Button Command
You could try...
loop:
if in1 = 1 then button_is_down
goto loop
button_is_down:
pause 2000
if in1 = 1 then do_the_second_job ' if the button is still pressed, do
the second job
'put the procedure for the short button press here
do_the_second_job:
'put the procedure for the long button press here
'its a bit simple, but does the same thing.
'regds, Chris
Original Message
To: <basicstamps@egroups.com>
Sent: Wednesday, December 13, 2000 8:58 PM
Subject: [noparse][[/noparse]basicstamps] Button Command
> I have seen before on this list, someone was wanting to
> use the input command to do two different thing.
> First if the switch was pushed it would do something and if it was held
> down for a long period of time it would do something else.
> Does anyone remember this, if so could you please help me.
> Thanks
> Gene
loop:
goto loop
button_is_down:
pause 2000
the second job
do_the_second_job:
'regds, Chris
Original Message
> Thanks
> Gene
Gene
>Thanks
>Gene
Stamps-in-class has tutorial
http://www.emesys.com/EarthM/em2.pdf
covers pushbutton responding to single click, long click, and double click.
I don't usually use the button command, because specific results can
be achieved with program loops. More info about the internal workings
of BUTTON at:
http://www.emesys.com/BS2buttn.htm
-- Tracy Allen
Electronically Monitored Ecosystems
Berkeley CA U.S.A.
Original Message
Sent: Wednesday, December 13, 2000 1:58 PM
> Thanks
> Gene
Original Message
> Thanks
> Gene
Original Message
> Thanks
> Gene
Original Message
> Thanks
> Gene
When using the button command it is necessary to define a byte variable
cleared to 0 at start time.
The manual says:
BUTTON Pin, DownState, Delay, Rate, Workspace, TargetState, Address
Where workspace is the byte variable.
When using several button commands in a loop for scanning 11 push buttons
like:
code
workspace var byte 'used by button command
workspace=0
scan_buttons:
button 1,0,255,0,workspace,1,button_1_pressed
button 2,0,255,0,workspace,1,button_2_pressed
button 3,0,255,0,workspace,1,button_3_pressed
button 10,0,255,0,workspace,1,button_10_pressed
button 11,0,255,0,workspace,1,button_11_pressed
goto scan_buttons
end
code
Can I use the same byte variable "workspace" for every button command or do
I have to define a different byte variable for each button command.
like
workspace1 var byte 'used by button1
workspace2 var byte 'used by button2
workspace3 var byte 'used by button3
etc.
I hope not because this "eats" variable space ;-(
BTW has anyone ever wrote a program for controlling an H-bridge powered DC
motor activated by to pushbuttons "left" & "right" including the left and
right overrun switches?
Thanks in advance
Michel De Meester
Belgium
Met vriendelijke groetjes,
> Michel De Meester
> Biotechnisch Onderhoud
> Universitair Ziekenhuis Antwerpen
> Wilrijkstraat 10
> 2650 Edegem - B
> tel: ++32 (0)3 821 36 47
> e-mail: michel.de.meester@u...
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
Original Message
From: De Meester, Michel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lyRvyZxe5rwFj5J474_1mo8C3eOuMhvR1JZebFDRL7h98koQFgcULd-0Gr7qsrjGQ4eHKVBLEPfEdZ614gJMfwbcHUpE]Michel.De.Meester@u...[/url
Sent: Tuesday, October 16, 2001 2:12 AM
To: 'basicstamps@yahoogroups.com'
Hello Stampers,
The manual says:
like:
code
workspace=0
scan_buttons:
goto scan_buttons
end
code
like
etc.
Thanks in advance
Michel De Meester
Belgium
> Michel De Meester
> Wilrijkstraat 10
> 2650 Edegem - B
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
but not when the 'debug' is 'rem'd out?
Any clues?
CL
behaves the same way. Just always put the "Hello World" line in there at
the top of the program and everything will work out.
Original Message
> Why might a button command work properly with a 'debug' in a target loop,
> Any clues?
My guess is you are experiencing debounce effects.
With the debug in place your switch gets enough time
to settle. Without debug the time is too short.
Try increasing the debounce delay in the button command.
To effectively suppress debounce effects place a small
cap between your stamp pin and gnd (assuming you have a pullup resistor)
Regards peter
Oorspronkelijk bericht
Van: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vDE67RUe-AOUaGy921zTMCJM0qvZXiPYCP4OQhq7CusTOmjTTvRxKr9BPosMXvSxEpA1bWv2AgzQntygRw]chris@m...[/urlNamens Chris Loiacono
(E-mail)
Verzonden: donderdag 20 december 2001 19:41
Aan: Basicstamps Group (E-mail)
Onderwerp: [noparse][[/noparse]basicstamps] Button command
Any clues?
