Msb,lsb?
Can someone please help me. I am trying to visualize what is MSB, and LSB. Is
MSB like this?
100 = 00100110
Or is it like this?
100 = 01100100
I know that LSB is the opposite of MSB.
Any info would be great
A. Conti
MSB like this?
100 = 00100110
Or is it like this?
100 = 01100100
A. Conti
>what is MSB, and LSB. Is MSB like this?
>100 = 00100110
>Or is it like this?
>100 = 01100100
MSB and LSB are really neither of the above.
100 decimal is equal to 01100100 binary. The MSB (most significant bit) of
the binary number is the first (leftmost) zero and the LSB (least
significant bit) is the last (rightmost) zero.
Jim H
> Jim H
So what you are saying is,
MSB LSB
01100100
If this is true then the stamp would send out 100 like this if it was MSBFIRST
0 first out
1
1
0
0
1
0
0 last out
Am I right?
A. Conti
> bit) of
> > Jim H
>MSB LSB
> 01100100
>0 first out
>1
>1
>0
>0
>1
>0
>0 last out
>Am I right?
Yes, that's right.
Jim H
The LSB is the right bit in binary always, and the MSB is the left bit, so
for
100 = 01100100 is correct. | MSB | 64 | 32 | 16 | 8 | 4 | 2 | LSB |
| 0 | 1 | 1 | 0 | 0 |
1 | 0 | 0 |
64 + 32 + 4 = 100
MSB for Byte (8 bits) is 128, and for Word (16 bits) it is 32768. I hope this
will help you out in knowing which
is correct and visually show how it works.
Have Fun !!
Dale Fleischmann
MSB like this?
> 100 = 00100110
> Or is it like this?
> 100 = 01100100
> A. Conti
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
A. Conti
The Basic Stamp can put out either the MSB first or the MSB first, here is
an example of the code for both;
SHIFTOUT D_out,Clock,MSBFirst,[noparse][[/noparse]pattern] or
SHIFTOUT D_out,Clock,LSBFirst,[noparse][[/noparse]pattern]
as you can see above do not assume which is first. In the Basic Stamp Manual
you can find a lot of information.
I was having some problems with my code awhile back and found my answers in the
manual. If you do not have a
manual either buy one or download it from the following site;
http://www.parallaxinc.com/html_files/downloads/download_documentation.htm
Have Fun !!
Dale Fleischmann
> > bit) of
> > > Jim H
> >MSB LSB
> > 01100100
MSBFIRST
> >0 first out
> >1
> >1
> >0
> >0
> >1
> >0
> >0 last out
> >Am I right?
> Yes, that's right.
> Jim H
bit (LSB). In base 10 a number like 1240 is read One thousand two
hundred and twenty four. The one is the MSB and the 0 is the LSB (some
might say least significant Byte & most significant Byte). Binary and
Hex are the same story only in a different number base. A number like
101 can be read from left to right or right to left. I could read the
LSB first and the MSB second or vice versa. I usually suggest formatting
the number such that the MSB is on the left and LSB is on the right,
i.e. as you would read a number in the base 10 system. Problem is in
binary a number like 101 would be the same number read either way. A
number like 100 would not be. If I took a number like 100 and said the
LSB was on the left my number would be a decimal 1. If I said the MSB
was on the left the decimal equivalent would be a 4. Each number system
has column weights of what the number adds up to be. In decimal the
weights are 1000 100 10 1 0 etc. In binary they are 64 32 16 8 4 2 1 0
etc. Hope this helps..
Leroy
MSB like this?
> 100 = 00100110
> Or is it like this?
> 100 = 01100100
> A. Conti
>All numbers have a most significant bit (MSB) and a least
>significant bit (LSB).
OK so far.
No, it is read as "One thousand two hundred forty." Convention is not to
use the word "and," although many do. The use of "and" incorrectly can be
confusing when dealing with values having fractional parts, and especially
when dealing with money.
Some might be incorrect. The concept of bit and byte have no standardized
meaning in the base ten numbering system. In numbering systems other than
base 2, the term is "most significant digit" and "least significant digit."
>Binary and Hex are the same story only in a different number base.
Binary yes, hex no. See above.
>A number like 101 can be read from left to right or right to left. I
>could read the LSB first and the MSB second or vice versa. I
>usually suggest formatting the number such that the MSB is
>on the left and LSB is on the right, i.e. as you would read a
>number in the base 10 system. Problem is in binary a number
>like 101 would be the same number read either way. A number
>the MSB was on the left the decimal equivalent would be a 4.
The above contains a good bit of babble and some elements of truth, but the
truths are based on hypotheses, "if" statements or assumptions, that have
no real place in the real world. It makes about as much sense to say, "If
I had horns and a nose that glowed I'd be Rudolph the Red-Nosed Reindeer."
You "usually suggest formatting the number such that the MSB is on the left
and LSB is on the right?" I gotta ask, to whom and under what
circumstances do you ever suggest formatting the other way around?
>Each number system has column weights of what the number
>adds up to be. In decimal the weights are 1000 100 10 1 0 etc.
No, the weights are 1000 100 10 1. There is no zero weight. The weight
value after 1 in the base 10 system is one-tenth. The transition from
integral weights to fractional weights is marked with a decimal
point. There is no zero weight. Zero is formed by placing a 0 in the 1s
position. You seem to be confusing the positional weight value with the
concept of a number line.
>In binary they are 64 32 16 8 4 2 1 0 etc.
Again, there is no zero weight.
>Hope this helps.
So do I.
Jim H
