Strain Gage
I plan I using a cirrus, CD5532, 24 bit a/d to read my omega 3/350-ly43 strain
gage, I just thought that I would be able to see a change of resistance on my
meter. Im very fortunate that parallax has did some of the work for me with the
code listed below. Im sure I will have to change the code to read a 250lb load
cell that Im trying to build plus Im planning on using a 2 * 16 Scott Edwards
backpack. Im not really sure what size of resistor to use in my full wheatstone
bridge.Any suggestion would be great Thanks to all of you for your input to this
project.
Link to Cirrus CD5532 a/d
http://www.cirrus.com/design/applications/detail.cfm?d=7
Link to Omega sg-3/350-LY43
http://www.omega.com/toc_asp/frameset.html?book=Pressure&file=STRAIN_GAGES Page
E-9
'Program used to measure voltage analog data using a CIRRUS LOGIC
CS5532, 24
bit ADC chip
'PARALLAX BS2p24 reads I/O data from the CS5532 connected to a MUSE
M1101-20#
beam sensor
'See Crystal CS5531/32/33/34 Datatasheet (Oct '99) page 38, figure 16,
for
connection setup
'4/27/01
dathi var word '16 bit high address
datlo var word '16 bit low address
x var word 'computed data value
y var word
y1 var nib
y2 var nib
y3 var nib
y4 var nib
SCLK con 15 ' ADC Clock
SDO con 14 ' ADC Data output
SDI con 13 ' ADC Data input
CS con 12 ' Chip select
p con 0
high CS
pause 50 'delay for crystal oscillator power
up
low CS
gosub RESET
gosub LCDINIT
gosub CHIPINFO
shiftout SDI,SCLK,1,[noparse][[/noparse]%00001011] 'read configuration register 1
shiftin SDO,SCLK,0,[noparse][[/noparse]dathi\16,datlo\16]
' debug " CONFIG:",cr,"bits 31 to 16 ",bin16 dathi,cr,"bits 15 to 0
",bin16
datlo,cr,cr
dathi=%0000000000000000 'write channel setup register 1
datlo=%0000000000000000
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000101,dathi\16,datlo\16]
dathi=%0000000000000000 'write offset register 1
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000001,dathi\16,datlo\16]
dathi=%0000010000000000 'write gain register 1
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000010,dathi\16,datlo\16]
shiftout SDI,SCLK,1,[noparse][[/noparse]%00001101] 'read setup register 1
' debug " SETUP:",cr,"bits 31 to 16 ",bin16 dathi,cr,"bits 15 to 0
",bin16
datlo,cr,cr
shiftout SDI,SCLK,1,[noparse][[/noparse]%00001010] 'read gain register 1
' debug " GAIN:",cr,"bits 31 to 16 ",bin16 dathi,cr,"bits 15 to 0
",bin16
datlo,cr,cr
shiftout SDI,SCLK,1,[noparse][[/noparse]%11000000] 'contineous data conversion
lcdout p,1,[noparse][[/noparse]"CIRRUS CS5532"]
REPEAT
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000000]
' debug " DATA:",cr,"bits 31 to 0 ",bin16 dathi,cr,"bits 15 to 0
",bin16
datlo,cr
dathi=dathi<<8 'select bits 23 to 8 for
measurement
datlo=datlo>>8
x=dathi+datlo
debug " Voltage ",dec x," counts (bits 23/8)",cr,cr
if x<38600 then over
x=38600
over:
y=((38600-x)*2)/33 'convert to pounds
x=y
x=y/100
y=(y-(x*100))
lcdout p,192,[noparse][[/noparse]dec x,".",dec1 y," pounds "]
pause 500
goto REPEAT
RESET 'initialize CS5532
shiftout
SDI,SCLK,1,[noparse][[/noparse]$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FE]
dathi=%0010000000000000 'activate reset in
configuration
register
shiftout SDI,SCLK,1,[noparse][[/noparse]%00000011,dathi\16,datlo\16]
return
LCDINIT 'initialize LCD
lcdcmd p,48 'set function
pause 5
lcdcmd p,48
pause 1
lcdcmd p,48
pause 1
lcdcmd p,32
pause 1
lcdcmd p,44
pause 1
lcdcmd p,8 'display off
lcdcmd p,12 'display on
lcdcmd p,6 'set mode
return
CHIPINFO
lcdcmd p,1
lcdout p,128,[noparse][[/noparse]" BASIC Stamp2P reads Cirrus Logic CS5532 "]
for x=1 to 24
pause 200
lcdcmd p,24
next
pause 1000
lcdcmd p,1
return
Do You Yahoo!?
LAUNCH - Your Yahoo! Music Experience
project.
E-9
CS5532, 24
bit ADC chip
M1101-20#
beam sensor
for
connection setup
'4/27/01
y var word
y1 var nib
y2 var nib
y3 var nib
y4 var nib
p con 0
high CS
up
low CS
gosub RESET
gosub LCDINIT
gosub CHIPINFO
",bin16
datlo,cr,cr
",bin16
datlo,cr,cr
",bin16
datlo,cr,cr
REPEAT
",bin16
datlo,cr
measurement
datlo=datlo>>8
x=dathi+datlo
x=38600
over:
x=y
x=y/100
y=(y-(x*100))
pause 500
goto REPEAT
shiftout
configuration
register
return
pause 5
lcdcmd p,48
pause 1
lcdcmd p,48
pause 1
lcdcmd p,32
pause 1
lcdcmd p,44
pause 1
return
CHIPINFO
lcdcmd p,1
for x=1 to 24
pause 200
lcdcmd p,24
next
pause 1000
lcdcmd p,1
return
Do You Yahoo!?
Have you located a wiring schematic for this example?
Original Message
From: Jim Gorbet [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oMeK7vkFZ5L3HpYUUlH145nbJ8I-O5dOHsZrGJZR2oy1mN0H5EsFYbPcwxJB4_aTk--gdc6y80B5poXh6Q]jimgorbet@y...[/url
Sent: Monday, May 13, 2002 7:06 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Strain Gage
Importance: High
strain gage, I just thought that I would be able to see a change of
resistance on my meter. Im very fortunate that parallax has did some of the
work for me with the code listed below. Im sure I will have to change the
code to read a 250lb load cell that Im trying to build plus Im planning on
using a 2 * 16 Scott Edwards backpack. Im not really sure what size of
resistor to use in my full wheatstone bridge.Any suggestion would be great
Thanks to all of you for your input to this project.
Page E-9
CS5532, 24
bit ADC chip
M1101-20#
beam sensor
for
connection setup
'4/27/01
y var word
y1 var nib
y2 var nib
y3 var nib
y4 var nib
p con 0
high CS
up
low CS
gosub RESET
gosub LCDINIT
gosub CHIPINFO
",bin16
datlo,cr,cr
",bin16
datlo,cr,cr
",bin16
datlo,cr,cr
REPEAT
",bin16
datlo,cr
measurement
datlo=datlo>>8
x=dathi+datlo
x=38600
over:
x=y
x=y/100
y=(y-(x*100))
pause 500
goto REPEAT
shiftout
configuration
register
return
pause 5
lcdcmd p,48
pause 1
lcdcmd p,48
pause 1
lcdcmd p,32
pause 1
lcdcmd p,44
pause 1
return
CHIPINFO
lcdcmd p,1
for x=1 to 24
pause 200
lcdcmd p,24
next
pause 1000
lcdcmd p,1
return
Do You Yahoo!?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
You can find the schematic on page 42 of application sheet.
http://www.cirrus.com/pubs/cs5531-5.pdf?DocumentID=828
Fred Darnell <fdarnell@c...> wrote: Jim,
Original Message
From: Jim Gorbet [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2nMo77Y1171yGT_Kb52TVNJqqW3h7GEOJrF3KfXlu88DGmjoE1daYYlkwVO7OEgkNdQ64_4YeGV7JbDbBA]jimgorbet@y...[/url
Importance: High
Page E-9
CS5532, 24
bit ADC chip
M1101-20#
beam sensor
for
connection setup
'4/27/01
y var word
y1 var nib
y2 var nib
y3 var nib
y4 var nib
p con 0
high CS
up
low CS
gosub RESET
gosub LCDINIT
gosub CHIPINFO
",bin16
datlo,cr,cr
",bin16
datlo,cr,cr
",bin16
datlo,cr,cr
REPEAT
",bin16
datlo,cr
measurement
datlo=datlo>>8
x=dathi+datlo
x=38600
over:
x=y
x=y/100
y=(y-(x*100))
pause 500
goto REPEAT
shiftout
configuration
register
return
pause 5
lcdcmd p,48
pause 1
lcdcmd p,48
pause 1
lcdcmd p,32
pause 1
lcdcmd p,44
pause 1
return
CHIPINFO
lcdcmd p,1
for x=1 to 24
pause 200
lcdcmd p,24
next
pause 1000
lcdcmd p,1
return
Do You Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
Do You Yahoo!?
