent: Thursday, 23 May 2002 12:19
> is the case
> here. Look at
> converter chip, but
> were meant to
> device. To
> Don
Original Message
> > >arrow
> > >Don
Original Message
> > > > Hey folks,
> is going to
> > >help
> > >a
> > >Converter.
> > > > cheers,
> > > > Hm: +64 4 972 7567
> > > > Mb: +64 21 536 627
> > > > 87 Spencer Street
> > > > Crofton Downs
> > > > Wellington
> > > > New Zealand
> > >is
> it needs to
> > >be."
> although the
> you
> that
> backwards.
> mistake on
> my
> effect on the
> > >rectifier
> right?"
> reflected
> discuss the
> that I have
> although
> the
> > > > > Leroy
> to
> > >fit to
> every field, it
> > >seems,
> AC Power EE
> > >problem:
> three
> > >phase
> line,
> > >and
> phase angle to
> > >fire at.
> > >voltage
> which
> > >is
> > >a
> three-phase bridge
> > >rectifier
> the
> > >concept of
> > > > >> motion.
> > >coupling
> balanced,
> > >there
> effect
> > >my
> > >controller
> > >fireworks,
> > >since
> sort of thing
> > >that
> > > > >> Chris
> Subject
> > >and
> Subject
> > >and
> the Subject
> > >and
> Subject and
wiper.
The line from the IC is it's Analogue input (pin 2).
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
>Date: Fri, 24 May 2002 2:40 AM
> Ben, in the diagram on that link, what is the significance of the arrow
> Don
Original Message
>> Hey folks,
> a
>> cheers,
>> Hm: +64 4 972 7567
>> Mb: +64 21 536 627
>> 87 Spencer Street
>> Crofton Downs
>> Wellington
>> New Zealand
> be."
>> > Leroy
> fit to
> seems,
> problem:
> phase
> and
> fire at.
> voltage
> a
> rectifier
> concept of
>> >> motion.
> coupling
> there
> my
> controller
> since
> that
>> >> Chris
> and
> and
> here. Look at
From the verbage in the descritption and the looks of the diagram, it is
the wiper of the 47k pot connected to the input pin of the adc. Proper
schematic icon for a pot; not really but it does get the point across
IMHO.
Take Care,
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
