3x5 matrix keypad
what would be the best way to use a 3x5 keypad with wiring like the
following:
http://www.aasdcat.com/rstaph/3x5keypad_legend.gif
I'm not quite sure how to -- since there isn't a single wire that would
allow me to pull the pins I connect up or down.
-Rob
following:
-Rob
>following:
>-Rob
Hi Rob -
Who manufactures this keypad, and do you have the model number handy ?
Bruce Bates
A friend was going through his junk and we ended up trading a few things.
It seemed like the right size for something I was working on.
On that keypad legend, the number row at the top represents the pins in the
header that the keypad has. I see a pattern to it, just nothing like I've
had a chance to play with before.
-Rob
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, March 03, 2002 12:32 AM
Subject: Re: [noparse][[/noparse]basicstamps] 3x5 matrix keypad
> >following:
> >-Rob
> Hi Rob -
> Regards,
> Bruce Bates
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I was looking at the same keypad at Radio Shack yesterday. When you push
down on pad "A" wire #3 and #5 short
together, for pad "B" wire #4 and #5 short together and so on for all other pads
as indicated by 3x5 matrix. By
putting a pull-up or pull-down resister on the following pins it should work for
what ever logic you want the
switch to have when pushed down #3, #4, and #6. These are the wires running
vertical on the key pad requiring 3
pull-up or 3 pull-down resisters. The others can be used, but it would take 5
setups instead of 3 to make it
work. Back in the 70's I made a science fair project that used diodes on the
matrix to display binary numbers
using LED's, then using this binary number as inputs to a 7 segement display
driver to show the binary and its
decimal equivalent. I took first prize in my category with this project. It
would of been a lot simpler if I
could of used pull-ups or pull-downs at that time, but I did not know about them
because this was in the early
stages of my learning about electronics. Hope this will help.
Thank You
Dale Fleischmann
Robert Staph wrote:
> Manufacturer is unknown, but it looks like the one that radio shack carries.
> -Rob
Original Message
> From: "Bruce Bates" <bvbates@u...>
> > >following:
> > >-Rob
> > Hi Rob -
> > Regards,
> > Bruce Bates
> from the same email address that you subscribed. Text in the Subject and Body
Re:
I agree with Dale that it looks like connections 3,4 and 6 are the
"columns" and the other 5 connections {1,2,5,7,8} are the "rows" in
the matrix. Then each key connects one row to one column.
There are chips you can use for keyboard decoding, such as the
74C922. See BS1 App note #3 for a project that uses that chip along
with an LCD. Also, there are modules like the memkey sold by
Parallax, or one of Al's Pak modules I think, that do the scanning
and debouncing for you, so you don't have to write the code. Also
there are Nuts and Volts columns that cover matrix scanning, and
explanation in Scott Edwards' book.
If you want to hook the keypad matrix directly to a BS2 and have the
fun of scanning it yourself, it will take 8 pins, 5 for the rows and
3 for the columns, plus the 3 pullup resistors Dale mentioned.
Scanning is step 1, and then decoding is step 2 to match the scan
codes with what is printed on the key cap. I have a writeup on how to
do it using state machine logic at this URL:
http://www.emesystems.com/BS2fsm.htm#keypad.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
>you push down on pad "A" wire #3 and #5 short
>all other pads as indicated by 3x5 matrix. By
>should work for what ever logic you want the
>running vertical on the key pad requiring 3
>would take 5 setups instead of 3 to make it
>diodes on the matrix to display binary numbers
>display driver to show the binary and its
>project. It would of been a lot simpler if I
>know about them because this was in the early
>Thank You
>Dale Fleischmann
>shack carries.
> > -Rob
3 to the other. Pull each line down with a 10K resistor to ground,
and then set one axis as high outputs. Then set the 3 on the other
axis to inputs, and start scanning them. As soon as one goes high
(button is pressed), record which one, and then reverse all the io
lines. Make the outputs inputs, and the inputs outputs, and then
scan the remaining 5 inputs one time. One should be high, and then
you can translate your matrix. If this makes no sense, I can draw
you a little schematic, and send you some code I wrote to do this.
