Javelin Stamp as interpretator or Javelin Langugae being a complier to hex code?
The Javelin IDE compiles the program into compressed byte codes. An
on-stamp interpreter then uses the byte-code program to run.
-Martin Hebel
--- In basicstamps@y..., "John Leung" <jleung00@n...> wrote:
> Is the new version of Javelin Stamp running on interpreter or else,
it is a
> complier that comply the java code in hex code like other complier?
> John
-Martin Hebel
it is a
> John
John
