Decoding SPC output with the Stamp
HI,
I have several DRO's (digital read outs) mounted on
my drill/mill and my lathe for accurate positioning.
Each DRO is essentially a digital caliper with an ability
to output a binary position serially.
I'm wondering if anyone in the group has ever decoded
the serial SPC output of a digital caliper? Looks like
my next stamp project will be a multi-axis SPC readout
to an LED or LCD display but I don't want to re-invent
the wheel!
All comments are welcome!
Greg
the wheel!
Greg
>HI,
>the wheel!
>Thanks,
>Greg
Hi Greg -
I sent you a PDF file off list, to the address contained in
this email message.
Bruce Bates
goflo@p... writes:
> > this email message.
> Hi Bruce -
> Could I trouble you for a copy of the document you mention?
> regards, Jack
Bruce:
I too would like a copy of the PDF file you mentioned. As luck has it
I have been asked to interface an SPC device to a machine and I am looking at
doing it with a BS2 or SX.
Thanks in advance
Randy Abernathy
4626 Old Stilesboro Road
Acworth, GA 30101
Ph/Fax: 770-974-5295
E-mail: cnc002@a...
We service, install and repair industrial woodworking machinery
Specializing in SCM / SCMI CNC Panel Saws and Routers
Hi Greg -
Mitutoyo caliper protocol is 3-wire, CLK, DATA, REQ.
CLK and DATA are open-collector outputs. 10K pull-ups
work fine.
Pulling REQ low produces 52 clocks, DATA valid on
CLK low, each group of 4 bits represents a hex #,
lsb to msb:
d0-d3 0Fh
d4 sign digit, 0 is positive, 1 negative
d5-d10 measurement value, BCD, MSD to LSD,
d11 decimal point position in the 6-digit
measurement value, counting right to left
d12 units, 0=mm, 1=inches
IIRC CLK freq is 1562 Hz, or thereabouts.
regards, Jack
> this email message.
Hi Bruce -
regards, Jack
In the absence of written stamp code to decode the serial bit
stream from the calipers, I'll put it on my project list. This
is a great stamp project! I'll post to the list when finished
but don't hold your breath, I can procrastinate for months!!
My thanks to Bruce and Jack for responding to my question.
Greg
a Mitutoyo Indicator through the SPC connection. I'm having trouble
actually obtaining the correct data. I'm using a 10k pull-up
resistor and a 74HCT04N Hex inverter for the clk and data outputs.
The stamp im using is the BS2p so I dont think its a sampling speed
problem ...
Here is an example of expected and returned data I'm getting. Maybe
this will help:
Number 25.83 mm
Expected output:
1111 1111 1111 1111 0000 0000 0000 0010 0101 1000 0011 0100 0000
Obtained output:
1111 1111 1111 1111 0000 0000 0000 0000 1111 0000 1100 0000 0000
Thanks for your time!
If you could reply to my work e-mail address, it would be much
appreciated!
P.S. there was also some pdf file going around - do you know what it
contains?
Carlos De Oliveira
Halsall Associates Limited
2300 Yonge St., Suite 2300
Toronto, Ont. M4P 1E4
Tel: 416-487-5256 ext. 332 Fax: 416-487-9766
CDeOliveira@h...
> Hi Greg -
> work fine.
> lsb to msb:
> d0-d3 0Fh
> regards, Jack