It is very reliable, and doesn't bounce.
/John
> following:
would
> -Rob
just 1 less pushbutton = 15, so the easy way and don´t
sacrifice many i/o is to use the 74C922 16 Keypad
Driver.
Connect your input keypad signals (rows and columns)
to the 74922, the you at the other side you have 5
outputs (from the 74922), one is the Key Press Enable
(so when you press any key you get a "1" o high in
that pin) and the other 4 is a 4 bit binary
convination. So with 4 bits you can have 16 possibles
results.
This one is the easy way.....
If you have any doubt just ask
Alex
--- johnschwab5678 <johnschwab5678@y...> wrote:
> If you don't mind using 8 io lines, you can attach 5
> to one axis, and
> resistor to ground,
> 3 on the other
> one goes high
> reverse all the io
> outputs, and then
> high, and then
> sense, I can draw
> wrote to do this.
> /John
> > following:
> single wire that
> would
> > -Rob
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Try FREE Yahoo! Mail - the world's greatest free email!
http://mail.yahoo.com/
In the StampWorks manual experiment #24 uses a 74HC165 parallel-in /
serial-out 8-bit shift register to
operate 8 switches on only 3 I/O lines. As a challenge it suggests using a
second so that you have 16 switches on
only 3 to 6 I/O lines. It says to check the data sheet for the 74HC165 for
connection of the two together, it has
only an abbreviated data sheet so you will have to find a full data sheet to see
how it should be connected. It
looks like you can do it with 4 I/O pins, but I am not quite sure. If you do
not have the StampWorks Manual go to
www.parallaxinc.com/html_files/downloads/download_documentation.htm and look at
the StampWorks Manual pages 117 to
119, and data sheet on page 167. I will be trying this as soon as I get a
second 74HC165. Note that all the
switches have pull-up resisters. Hope this will help you out.
Good Luck !!
Dale Fleischmann
johnschwab5678 wrote:
> If you don't mind using 8 io lines, you can attach 5 to one axis, and
> /John
> > following:
> would
> > -Rob
noticed that chip is for a 4 row X 4 column layout. So I'm going with the
74C923 which will do a 4x5 matrix keypad. 4x5 decoder fits better with a
3x5 keypad than 4x4 decoder does. I didn't want to use a work-around with
the 4x4. Using work-arounds is getting old fast. Thanks to those who
pointed me at the 74C922 as that led me to the line right under that, the
74C923.
-Rob
Original Message
Sent: Saturday, March 09, 2002 11:36 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: 3x5 matrix keypad
> A 4x4 keypad is a 16 pushbutton matrix a 3x5 keypad is
> Driver.
> results.
> Alex
> > to one axis, and
> > resistor to ground,
> > 3 on the other
> > one goes high
> > reverse all the io
> > outputs, and then
> > high, and then
> > sense, I can draw
> > wrote to do this.
> > /John
> > > following:
> > single wire that
> > would
> > > -Rob
> > ignored.
> Do You Yahoo!?
>Hello John;
> serial-out 8-bit shift register to operate 8 switches on only 3 I/O
> lines. As a challenge it suggests using a second so that you have 16
> switches on only 3 to 6 I/O lines. It says to check the data sheet for
> the 74HC165 for connection of the two together, it has only an
> how it should be connected. It looks like you can do it with 4 I/O pins,
Actually, it can still be done with the same 3 pins you used for a single
shift register. Just cascade the shift out of the 2nd SR into the shift in
of the 1st SR. And so on for as many shift registers as you need.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
74hc165's as Dwayne mentions.
"http://www.ucapps.de/midibox/midibox64_sr.pdf"
Ray
Dwayne Reid wrote:
> At 10:55 PM 3/9/02 -0700, Dale Fleischmann wrote:
> >Hello John;
> dwayne
