Wwvb/wwv clock
STAMPERS:
Has anyone out there interfaced a WWVB/WWV clock to a
STAMP II. The Ultralink clock offered is no longer
available, so that is no longer an option! Is there a
current substitute clock?
thanks
Tom
__________________________________________________
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
thanks
Tom
Do You Yahoo!?
Maybe you could hack one of the WWV clocks they sell various places for
$20-40?
Original Message
> STAMPERS:
http://psn.quake.net/sdrdocs/wwvcorr.htm
The Canadian version of WWV actually sends out a 300 baud modem FSK signal
at regular intervals.
Which is the same signal they send out when you dial in on their data lines.
So one could feed the audio into a modem to get the signal decoded into a
serial stream.
But you have to be up near the Canadian borders to be able to receive this
radio signal.
Original Message
From: Tom Peterson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6cZJLeGWr20EiOhF9ZAgrqxPW_whQH5SzvQbFAp3RFAYx3CxxwTLKscXO7wJ2IB4dEyomQSp5A]techmon@y...[/url
Sent: Tuesday, April 16, 2002 6:26 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] WWVB/WWV CLOCK
STAMPERS:
thanks
Tom
Do You Yahoo!?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>The only thing I found was this:
>baud modem FSK signal at regular intervals.
>signal decoded into a serial stream.
>able to receive this radio signal.
The signal from CHU is Bell 103 compatible. Full details are here:
http://www.nrc.ca/inms/time/chu.html
The broadcasts on 7335 kHz and 14670 kHz should be receivable anywhere in
the USA, though maybe not 24 hours a day. 7335 would tend to be better at
night while 14670 would tend to be better in the day. Both of them are
clear as a bell at S-6 on my signal strength meter as I type this at about
9:30 AM. I'm located in South Carolina and have a ground mounted vertical
antenna. A 3-foot whip sticking out of the radio won't work as well, but
it should work as well as any "Atomic Clock Radio" that uses the WWVB
system based on 60 kHz out of Fort Collins, CO. Info on WWVB is at:
http://www.boulder.nist.gov/timefreq/stations/wwvb.htm
Jim H
WWVB and other time receivers.
http://www.boulder.nist.gov/timefreq/general/receiverlist.htm