CL
Original Message
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3heUClSXFrls0G0k2tEWT_hJTJroAuvEAquD5wLsOvRNdeKPgvYPv9wTxSv36doli_aUTlLKPvGYSDhUmw]chris@m...[/url
> Sent: Friday, December 21, 2001 8:30 AM
> Subject: RE: [noparse][[/noparse]basicstamps] Button command
> Thanks. That's what I was afraid of. *** Device
> Limitations***, or unexplainable phenomena, only the effects
> of which are visible.
> > This sounds like one of those Stamp issues. I think the
> > FREQOUT command
> > in there at
Original Message
> > a target loop,
> > > Any clues?
Original Message
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CFucUdPfGJxYojS69br5x3-9XaYo8hV3gFUv1IQk9YaW5C7-GTf4Kj8k3hYiA-Zzy_0DSxQePj4Zx9aH]chris@m...[/url
> Sent: Friday, December 21, 2001 8:35 AM
> Thanks Peter,
> Been there, done that (though it's not often the case).
> I've tried longest delay, "decoupling" the signal, and yes -
> it is pulled up.
> Nada, nada. (Or is it yada, yada - OK to poke fun at myself, no?)
> I may just leave the extra statement in the program. I sure
> would like to understand why this is happening....Jon, are
> you listening?
> Chris
Original Message
> > From: peter verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kQiZPwhoK1A_u63oQvsCq5ZHyx2Htvvph6sFZRKdJUwK_jFttjO_a4HPc6Ashhy5uCDv0djDVfaBhSUcBY7wvtw]peterverkaik@b...[/url
> > Sent: Friday, December 21, 2001 7:46 AM
> > To: basicstamps@yahoogroups.com
> > Hi,
> > pullup resistor)
> > Regards peter
I don't use button that often but never had that problem.
If you replace the debug statement with pause 10
does the button command work properly then?
Just to rule out debouncing.
Regards peter
Van: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9uGOqOgdr3l5AY0IYVa7AVOhKk5yAxdycjHEZ5y4chaiB5xHF3nxhfk4EFznmrOHxlGJmqnL2H90vIA]chris@m...[/urlNamens Chris Loiacono
(E-mail)
Verzonden: vrijdag 21 december 2001 6:25
Onderwerp: FW: [noparse][[/noparse]basicstamps] Button command
Original Message
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9uGOqOgdr3l5AY0IYVa7AVOhKk5yAxdycjHEZ5y4chaiB5xHF3nxhfk4EFznmrOHxlGJmqnL2H90vIA]chris@m...[/url
> Thanks Peter,
> it is pulled up.
> you listening?
> Chris
Original Message
> > From: peter verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hFSIVccb9tj6Ptovdqh4jf8T8VeKg9ny5WtveBOnHGmw_fy8FnZ_tekf3gycSszasK7iWcyJB3zwAL0pqo6c5Ms]peterverkaik@b...[/url
> > Hi,
> > pullup resistor)
> > Regards peter
>Any clues?
>CL
Hi Chris,
What is the shortest program you can come up with that illustrates
this problem? I can't believe it is _that_ mysterious!!!
-- Tracy
problem and it might be a W2K problem and not a BS problem.
hankster
--- In basicstamps@y..., "Chris Loiacono (E-mail)" <chris01@t...>
target loop,
> Any clues?
> CL
I have to check the state of four push buttons for starting and stopping dc
motors (btw the problem with th H-bridge is solved I use a L298 now)
wath do I want exactly to do:
when the button "left" is pressed, the motor start turnig lef (until it
reaches an overrunswitch)
when the button "left" is pushed again notting will happen
when the button "right" is pressed while the motor runs left, the motor has
to stop
when the button "right" is pressed again, the motor start turnig right
(until it reaches an overrunswitch)
the motor can then be stopped by pressing the "left" switch and restarted
left (or right) and so on
What is the problem:
When I push the "left" button the motor start turning left
When I then push the "right" button to stop the motor, the motor stops, but
starts immediatly turning right because the program loop in wich the inputs
are scanned is already executed again and still sees the "right" button
pressed (he is of coarse still pressed, the stamp is just to fast ;-)
Isn't here a way to scan for the high to low change of an input, so holding
down th input will only trigger once the subroutine jump.
