Newbie - Serial Comm.
Hello,
I have just started some work with a BS2 and I'm encountering a problem that
I am hoping someone might help me resolve.
I'm trying to control a projection system with the BS2 through a serial
connection. The format in which the commands must be sent to the projector
is correct, verified by a Panasonic Technician. My SEROUT command is shown
below:
SEROUT 9, 16468, 1000, [noparse][[/noparse]2,"AD01:PON",3]
However, I'm still unable to get a response from the projector. When I plug
the connector into a laptop and run HyperTerminal everything shows up as
expected.
I've been told that the projector requires a 12/-12 V signal, but someone
else told me that the 0-5V signal from the Stamp should be enough.
Any suggestions would be appreciated
Daniel Iaboni
Engineering Co-op
Fakespace Systems
below:
expected.
Daniel Iaboni
Engineering Co-op
Fakespace Systems
Well, RS232 interfacing is sometimes a black art.
A few things to think about:
1) Make sure you are using the right baud rate for the type of Stamp you
are using (they are not all the same). Since you say Hypterterminal is
OK, then I presume this is not your problem.
2) The projector is probably made to plug into a PC. PCs are DTE (Data
Terminal Equipment). That means (I'm guessing) the projector is DCE. If
you can plug a straight cable from your PC to the Stamp, you are wired
DCE also. If you want a DCE device to talk to another DCE device, you
need a null modem or cross cable. In your case, it sounds like you are
only sending data to the projector, so you can probably just reverse
your transmit pin from 2 to 3 or vice versa. Keep in mind that 25 pin
and 9 pin are "backwards". On a 25 pin DTE, pin 3 is RX. On a 9 pin DTE,
pin 2 is RX. So to hook your PC to the projector, I'm guessing you are
connecting pin 3 (DB9TX) to pin 3 (assuming the projector uses 9 pins)
or to pin 2 if it uses a DB25. The Stamp output must also connect to the
same pin.
3) The 5V signal is not within RS232 spec, but yes, it often works. The
key here is often (but not always). A MAX232 (for example, our RS1 board
at http://www.al-williams.com/awce/rs1.htm) will handle the conversion
for you simply and easily.
4) Your output in hex is 02 41 44 30 31 3E 50 4F 4E 03 (I think a colon
is 3E; I'm sure about the rest of them, but this is from memory -- man,
that's pitiful to read ASCII on sight). So my point is that the first
and last bytes are 02 and 03 (Control+B and Control+C). Is that what you
intend? Or did you mean to send ASCII 2 and 3? Does the projector
require a carriage return or anything like that?
So in summary, make sure the string is really what you intend. Be sure
you are driving the correct pin on the projector. And if all else fails,
suspect the voltage levels.
Hope that helps.
Al Williams
AWC
* Easy RS-232 Prototyping
Original Message
> From: Daniel Iaboni [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EocQNXRBvuMEpCqOn2SankdTi5Br6-NTFu3fFyKT_j7BvQDvbGsTTKeSQD3cJtEkegg7qwLDEKcGq2dgsUWlJ1qr1A]diaboni@f...[/url
> Sent: Friday, April 26, 2002 8:31 AM
> To: 'basicstamps@yahoogroups.com'
> Subject: [noparse][[/noparse]basicstamps] Newbie - Serial Comm.
> Sensitivity: Private
> Hello,
> a problem that I am hoping someone might help me resolve.
> through a serial connection. The format in which the commands
> must be sent to the projector is correct, verified by a
> below:
> projector. When I plug the connector into a laptop and run
> HyperTerminal everything shows up as expected.
> but someone else told me that the 0-5V signal from the Stamp
> should be enough.
> Thanks
> Daniel Iaboni
> Engineering Co-op
> Fakespace Systems
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Is there a way to take a program written in pbasic and change it to the
code required to work in a PIC that doesn't have pbasic in it?
thanks,
Leroy
