Bs2sx programm for unipolar 4 phase stepping motor
hi, i am required to learn BS2SX programming for examination
purposes. However , i do not understd what does outa=1,2,4 mean.Thx.[noparse]:)[/noparse]
outa=1
pause delay
outa=2
pause delay
outa=4
pause delay
outa=1
pause delay
outa=2
pause delay
outa=4
pause delay
word. OUTB refers to P4,P5,P6,P7, etc. There are other special words
that let you treat the I/O pins as a word or byte. These are useful when
you need to talk to devices that require parallel output like LCDs, for
example.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
Original Message
> From: danger_21sg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kQMpjOMf3l7kpqQybZma9lmMQPfBPf-jtCyxYyxTUfenthMrWEzTpVoBkCf5xxyJWWv4jkPHBCJD2fEhx34HCLQ]danger_21sg@y...[/url
> Sent: Wednesday, April 10, 2002 8:38 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Bs2sx programm for unipolar 4 phase
> stepping motor
> mean.Thx.[noparse]:)[/noparse] outa=1 pause delay outa=2 pause delay outa=4 pause delay
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
download a PDF version at no charge from www.parallaxinc.com.
As to your question below, OutA refers to pins 0, 1, 2 and 3 of the BASIC
Stamp. Using binary (%) notation for numbers, it's a bit easier to see
what's going on:
OutA = %0001 ' turn on pin 0
PAUSE delay
OutA = %0010 ' turn on pin 1
PAUSE delay
OutA = %0100 ' turn on pin 2
PAUSE delay
-- Jon Williams
-- Applications Engineer, Parallax
In a message dated 4/10/02 8:41:27 AM Central Daylight Time,
danger_21sg@y... writes:
> outa=1
> pause delay
> outa=2
> pause delay
> outa=4
> pause delay
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, April 10, 2002 6:38 AM
Subject: [noparse][[/noparse]basicstamps] Bs2sx programm for unipolar 4 phase stepping motor
> outa=1
> pause delay
> outa=2
> pause delay
> outa=4
> pause delay
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