Thx in advance
the program listing kan be found at
http://users.pandora.be/jff/tankmotorsturing/tankmotorsturing.html
> Michel De Meester
> Wilrijkstraat 10
> 2650 Edegem - B
>to stop
Here is a way to do it, as a state machine. The keyDetect routine
uses the xor operator (^ on the stamp) to flag the _change_ 1 --> 0
in the input state of the switches. There are state variables for
the old and new state of the 4 switches, and also a state variable
for the key change. Also a state variable for the motors.
motor var nib ' two bits for each motor.
' xx00=stop, xx01=right, xx10=left
' 00xx=stop, 01xx=right, 10xx=left
keys var nib ' new state of switches
key0 var nib ' old state of switches
keyx var nib ' change in state of switches
key0 = inA ' state at start
keyDetect:
keys=inA
keyx=keys^key0&key0 ' detects change 0-->1
key0=keys
if keyx then processKey ' do only if key press
goto loop
processKey:
motor=motor|keyx ' set the direction bit
if motor&%0011<>%0011 then p1 ' xx11 --> xx00
motor=motor&%1100
p1:
if motor&%1100<>%1100 then p2 ' 11xx --> 00xx
motor=motor&%0011
p2:
outA=motor ' set motor direction
goto keyDetect ' look for key action
Here is an alternative for the processKey routine, that uses static
logic operators instead of if-then to get the motor state. The
variable keys is reused as a scratch variable. (You don't really
need the variable motor in any of this--it too is really a scratch
variable.)
process:
motor=motor|keyx
keys=motor&%1010>>1&(motor&%0101)
keys=keys<<1|keys
motor=motor&~keys
outA=motor
goto loop
I hope that helps. I have more write-up on state machines at
<http://www.emesystems.com/BS2fsm.htm>
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
In looking at my earlier post on the state logic, I wanted to clean
it up a bit.
' 4 switches on 4 bits of inA, active low
' 2 motors on 4 bits of outB, bits in pairs
' motor 1: xx01 right, xx10 left, xx00 stop, xx11 not allowed
' motor 2: 01xx right, 10xx left, 00xx stop, 11xx not allowed
key0 var nib ' store prior state of keys
keys var nib ' current state of keys
keyx var nib ' change in state of keys
X var keyx ' temporary variable, =keyx
Y var keys ' ditto, =keys
dirB=%1111 ' all outputs for motors
key0 = inA ' startup state of keys
keyDetect:
keys=inA ' get current key state
keyx=keys^key0&key0 ' detects change 1-->0
' change --> bit=1 in keyx
key0=keys ' renew prior state
goto keyDetect
processKey: ' enter with keyx<>0
X= outB | keyx ' tentative state of motors
Y= (X & %1010 >> 1) & (X & %0101) ' detects %11 pair(s)
Y= Y << 1 | Y ' creates %11 mask
outB= X & ~Y ' final state of motors
goto keyDetect
For example, if the current output happens to be outB=1001, then
motor 2 is turning left and motor 1 is turning right. All keys are
up, %1111. If the user now presses the button in position %1101, the
keyDetect routine catches the change and jumps to processKey with
keyx=%0010. When keyx is ORed with the current motor state, outB,
that makes the tentative motor state X=%1011. The next two lines
starting with "Y=" detect the 11 pair in the two low bits and create
a mask %0011. The final expression then ANDs the tentative state
with NOT ("~") the mask, to give the new motor state, %1000. Motor 1
stopped. The user has to release the motor 1 "left" button and then
press it again to generate another keyx event. (That was your
question.) This time through processKey, the tentative motor state
is 1010. The cross terms are all zero, so the NOT~mask is ~Y=%1111,
and the final motor state is %1010, both motors turning left.
The nice thing about using math (instead of if-then) to detect the
%11 condition is that it takes exactly the number of lines of code to
do 8 switches and 4 motors, simply by using bytes instead of nibs.
-- best regards
Tracy Allen
http://www.emesystems.com/BS2fsm.htm <--- more state machines!
mailto:tracy@e...
>it>reaches an overrunswitch)
>to stop
http://www.emesystems.com/BS2fsm.htm#BUTTON
-- Tracy
>I'm a newbie and need a bit of help...
>Perhaps someone could explain the BUTTON command a bit
>more in depth for me. The manual just seems to
>confuse me. For instance, downstate vs.
>targetstate...wha??
>I'm am trying to set up something with a number of
>momentary switches, and depending on which one is
>depressed at any one moment, send specific serial info
>to a PC. It would be nice to be able to detect
>multiple closed switches, but for now I'm just going
>for one at a time.
