MIDI
Hi, i want to build a MIDI controller pedal that allows to change
presets from my Digitech RP2000 guitar effects pedal, anybody can help
me?
me?
Thanks for the response. My message was a little short
in background info. I tinker with stuff but know
precious little about these sorts of things.
What I'm trying to do is to build a midi controller
built around a series of resistors. +5 volts at one end
deviding the octaves in 1/12 increments by the resistors,
with two octaves total. So at the lowest end +3 volts
and at the top +5.
The volt per octave synthesizers like Moog work this way.
So in essence I'm converting control voltage in the 3 to
5 volt range divided into 1/12 segments into midi note
on/off messages.
> Well, it depends on how fast (how many times a second) you need it to go.
> You could use a Dallas Semiconductor Analog to Digital Converter chip such
> as the DS2480s.
> Reference www.maxim-ic.com and go to their 1 wire section. The ADC maybe is
> overkill, but fairly easy to use and only uses one I/O pin on the Stamp.
> The Stamp MCU would use the ADC to read the voltage level to get a value
> reference to it.
> Then the Stamp can convert it into a value that could be outputted to
> something. I forget
> what midi would want at the moment.
> But if you are only looking for two different voltages, you could use a
> LM311 or 339 comparator to convert the level into 1's and 0's for the Stamp
> chip. A resistor network might work as well too.
> If it has to do this thousands of times a second, you'll have to use a fast
> ADC and a MCU that you program in it's machine language to perform the input
> conversion to output conversion.
> If it's even faster, you'd have to use a DSP (Digital signal processor)
> designed for the high speed.
Original Message
> From: jacksonknobs [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5JYyFSQ6DPmx4ba_QXcUqEy5kyl4cVurk1Qx5tc_BBL55Vahgxk6Q6KjKwHAGaXibbKa6coamiA]guess@a...[/url
> Sent: Wednesday, April 17, 2002 11:23 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] midi note info from a Parallax Basic Stamp 2
> Dear Group,
> My desperate need for a control voltage to midi note on/off converter
> has brought me to this forum.
> What I need is a means for converting +1 - +5 volts into midi note
> on/off messages via a single source switch.
> Can this be done with this device?
> Thanks in advance,
> Bill Guess
> Baton Rouge, La
> guess@a...
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> from the same email address that you subscribed. Text in the Subject and Body
octave you want. Then feed the outputs into the Stamp I/O pins. But you may
run out of I/O pins on the Stamp.
A better way is to use the Dallas DS2480 quad ADC chips and run as many as
you need to get all the octaves your after. You can run all of them off of
the 1 wire databuss.
Once you get your voltage levels you can then output the data via a midi
interface to whatever you want.
The ADC's are 16 bit devices so you can take 0 to +5 volts and have 65525
separate steps or increments from 0 to +5 volts. It should give you
sufficient resolution.
Original Message
From: guess@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FcesuVlDa7nWJpDgvbcOIiBtLWUxokU9qn50w4j_UEuwaGz0GxqSfc1nLCBNcZFTTVTRyA]guess@a...[/url
Sent: Thursday, April 18, 2002 9:44 AM
Dear Earl,
and at the top +5.
on/off messages.
> as the DS2480s.
is
> reference to it.
> something. I forget
Stamp
fast
input
Original Message
> From: jacksonknobs [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FcesuVlDa7nWJpDgvbcOIiBtLWUxokU9qn50w4j_UEuwaGz0GxqSfc1nLCBNcZFTTVTRyA]guess@a...[/url
> Dear Group,
> Thanks in advance,
> Bill Guess
> Baton Rouge, La
> guess@a...
Body
