bs2<->rs232<->PC
I'm attempting communication with bs2 stamp send
commands to Stamp bs2, have it receive it. act on it
and send back info back to the pc when done.Leaving it
in a variable.
I downloaded an experimental small term program of
Jon Williams Qterm.bas for rs232 pc to stamp
communications. When I use it I get buffer overflow
when it gets to the INPUT$ from stamp and no
communiction with the stamp. I changed the settings to
9600, No Parity, 8 bits, 1 stop,and to match in the
stamp
serin 16, 16468, 100, NONE, char
(branches to NONE: when not receiving.)
The serout in the stamp works with debug to the pc.
serout 16, 16468, 100, [noparse][[/noparse]"works"].
prints works to the screen.
Nothing else connected to com1 or com2, using com1,
can load and run to bs2
I also tried. bioscom() example in c programming
language , no works there either.
Any ideas???? thanks
__________________________________________________
Do You Yahoo!?
Yahoo! Health - your guide to health and wellness
http://health.yahoo.com
in a variable.
stamp
Do You Yahoo!?
in a variable.
stamp
Do You Yahoo!?
in a variable.
stamp
Do You Yahoo!?