>My switches are set up in an active-low state. I keep
>getting repeat while the button is depressed or
>infinite repeat while open. The sample code in the
>manual doesn't help much... any suggestions?
>Thanks,
>--Andrew
>__________________________________________________
>Do you Yahoo!?
>Yahoo! Shopping - Send Flowers for Valentine's Day
>http://shopping.yahoo.com
>Subject and Body of the message will be ignored.
for me) -
Suppose we have a pin that is HIGH until the switch is pressed.
Wait in a loop until the pin goes LOW.
PAUSE for a few milliseconds to let contact bounce subside (I tend to use
10 to 50 ms)
If the pin is no longer low, then this was just bounce or noise - ignore it
- go back to waiting until pin goes low
If pin is still low, then loop until it goes high again - when it does, the
user has released the button and you can do what you want.
A better way (but hard to do on the stamp - I do this with a PIC) is to
actually measure the time that the button is down and if it is greater
than the bounce time (e.g. 10 ms), consider the button to be pressed. This
is easy on a PIC where you can actually measure times. If you have a good
idea of the instruction timings on the stamp, you can measure time by the
number of passes though a loop.
Larry
At 07:39 AM 2/13/2003 -0800, you wrote:
>Thanks for the article, Tracy.
>As a conclusion, am I right to assume that more than
>one switch using the BUTTON command is too much
>trouble than it's worth? Is a state machine always
>easier?
>Thanks again,
> >Andrew
>Do you Yahoo!?
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
I'd say, the BUTTON command is overkill unless you need the
auto-repeat capability. Each BUTTON needs one byte for workspace,
whereas for simple debounce or state transition detection all that is
necessary is one bit. That really adds up if you have many buttons.
-- Tracy
>easier?
>Thanks again,
> >Andrew
You need to store both the current state of InA and the previous
state, There is one bit in each nib for each button, for its present
and previous state, 0=down and 1=up. When a bit changes from 0 to 1,
then you do your SEROUT for the corresponding button(s). You have to
have both the previous and present state in order to detect changes.
Example (taken from my URL on state machines)
'($PBASIC 2.5}
do
x1 = inA ' get state of all 4 input pushbuttons or sensors
xx=x1^x0&x1 ' detect changes, bit =1 when button is released
x0=x1 ' update old state of all 3 buttons
if xx.bit1=1 then debug "second button",cr
loop ' over and over
The third nib variable xx is for the transitions. The computation
uses the boolean AND and XOR operators. ("&" and "^" in Stampese)
-- regards
Tracy Allen
mailto:tracy@e...
>Ok...I see the light at the end of the tunnel.
>Thanks for all the input from everyone. I've got my
>switches reading accurately and reliably.
>One final quesiton [noparse];)[/noparse] I am trying to send a character
>via SEROUT depending on which switches are triggered
>("0", "1", "2", etc.).
>If I were to test InA and receive back %0010 (telling
>me that pin1 had just been pressed & released), how
>could I translate that into 'if bitX = 1 then serout
>"X"'...?
>Thanks,
>--andrew
switch. I connected IO pin 8 to +5 and the switch, and I connected
the ground to the other side of the switch. When I press the switch
it debugs "notpressed" just as it should. The problem is, it works on
any IO pin, not just 8. want to use button to monitor many switches
not just one and it wont work it this happens. Any help is appreciate.
'{$STAMP BS2}
Bttn var byte
Bttn=0
Loop:
button 8,0,255,250,Bttn,0,NotPressed
debug "button pressed!"
NotPressed:goto Loop
to use through a seperate resistor ( 4.7K) is fine to +5volts and the other
end to the stamp pin. Connect the switch between the stamp pin and ground.
When you press the button, the voltage will be dropped through the resistor
and the stamp will see a low and detect it. I suspect you are just pulling
down the 5 volt supply causing erroneous readings. If you wish to look at
several switches, wire each like this and instead of goto loop, call the
next button routine and on the last, goto loop.
jim
http://geocities.com/jimforkin2003/
Original Message
From: mstroboto2003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=u8hxbKt3pCLroH-3kjczDJel4f5XKxKqPu9IFyFa2HxsDlJui_Lu4zfAuACR1E9ImiTMGAK2ehHIOCI1]monkeymack@a...[/url
Sent: Monday, May 12, 2003 6:39 PM
Subject: [noparse][[/noparse]basicstamps] button command
I used the following commands to check the state of a mechanical
'{$STAMP BS2}
Bttn var byte
Bttn=0
Loop:
