SOlid State Relays ???
I read thru all msgs about Solid State relay, and decided to buy one
online. I bought the Crydon with the spec as follows: input 3-32 V,
output 25A with 120VAC. I thought it would help me to control the lamp
on/off. But it didn't work at all. With my voltmeter, I could read
the input from my Stamp 4.8V, but no voltage at all on the other
side (output). My question is, do I have to do any extra thing to
make it work ??? I hooked my Stamp and the lamp directly to the relay.
Thanks advance for your help.
The relay is meant to switch a standard 120 volt AC line on and off when
you apply or remove the control voltage. There is no "output" per se, just
a set of solid state "contacts" activated by the input. You don't mention
a 120 volt AC power source to the lamp with the "output" of this relay in
series anywhere above. Is that an oversight or did you not connect the AC
line?
Jim H
Regarding SSR's, there are several things to watch for.
1. If the unit you bought, accepts a DC control voltage of from
3-32 V.D.C., it seems like that side of things is working.
2. Do you have the output of the SSR wired in "series" with your
lamp and the 120 VAC supply?
At the risk of being redundant, I'll explain wire by wire.
On the high voltage side you should have one wire coming from the
line side of the 120 volts, connecting it to one terminal of your lamp.
The other terminal of your lamp should connect to a fuse of some
type.
The other terminal of the fuse should connect to one of the output
connections of the SSR.
The other output terminal of the SSR should then connect back to
the other side of your 120 VAC.
Good luck
Russ
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, May 01, 2002 7:17 PM
Subject: [noparse][[/noparse]basicstamps] SOlid State Relays ???
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
reply, you would too if you were as stupid as me [noparse]:)[/noparse]
The thing that really stitched me up with SSR's was that there must be some
load on it before it will contact. For instance if you connect 120VAC to
the + terminal on the output side and + and - 5V on the input side and then
put a meter on the output side the meter will read nothing. However is you
connect a lightbulb it will work.
Obvious possibly [noparse]:)[/noparse] But I had many exciting hours working this one out [noparse]:)[/noparse]
Justin
They used triacs to control a series of 24-volt AC valves and without a load
you could not use a meter to determine if you had output or not.
Might read the poop sheet on the device and see if a minimum load is
specified. If so, I would make a load of some sort with an LED that you
could connect and test your outputs with in the field.
Original Message
> As usual if I know ANYTHING about a topic written here I feel I have to
some
to
then
you
